VWCOOL Samba Member
Joined: June 02, 2006 Posts: 1821 Location: Down under
Posted: Tue Dec 08, 2015 1:09 pm Post subject: Super Beetle strut tower layback for extra caster |
Folks, I am considering relocating the strut towers on my '75 rack and pinion Super 25mm rearwards to provide more caster. I also have some other ideas about getting extra caster into the chassis with machined sway bar mounts.
This car will replace my present BJ/IRS car used for hill-climb/motorsport
Wheels will be 15x6-inch 37P to retain the steering axis offset
Has anyone attempted similar? |
talljordan Samba Member
Joined: January 10, 2012 Posts: 964 Location: San Francisco, CA
Posted: Tue Dec 08, 2015 1:38 pm Post subject: Re: Super Beetle strut tower layback for extra caster |
Why not just buy a caster adjusting sway bar, or caster adjusting sway bar bushings. A lot easier, a lot cheaper. _________________ 1972 Super Beetle, Parked until adequate restoration funding is acquired in restoration!
Wanted: Male computer diagnostic plug end |
VWCOOL Samba Member
Posted: Tue Dec 08, 2015 5:58 pm Post subject: Re: Super Beetle strut tower layback for extra caster |
talljordan wrote: |
Why not just buy a caster adjusting sway bar, or caster adjusting sway bar bushings. A lot easier, a lot cheaper. |
Been there, done that... short swaybars are expensive. I've designed a swaybar mount kit that provides more caster than the offset bushes but my labour is free (for me, anyway!) and unpicking a few welds is hardly difficult
Posted: Tue Dec 08, 2015 5:59 pm Post subject: Re: Super Beetle strut tower layback for extra caster |
In that case I would machine the sway bar to be shorter to give extra caster. _________________ 1972 Super Beetle, Parked until adequate restoration funding is acquired in restoration!
VWCOOL Samba Member
Posted: Tue Dec 08, 2015 6:11 pm Post subject: Re: Super Beetle strut tower layback for extra caster |
talljordan wrote: |
In that case I would machine the sway bar to be shorter to give extra caster. |
Big machine required to set up the swaybar...? I can get a bar custom-made.. but I'd rather layback the struts as it is cheaper and easier and retains standard components
I'm also looking for more caster than those bolt-on methods provide so I can reduce the amount of static neg camber |
JasonBaker Samba Member
Joined: February 08, 2010 Posts: 1642 Location: Cleveland, TN
Posted: Wed Dec 09, 2015 11:52 am Post subject: Re: Super Beetle strut tower layback for extra caster |
I bought a pair of these for to help with camber. I posted it on the Superbeetle's only Facebook site and someone else contacted the manufacuter and they cut the slots out the other way for caster.
I have not installed the plates yet, but they were shipped from Poland pretty quick.
http://silverproject.eu/en/product-category/vw-2/suspension-vw/ |
VWCOOL Samba Member
Posted: Wed Dec 09, 2015 5:00 pm Post subject: Re: Super Beetle strut tower layback for extra caster |
Some brands of replacement/performance strut tops (such as K-Mac made here in Australia) offer adjustment for both camber and caster, but only as far as the constraints of the strut tower allows... in other words, only as far as the point where components such as tops and springs collide with the strut tower
Relocating the strut tower gets around this problem...but are there any drawbacks? |
theKbStockpiler Samba Member
Joined: July 07, 2012 Posts: 2316 Location: Rust Belt
Posted: Wed Dec 09, 2015 6:29 pm Post subject: Re: Super Beetle strut tower layback for extra caster |
Isn't increasing the castor going to increase oversteer tendencies? _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Use all safety devices including a mask. |
VWCOOL Samba Member
Posted: Thu Dec 10, 2015 4:56 am Post subject: Re: Super Beetle strut tower layback for extra caster |
theKbStockpiler wrote: |
Isn't increasing the castor going to increase oversteer tendencies? |
I will be using Porsche spring plates so will have adjustable rear camber - plus an adjustable rear sway-bar - to help dial-in the chassis balance |
