westcoastbullies Samba Member
Joined: July 02, 2002 Posts: 302 Location: DIABLOS SHADOW
Posted: Sat Feb 28, 2004 11:17 am Post subject: torque specs on gear box |
With the help of hazetguy's killer step by step, i got he boxes open and torn down...going to get parts right now, but need help on torque specs for re-assembly.... especially the half shaft nut behind "freeze plug", it was farily loose from get go...i dont want to crush my new bearings
thanks alot yall
Jeff |
Lind Samba Member
Joined: November 06, 2000 Posts: 9916 Location: idaho
Posted: Sat Feb 28, 2004 12:15 pm Post subject: |
all of the torque specs should be in your bentley manual. |
dstefun Samba Member
Joined: February 20, 2002 Posts: 3338 Location: Sacratomato
Posted: Sat Feb 28, 2004 12:25 pm Post subject: |
Torque specs are from the '60-'70 Without Guesswork book....but they're in the Bentley too....
Nut on driven shaft (behind the freeze plug) - 108 ft lbs Be sure to peen the shoulder of the new nut into the groove after torgue check. And use sealer on the freeze plug.
Nut on rear axle driven shaft - 217 ft lbs (to max of 250 to get nut to line up with cotter pin hole)
Redux front housing bolts - not listed (Bentley says "securely tighten") but they're 8mm bolts so I would use 15-20 ft lbs
Rear axle bearing/seal retainer 43 ft lbs _________________ ~~~~~~~~
Radio Questions R Us - what'cha need to know?
"Out! Out! You demons of stupidity!"
Remember - You are required to get older but you are not required to grow up!
62 SC & 66 Bus |
Posted: Sat Feb 28, 2004 11:19 pm Post subject: |
thanks dstefun..
i have neither of those manuals,....yet...but getting bentley.
things going together good... |
Hella Bro Samba Member
Posted: Sun Feb 29, 2004 5:28 am Post subject: |
Jeff what did you find that was bad in the box's? Were the bearings the problem? |
Posted: Sun Feb 29, 2004 10:15 am Post subject: |
broham
it was the inner top bearing, the race had cracked and basically i couldnt move car....cleaned everything and got parts,. so far so good
is this Al...i never knew your alias..ah haw!!
give me a call about kelly park when you got time, got a question _________________ WWW.WESTCOASTBULLIES.COM
TEAM AUOK 1984 SKATEBOARD CO. |
joe13 Samba Junkie
Joined: February 09, 2004 Posts: 173 Location: so cal area
Posted: Mon May 23, 2005 4:45 pm Post subject: torgue specs on flywheel and pressure plate for a 180mm |
i need to know what to torgue the flywheel and pressure plate 2
thanks for any help joe _________________ VW sickness |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Mon May 23, 2005 5:36 pm Post subject: |
Lind wrote: |
VERY helpful.
dstefun got it right.
also, don't forget to tighten/torque the reduction box to springplate bolts in the correct sequence. they get torqued to 10-12mkg, or 100-120 Nm, or 72-86ft. lbs.
the sequence of tightening is the same for both sides:
1. the center one of the 3 in the back (vertical row).
2. the forward one, near the shock mount.
3. the top one of the 3 in the back (vertical row).
4. the bottom one of the 3 in the back (vertical row).
i always use new GRADE 10.9 bolts (12 x 1.5 x 25) after chasing the threads in the reduction boxes, and if the threads are messed up, the get time-sert inserts installed. when re-installing the reduction boxes to the springplates, i start the middle rear bolt and the forward one, then start the other 2. if i can not run them in by hand, i do not force them, i align the hole better until i can run them in by hand. it's real easy to cross thread the bolt and damage the threads on both the bolt and the reduction box, which can cause a whole world of fun you don't want to do.
I also use new spring washers. and don't forget the brake line bracket on the upper bolt.
a few more pics to enjoy:
http://thesamba.com/vw/forum/album_page.php?pic_id=207531
http://thesamba.com/vw/forum/album_page.php?pic_id=207530
http://thesamba.com/vw/forum/album_page.php?pic_id=207529
http://thesamba.com/vw/forum/album_page.php?pic_id=207528
http://thesamba.com/vw/forum/album_page.php?pic_id=207527
http://thesamba.com/vw/forum/album_page.php?pic_id=207526 _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money |
