VWinVT Samba Member
Joined: April 21, 2013 Posts: 1541 Location: North East Kingdom
Posted: Thu Dec 10, 2015 2:39 pm Post subject: Is this opening supposed to be in my engine tin? |
While replacing motor mounts, I discovered this hole in the engine tin. It is located behind and to the left of the alternator...next to cylinder #2. It seems to be a big hole and I don't know if it is correct?...?
_________________ 1981 Westfalia with a 2001 Cabrio ABA
Small wheel turns by the firing rod,
Big wheel turns by the grace of God.
Every time that wheel turns 'round,
You're bound to cover just a little more ground. |
jpwerks Samba Member
Joined: July 16, 2009 Posts: 56 Location: Pacific Grove,Ca
Posted: Thu Dec 10, 2015 3:48 pm Post subject: Re: Is this opening supposed to be in my engine tin? |
plastic ducting for aux fan, I beleive _________________ 81' single cab 1.8T Syncro (converted)
85 Vanagon 1.8T
55 chevy
2008 330i BMW
2000 jetta 1.8T
2004 Golf 2.0 |
VWinVT Samba Member
Posted: Thu Dec 10, 2015 6:12 pm Post subject: Re: Is this opening supposed to be in my engine tin? |
jpwerks wrote: |
plastic ducting for aux fan, I beleive |
R u referring to the plastic ducting on the alternator fan? That ducting travels on the rear bumper side of the motor, not through this opening. I see the screw holes, but I have nothing to attach them to. I am considering making a piece to fit here _________________ 1981 Westfalia with a 2001 Cabrio ABA
pathao Samba Member
Joined: November 01, 2012 Posts: 291 Location: Montreal, Canada
Posted: Fri Dec 11, 2015 1:02 am Post subject: Re: Is this opening supposed to be in my engine tin? |
Looks to me like you are missing tin #15
I could be wrong I newbee to this and only took those apart only 1 time _________________ 1982 AC P27 - 2.0 FI FED - 091 - BA6
English is a second language to me |
pathao Samba Member
Posted: Fri Dec 11, 2015 1:03 am Post subject: Re: Is this opening supposed to be in my engine tin? |
Double post from above _________________ 1982 AC P27 - 2.0 FI FED - 091 - BA6
Posted: Fri Dec 11, 2015 4:37 am Post subject: Re: Is this opening supposed to be in my engine tin? |
Don't know if you can get anything from this picture or not. From the gallery:
VWinVT Samba Member
Posted: Fri Dec 11, 2015 6:44 am Post subject: Re: Is this opening supposed to be in my engine tin? |
Thanks for the help. It looks like it is #15 in the diagram, but not all of #15 is missing. Just the little corner/flange piece that juts out from #15 is missing. Its funny I looked at that exploded view of the tin many times and never noticed the little corner piece before...always good to have another set of eyes!! I swore that all my tin was in place...glad I had to replace the engine mounts...otherwise I may never have found the missing piece! _________________ 1981 Westfalia with a 2001 Cabrio ABA
Posted: Fri Dec 11, 2015 9:30 am Post subject: Re: Is this opening supposed to be in my engine tin? |
The piece of tin you have is probably for an earlier T4 engine from a bus or other use. When VW changed the fan shroud/alternator mounting in 1980 that added bit became necessary. |
VWinVT Samba Member
Posted: Fri Dec 11, 2015 10:24 am Post subject: Re: Is this opening supposed to be in my engine tin? |
I now have my next mini-project...convert some old scrap tin into cooling tin! _________________ 1981 Westfalia with a 2001 Cabrio ABA
