Axitech Samba Member
Joined: August 31, 2011 Posts: 1265 Location: Bucks County, Pa
Posted: Fri Dec 11, 2015 12:56 pm Post subject: Hoover mod question |
New aluminum case. Looking at possibly doing the hoover mods to it as I build the motor. Specifically, I'm at the 'drill the oil passages to connect the cam gallery to the lifter gallery on the right case half'. Anyone done it at home, with a hand-held drill? I've done all the measuring, several times. I think I can do it here, but want to hear the experienced guys say it's possible, or not possible, or it's a horrible idea.
If it's not out of the question to do it, what size drill bit. I swear, I searched high and low and cannot find that answer. It looks like it would have to be less than 5/16", but other than that, I can't tell.
Thanks,
Y'all have a Merry Christmas too! _________________ He said to them, “But now if you have a purse, take it, and also a bag; and if you don’t have a sword, sell your cloak and buy one. Luke 22:36
The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government.-Thomas Jefferson |
theDrew Samba Member
slalombuggy Samba Member
Posted: Fri Dec 11, 2015 2:39 pm Post subject: Re: Hoover mod question |
It's an easy mod I did it on both my aluminum cases with a cordless drill.
I think it's a 1/4" drill. Pull the plug out and you'll be able to fit a short drill bit on the hole to check and make sure.
I used a steel rod to measure to the end of the bore and then measured from the side of the web to the center of the hole in the cam journal and added those to get the depth. Then I marked the bit with a piece of tape.
I drilled the main galley out first and then drilled down through the journal,angling it slightly towards the back of the case as the hole is a bit bigger than 1/4". Clean it out good and tap for a pipe plug and you're good to go.
brad
58Dub Samba Member
Joined: June 02, 2004 Posts: 1713 Location: Davison, MI
Posted: Fri Dec 11, 2015 3:17 pm Post subject: Re: Hoover mod question |
its easy to do.... jsut measure and mark your bit for depths _________________ 58 Beetle (now just a pile of parts in the corner)
60 Beetle (2221 turbo under construction)
70 Beetle Baja project |
esde Samba Member
Joined: October 20, 2007 Posts: 5966 Location: central rust belt
ALB Samba Member
Joined: August 05, 2008 Posts: 3483 Location: beautiful suburban Wet Coast of Canada
Posted: Fri Dec 11, 2015 5:24 pm Post subject: Re: Hoover mod question |
Mr. Hoover claimed 7/32 (or 1/4" if you didn't have the smaller size) was big enough, and Mark Tucker has done it with a 3/16" drill (which when you think of it should provide plenty, as all your looking for is a steady supply), so 5/16" is rather large. With the possibility of going through the case going up with the larger sizes it might be a good idea to stay on the small side. _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
Posted: Fri Dec 11, 2015 5:52 pm Post subject: Re: Hoover mod question |
picked up a 5/16" bit tonight. It's too big, . I'm going to go with 3/16". _________________ He said to them, “But now if you have a purse, take it, and also a bag; and if you don’t have a sword, sell your cloak and buy one. Luke 22:36
EPETREA Samba Member
Joined: September 07, 2007 Posts: 391 Location: DFW TX
Posted: Fri Dec 11, 2015 6:07 pm Post subject: Re: Hoover mod question |
Who manufactured the case? I was to the point of drilling the same yet when I measured the area below the lifter boss, it seem to taper off and if I had drilled I most likely would have drilled through the casting. Pay close attention to the horizontal area between the thrust #1 cam bearing boss and #4 exhaust lifter. Measure down on outside of boss to be drilled vertically (crank pulley end)
I have my case sealed up but will try to find some pics to show what I am talking about. My case is from CB. I did however do the other mods and I'm not saying it cant be done, actually I think as long as there is enough meat in the area where you are drilling I think it will be fine.
Another option is to have the area built up by someone who knows how to weld aluminum (if you don't) and then drill. If you do , don't forget to lightly deburr your lifter bores where the bit enters. |
58Dub Samba Member
pretty sure I used a 1/4 inch bit _________________ 58 Beetle (now just a pile of parts in the corner)
Posted: Fri Dec 11, 2015 6:12 pm Post subject: Re: Hoover mod question |
Another option is to have the area built up by someone who knows how to weld aluminum (if you don't) and then drill. If you do , don't forget to lightly deburr your lifter bores where the bit enters. Here is a chart of the mods. area of concern is the lower red circle between boss and lifter bore for #4e |
Posted: Fri Dec 11, 2015 6:46 pm Post subject: Re: Hoover mod question |
Both my cases are from CB. Didn't have a problem with going through the case.
Editted my previous post as I found my build sheet with drill sizes on it.
brad |
Posted: Fri Dec 11, 2015 6:49 pm Post subject: Re: Hoover mod question |
It's an Autolinea case. _________________ He said to them, “But now if you have a purse, take it, and also a bag; and if you don’t have a sword, sell your cloak and buy one. Luke 22:36
raul arrese Samba Member
Joined: July 23, 2006 Posts: 1329 Location: miami florida
Posted: Fri Dec 11, 2015 7:05 pm Post subject: Re: Hoover mod question |
I did my autolinea by hand , its actually better by hand so u can go in at an angle , the angle is so you will meet with the other passage and not go out of the case and ruin it , well even if you did go through it could be fixed , aluminum is easy to fix. _________________ " Hot vw feature , may 2014 issue "
" 2013 Bug Jam class winner "
" Bug Jam best motor and best paint "
" 2013 Lakeland Classic Best of Show "
" 2014 Show and Shine , First in class "
Like my facebook https://www.facebook.com/pages/Raul-Arrese-custom-fabrication-and-performance/1832968110262608 |
Howard 111 Samba Member
Posted: Fri Dec 11, 2015 7:17 pm Post subject: Re: Hoover mod question |
I would never do any of Bob's mods. They may actually help this or that, but I want to run my engines based on the original design, but get as much HP out of it I can. But that's just how I would do it. You could wring real HP out of them long before Bob came along. _________________ 1973 Karmann Ghia
Turbocharged, Fuel Injected
http://www.thesamba.com/vw/forum/viewtopic.php?t=531270 |
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4856 Location: sanger ca
Posted: Fri Dec 11, 2015 7:44 pm Post subject: Re: Hoover mod question |
Or you could just start another thread about the same thing! _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Posted: Fri Dec 11, 2015 7:57 pm Post subject: Re: Hoover mod question |
I looked through all the Hoover Mods, and I actually have one in my current engine. Connecting the oil groves on the lifters. Berg did that on his lifters a long time ago. Then Bob came along...after Berg was dead...and made it look like HIS mod. Oh well, to each, their own. _________________ 1973 Karmann Ghia
Posted: Fri Dec 11, 2015 8:50 pm Post subject: Re: Hoover mod question |
mcmscott wrote: |
Or you could just start another thread about the same thing! |
not sure how that happened. _________________ He said to them, “But now if you have a purse, take it, and also a bag; and if you don’t have a sword, sell your cloak and buy one. Luke 22:36
Posted: Sat Dec 12, 2015 1:46 pm Post subject: Re: Hoover mod question |
Ok, I did it! Lots of measuring, praying, more measuring, then a drilling. really slow. I drilled to a depth where the lifter bore hole would barley intersect the cam bore hole. Then I drilled the cam bore hole , angled like some advised, then really slowly advanced the bit until it broke through. I pushed just a bit further until I got to the depth of what the lifter bore hole would be, and stopped. Went back and drilled the lifter bore hole through until the two were fully intersected.
Later on I went back and drilled the cam bore hole to 5/16" so I get lots of flow to the point where the lifter bore hole is 3/16". Lots more measuring and it looks like I missed blowing through by a pretty wide margin. Just to reassure myself, I flipped the case, open side down, and filled the 'valley' with really lightweight penetrating oil. If I did break through, it should seep out overnight. We'll see, but I am very confident my wife won't be shooting me anytime soon.
Another question. On the third pic, bearing surface closest to the flywheel, I saw a hole in the bearing mounting surface (looking again, it appears to be on the back of the flywheel seal area) that goes into the crankcase. Normal, or needs plugged. Purpose? _________________ He said to them, “But now if you have a purse, take it, and also a bag; and if you don’t have a sword, sell your cloak and buy one. Luke 22:36
esde Samba Member
Posted: Sat Dec 12, 2015 2:05 pm Post subject: Re: Hoover mod question |
Nice work! |
mark tucker Samba Member
Posted: Sat Dec 12, 2015 2:24 pm Post subject: Re: Hoover mod question |
in addtion to that, if you do widen/deepen the slot going around the center cambearing so it flows more, be sure to only widen on the pully end of the slots, due to the stroker clearancing the forward side is alreays way closeer than comfert .Ive seen some that were almost clearanced right into the slot, and thats lost oil pressure inside the engine where you cant see it being sprayed and lost. I dont enlarge the oil gally going through the lifter bores but I do enlarge the gally going from the driver side between the cylinders that go's to the center cam bearing tower. it's kinda tiny. |
