Tonyorlo Samba Member
Joined: June 03, 2013 Posts: 182 Location: Glen dale wv
Posted: Fri Dec 11, 2015 9:18 pm Post subject: Empi side mirrors |
Id like to know if anyone has used Empi side mirrors? I really dont like the stock mirror. My car has been painted so I dont really want to drill any holes.
http://www2.cip1.com/ProductDetails.asp?ProductCode=C13-4591
Id like to use this mirror, but I havent been able to find anything about if they would work on a ghia. My car is a 72 btw.
I searched on here with no luck also. |
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13952 Location: Southampton U.K.
CiderGuy Samba Member
Joined: December 23, 2013 Posts: 1351 Location: Bucks County, Pa
Posted: Sat Dec 12, 2015 8:12 am Post subject: Re: empi side mirrors |
I had two different Ghias that I purchased come with those mirrors. I don't think they fit the car. They are too modern looking. _________________ ----------------------
Cars Currently Owned:
1970 Karmann Ghia Coupe
1973 Karmann Ghia Coupe - Project car for sale
1970 Karmann Ghia Convertible (Body off restoration)
Timing is everything |
c21darrel Samba Member
swavananda Samba Member
Joined: February 14, 2009 Posts: 889 Location: Can o' Scruz
fes Samba Member
Joined: January 26, 2011 Posts: 999 Location: Prince Edward Island
Posted: Sat Dec 12, 2015 2:00 pm Post subject: Re: Empi side mirrors |
I have the Empi Spyder ones..They came with the car and are pure garbage..I've tried to fix the driver's side a few times and something else cracks..I cant really go back to stock because the PO drilled a hole to accept the longer plastic mounting bracket..
Be warned for these cheap-ass $20 parts _________________ '68 Campmobile-Pedro
'15 Golf-Stella Blau
'56 Oval-The Turd (for now) |
sirzo Samba Member
Joined: December 12, 2007 Posts: 170 Location: Australia
Posted: Sat Dec 12, 2015 3:27 pm Post subject: Re: Empi side mirrors |
I'm still none the wiser in mirror selection.
I have 2 later model coupes (1969 & 1970) both originally LHD which will be made into RHD.
I'd like matching left and right period correct mirrors that will be both functional. I have had Talbot reproduction mirrors offered to me, but the left hand mirror ( our passenger side) would be fitted just for looks and symmetry!
I have spent mega hours searching on forums, both here and elsewhere, but there does not seem to be any definitive word on the best option. Even House of Ghia seems to not make any clear recommendations.
Is there anyone who can chime in with a recommendation for a set that is covered by the the following criteria:
- cost: up to $300 (AUS) a pair, so probably quality reproduction,
- functionality: both mirrors useful to the driver, even if modification is needed,
- mounting position: either fender or door,
- period correctness: like John et all have indicated: chrome or stainless steel,
- style: don't really care: either:Talbot, Swan neck or original style. Preference in order listed.
I would like to make a decision before one of these cars goes to paint.
One of them has come with those butt ugly black plastic mirrors from the 80s!
Anyone? |
Rome Samba Member
Joined: June 02, 2004 Posts: 9641 Location: Pearl River, NY
Posted: Sat Dec 12, 2015 11:15 pm Post subject: Re: Empi side mirrors |
fes and sirzo- have you considered the original-style swan neck on the doors, so that you can hopefully use at least one of the holes already there; and the swan base would cover the other hole? The swan neck is not correct for your years but would be "era" correct.
Moogie32 did that on her '63, though only on the driver's side door:
I did this on my '64, on both doors. The right mirror is fully in view from my driving perspective and is useful especially with the top up.
Another possibility that would look "period suitable" would be this, for a Porsche 356: http://www.autoatlanta.com/Porsche-aero-Mirror-356-Parts-PN-RNLA73100200.html
Posted: Sun Dec 13, 2015 5:07 pm Post subject: Re: Empi side mirrors |
Thanks for all the replies!
Ive de chromed my car, all the trim is black now. I kinda like the modern look, the remind me of something off of a late 70s porsche.
They do look very cheaply made, and thanks for the warning Fes. I figured for how cheap they are it wouldnt break me to buy one and try it, as long as I dont have to drill any holes. I wondered if I could drill holes on the new backing plate to match the original holes? |
Rome Samba Member
Posted: Sun Dec 13, 2015 6:24 pm Post subject: Re: Empi side mirrors |
Tony, I went into your gallery to find a photo of your painted door (nice color- "champagne"- from what car is it?).
I don't remember- Are the small outer holes threaded for machine screws? Most of the "flag" style aftermarket mirrors like the one you might pursue have the stem of the mirror shaft coming down the base. On the better mirrors that stem has a nut and spring on it to tighten so that the mirror head does not easily swing back when the car is at highway speeds and the wind hits the flag surface. The base mounting rail of the aftermarket mirror relies on holes drilled in the door far apart front/rear for stability. You "might" be able to fit the base rail over your original holes so that the two machine screws are still usable. You could try to find a used mirror in the style you like so that you can experiment. If you end up being able to use the original door mounting holes then you can buy a new mirror. Just make sure that the mirror is designed to have a base and mirror stem that goes on a nearly vertical door surface like the Ghia. |
sirzo Samba Member
Posted: Mon Dec 14, 2015 4:24 am Post subject: Re: Empi side mirrors |
To Rome: really thanks for the suggestion of the 356 style aero mirrors and the Swan mirrors mounted on the doors. Great suggestions which gives me something to look into.
To Tony: sorry for the little hijack about the mirrors, but I'd like to take the opportunity to say how much I enjoy reading your Type 4 project thread. Your attention to detail is superb! I particularly loved your inter cooler vents with the extension box into the luggage area. Great work on the Tachometer conversion.
Also, IMO, your paint choice looks classy and really ties in the classic and modern themes together. Cudos to you mate!
I'm moving slow on my projects, mostly because of work/family issues and also because I want to make sure I have everything I need etc before the paint gets done. Hopefully I will start posting stuff in the New Year. |
Posted: Sun Aug 13, 2017 6:38 pm Post subject: Re: Empi side mirrors |
Digging this back up, I am getting back into my ghia project after a year. I partted out a 77 firebird and kept the mirror. Holding it up to the car, it fits the body well. its from a 70-81 Pontiac Firebird.
I just figured I would post this incase someone was trying to find a mirror for their car.
didget69 Samba Member
Joined: July 22, 2004 Posts: 4927 Location: Raleigh, North Carolina
Posted: Sun Aug 13, 2017 7:33 pm Post subject: Re: Empi side mirrors |
Tonyorlo wrote: |
Digging this back up, I am getting back into my ghia project after a year. |
... has it been a year?
bnc _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
Posted: Sun Aug 13, 2017 8:54 pm Post subject: Re: Empi side mirrors |
Almost 2 years actually, time goes by too fast.
I'm going try to get it mounted soon. I'll post a picture when I do. |
Posted: Tue Aug 15, 2017 3:07 pm Post subject: Re: Empi side mirrors |
I drilled a few holes in the firebird mirror mount and put it on, I didn't have to modify the door. The mirror has cables to adjust it from the inside, I will probably remove them and adjust it from the outside. I think it looks good myself.
