aa390392 Samba Member
Posted: Sun Dec 13, 2015 12:36 pm Post subject: OG 1967 Bendix Radio worked now it crackle's???? Help |
Hey, I took the engine in for rebuild, prior the radio worked,now with the rebuild engine, the radio now makes crackling noise?
Specs.dual port, 12volt,1967 stock bedix radio,
Like I said it worked fine before. .....something to with the distributor?
Thanks for any and all suggestions
Thomas _________________ .
getting grumpy & less tolerant!
55 ragtop
56 delux sedan
56 Kabriolet |
grandpa pete Samba Member
Posted: Sun Dec 13, 2015 12:58 pm Post subject: Re: OG 1967 Bendix Radio worked now it crackle's???? Help |
distributor should give you a wineing noise and can be fixed with a noise suppressor;
crackle might be the speaker is broken or loose
New repop speaker is less than ten bucks at Wolfsburg West _________________ 63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery |
EVfun Samba Member
Posted: Sun Dec 13, 2015 2:26 pm Post subject: Re: OG 1967 Bendix Radio worked now it crackle's???? Help |
A bad speaker, a bad power or speaker connections, or a cracked solder joint -- these are the usual suspects. A failing part cannot be ruled out. In your advantage is that you have some function, which should should make troubleshooting easier. After checking all external connections you may want to find an old school electronics repair shop. _________________
Wildthings wrote: |
Posted: Sun Dec 13, 2015 4:06 pm Post subject: Re: OG 1967 Bendix Radio worked now it crackle's???? Help |
Nope none of the above,
Static,and poping when eng. Is running, like I said was perfect before eng. Rebuild..nothing like a resistor in dist? _________________ .
55 ragtop
56 delux sedan
56 Kabriolet |
Posted: Sun Dec 13, 2015 4:08 pm Post subject: Re: OG 1967 Bendix Radio worked now it crackle's???? Help |
Condensor? Wiring from dist. To plugs? _________________ .
55 ragtop
56 delux sedan
56 Kabriolet |
rcooled Samba Member
Joined: September 20, 2008 Posts: 2507 Location: Santa Cruz, CA
Posted: Sun Dec 13, 2015 5:26 pm Post subject: Re: OG 1967 Bendix Radio worked now it crackle's???? Help |
This is only happening when the car's running, right? Does the noise change in any way when you rev the engine? If so, check the plugs to make sure they're the resistor type. Are the plug wires shielded?
aa390392 wrote: |
..nothing like a resistor in dist? |
No resistor, but you might check to see if the condenser was replaced during the rebuild. _________________ '63 Ragtop (current)
'65 Ghia coupe (totaled)
'69.5 Ghia convertible and
'62, '63, '65, '69 Bugs (all long gone) |
Posted: Mon Dec 14, 2015 6:41 pm Post subject: Re: OG 1967 Bendix Radio worked now it crackle's???? Help |
Rcooled are not all plug wires created equal....or do some have resistors in the wiring?
And if the condenser is new or the old one used? Does that make a difference?
Thanks for help
55 ragtop
56 delux sedan
56 Kabriolet |
Posted: Mon Dec 14, 2015 9:04 pm Post subject: Re: OG 1967 Bendix Radio worked now it crackle's???? Help |
aa390392 wrote: |
Rcooled are not all plug wires created equal....or do some have resistors in the wiring? |
Some wires have a compressed-copper core, or are jacketed in wire mesh to suppress radio static. Un-shielded copper wire (found in the standard Bosch VW cable set) acts like an antenna to broadcast RFI. If you use these wires, you need to pair them with resistor-type spark plugs.
aa390392 wrote: |
And if the condenser is new or the old one used? Does that make a difference? |
The condenser helps to minimize sparking at the ignition points when they open & close. This is another source of RFI. Condensers usually last a good long time, but you never know... _________________ '63 Ragtop (current)
Posted: Thu Dec 17, 2015 10:01 am Post subject: Re: OG 1967 Bendix Radio worked now it crackle's???? Help |
Thanks for help that should cure symptoms
55 ragtop
56 delux sedan
56 Kabriolet |
KTPhil Samba Member
Posted: Thu Dec 17, 2015 10:52 am Post subject: Re: OG 1967 Bendix Radio worked now it crackle's???? Help |
rcooled wrote: |
...or regular plugs plus the OEM resistor (1KΩ) bakelite SP connectors. |
