Decklid differences
EMPIImp69
EMPIImp69 is offline
PostPosted: Mon Dec 14, 2015 7:22 pm    Post subject: Decklid differences Reply with quote
Anyone know why this decklid doesn't have the reinforcement piece where the latch goes thru? I don't see any sighs of the piece ever being there, no spot welds, no holes. Supposedly the decklid is from a '62.
1969 Empi Imp #1325
1963 Ragtop Bug
Use this to balance your wide 5 steelies -->
http://www.thesamba.com/vw/classifieds/detail.php?id=1830990
Joe Bence
Joe Bence is offline
PostPosted: Mon Dec 14, 2015 7:43 pm    Post subject: Re: Decklid differences Reply with quote
Not a 62 (which would have a 58-63 style lid) , note it has a push button latch 65-66, so no inner structure.
WWW.JBEVWSTORE.COM
www.facebook.com/JoeBenceEnterprises
63vbug82
63vbug82 is offline
PostPosted: Tue Dec 15, 2015 1:15 am    Post subject: Re: Decklid differences Reply with quote
Nope not a 62 at all dose not have the lines that that swoop out on the plate light area and as mentioned its a push button lid the 62 would be a t handle lid. And the holes where light housing would bolt up and plate mount holes are different then a push button I was told that mid 64 and up to 67 would be the lid that you have I don't know if its true or not but maybe that helps
62 bug , 66 split bus ,63 bug R.I.P,
Slow 1200
Slow 1200 is offline
PostPosted: Tue Dec 15, 2015 2:02 am    Post subject: Re: Decklid differences Reply with quote
that's a 65 lid, a 66 would have the holes for the 1300 (or 1200 in the case of 1200As) script, while a 64 and 67 are different altogether
VOLKSWAGNUT
Fastest VW Belt Changer
Location: Flippin' a Belt........ .... Off-n-On ... NC USA
VOLKSWAGNUT is offline
PostPosted: Tue Dec 15, 2015 6:39 am    Post subject: Re: Decklid differences Reply with quote
Plus good information within > Official "What year is my decklid" thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=490378
aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited
branston Premium Member
branston is offline
PostPosted: Tue Dec 15, 2015 7:55 pm    Post subject: Re: Decklid differences Reply with quote
x2 a '65 only lid
EMPIImp69
PostPosted: Tue Dec 15, 2015 8:18 pm    Post subject: Re: Decklid differences Reply with quote
Thanks guys
1969 Empi Imp #1325
1963 Ragtop Bug
Helfen
Helfen is offline
PostPosted: Tue Dec 15, 2015 10:08 pm    Post subject: Re: Decklid differences Reply with quote
As a used lid, yes a 65, but when I worked at a dealer 1971 -72 era. The factory replacement hood for 65-66 did not come with any holes ( except for the latch ) because those hoods could be used for T-111 "A" sedan 1965 which had no script and used the 63 and earlier license plate lamp, or a T-113 deluxe 1965 which had no script and used the 64 and newer larger license plate lamp.
1966 T 111 1200A used the 1200 script and the old style small license plate lamp. 1966 T 113 used the large license plate lamp and the 1300 script.
That is also why front and rear fenders were not drilled for tail lamps and front turn signal lamps.
Sharp64 Premium Member
Sharp64 is offline
PostPosted: Wed Dec 16, 2015 12:40 pm    Post subject: Re: Decklid differences Reply with quote
Wouldn't an OE 65 have the wider span for the larger license plate light mounting holes?
EMPIImp69
PostPosted: Wed Dec 16, 2015 7:53 pm    Post subject: Re: Decklid differences Reply with quote
Yes someone drilled holes for an earlier light housing.
1969 Empi Imp #1325
1963 Ragtop Bug
Sharp64 is offline
PostPosted: Wed Dec 16, 2015 8:02 pm    Post subject: Re: Decklid differences Reply with quote
That's what I'm saying. Where are the other holes? Possibly a repop?
Helfen
Helfen is offline
PostPosted: Wed Dec 16, 2015 10:03 pm    Post subject: Re: Decklid differences Reply with quote
Apparently you didn't read my post. My 65 type 111 is a "A" sedan.
The image below is my 65 111 and my friends 1966 1200A type 115 a rag top. Both cars use the small type lic. plate. Note my car came with towel rack bumpers because that was the only was the car would be able to pass U.S Customs. see below:
https://www.thesamba.com/vw/gallery/pix/516078.jpg
