roadkingdoc Samba Member
Posted: Sat Apr 07, 2012 6:21 am Post subject: loose sun visor |
i have some droopy sun visors which are annoying as hell. i think they are tmi and on my 61. any way to tighten them up? thanks |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24671 Location: Olympia Wash Rinse & Repeat
Posted: Sat Apr 07, 2012 8:24 am Post subject: |
Should be a screw in them to carefully gently tighten up just enough to keep them from flopping down. _________________ In Stereo, Where Available! |
Posted: Sat Apr 07, 2012 8:23 pm Post subject: |
no screw to tighten. |
Posted: Sat Apr 07, 2012 8:45 pm Post subject: |
Post images. _________________ In Stereo, Where Available! |
steven wardlaw Samba Member
Posted: Sun Apr 08, 2012 6:34 am Post subject: |
Make sure the rods aren't turning. Mine were doing the same thing and it took a while to figure out the rods are not suppose to rotate. The metal clip behind the mounting bracket locks the rods from rotating. Mine is also a 62 so I hope they are the same. |
wayne1230cars Samba Member
Posted: Sun Apr 08, 2012 10:50 am Post subject: |
I had a similar problem on my 60 bug. I bought a set of visors from CIP. They were TMI visors. There was no screw to tighten. After a few months of frustration I ordered a set from Wolfsburg West. These did have a screw to tighten and the problem was solved. Actually 1960 is a one year only sun visor design as far as the horizontal pattern design of the vinyl but the quality of the WW visors is good. http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=113857551A
[img][/img][img][/img] These 2 photos show both sides of one TMI visor and the lack of a tightening screw. I bought these in April 2010. _________________ 1960 beetle
1970 beetle convertible |
Posted: Sun Apr 08, 2012 12:05 pm Post subject: |
thanks for the help. i pushed the visor into the shaft (still mounted in the car) and it seem to help some. |
CLASSIC CAR GUY Transport and Title Guru
Joined: August 09, 2010 Posts: 1608 Location: Phoenix AZ, but originally from Long Island NY
Posted: Sun Apr 08, 2012 3:53 pm Post subject: |
older TMI visors had a screw if i remember right, now and then i come across a car a set in some cars that i have bought with a screw but definitly not OG, new repop ones dont, although when there new there pretty stiff but if you use them often i can see how they loosen up _________________ (0\!/0)
58' Rag'
60' Type 1
61' Type 1
62' Type 1
64' Type 1
66' Type 1
66' Vert'
67' Type 1
"every one wants to reinvent the wheel, but nobody knows how to make it round"
Vintage Volkswagen Sales and Service as well as Classics and Muslcecars all located here in Phoenix Arizona at www.rpmotorcars.com |
bgprest Samba Member
Joined: December 15, 2009 Posts: 158 Location: Plano, TX
Posted: Mon Dec 14, 2015 4:22 pm Post subject: |
Eric&Barb wrote: |
Should be a screw in them to carefully gently tighten up just enough to keep them from flopping down. |
My passenger side visor keeps flopping down. Does anybody have a pic of just where this screw is supposed to be on them?
Thanks! |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9663 Location: Oregon
Posted: Mon Dec 14, 2015 4:38 pm Post subject: Re: loose sun visor |
Note that this is on a 67. The screw in question is on the right near the mount to the body.
I hope this helps.
Good luck
_________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
grandpa pete Samba Member
Posted: Wed Dec 16, 2015 10:34 am Post subject: |
bgprest wrote: |
Eric&Barb wrote: |
Thanks! |
I should have specified...
My passenger sun visor keeps flopping down on my '61 Beetle. So, I don't thing the heat shrink tubing solution applies to my situation. |
Posted: Wed Dec 16, 2015 3:50 pm Post subject: Re: loose sun visor |
grandpa pete wrote: |
no screws in some of the reproduction ones . That's why I went to the heat shrink |
...still not sure how the heat shrink works. And that link didn't make it clear to me. Sorry, but would you mind clarifying how it works for me?
Thanks. |
Posted: Wed Dec 16, 2015 4:08 pm Post subject: Re: loose sun visor |
Heat shrink is a plastic tubing used to cover soldered wiring connections and by a quick heating shrink down over the soldered joint.
Heat shrink in this case would act as a snug cover over the mirror arm and be being there the arm will have a slightly bigger diameter for the non-screw visor to be snug on. _________________ In Stereo, Where Available! |
Posted: Wed Dec 16, 2015 5:02 pm Post subject: Re: loose sun visor |
bgprest wrote: |
Thanks. |
great explanation ; thks Eric&barb _________________ 63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery |
Posted: Wed Dec 16, 2015 7:51 pm Post subject: Re: loose sun visor |
No problem. _________________ In Stereo, Where Available! |
