Walking Contradiction Samba Member
Joined: August 14, 2013 Posts: 453 Location: Oregon, OH
Posted: Mon Dec 14, 2015 7:54 pm Post subject: My Crazy 1974 Super Beetle Autocross Build |
Hello again, everyone!
Some of you may know me from my previous thread, A Total Noob's 1974 Super Beetle Restoration http://www.thesamba.com/vw/forum/viewtopic.php?t=566713. I have owned my 1974 Super Beetle since July of 2013, and have had quite a tumultuous journey with it so far. The original intention was to restore this car basically to factory stock. However, I have decided to retire that thread and create this new one, because I am taking an entirely different direction with the build (plus the old one was getting huuuuge). Last October I entered my Beetle in an Autocross put on by my local chapter of the SCCA. It was the most fun I'd ever had with the car. After that, I decided I had to turn my Beetle into a race car.
The Car:
This is the foundation of the build, my 1974 Super Beetle (nicknamed Butterfinger, don't ask), with 95,xxx documented miles (the odometer was broken when I got it, so who knows). It's essentially stock, but not an original or clean car. Its engine has been replaced, its interior was poorly restored by a previous owner, and it has been resprayed so many times that I have yet to determine its original color. It has rust that needs to be addressed behind the crescent vents, at the back of the driver's heater channel, the floor pan, and the driver's door bottom. It has a problem with idling that has proven unfixable thus far. Essentially, every component of this vehicle is going to have to be inspected, cleaned up, or replaced.
The Goal:
My goal with this project is to build an extremely high performance Super Beetle that is competitive in SCCA Autocross while retaining most of the comfort, reliability, and daily drive-ability of a stock one. I want to be able to terrorize Porsche 911s on weekends, and continue driving it to work and school every day from spring to the first snow of the year. The class I will be running in is for the time being is called Street Touring Sport. As the list of modifications grows, I would like to end up in Street Modified. The car will retain a full interior, a radio, and functioning heat. No major modifications to the chassis or body should be necessary. I am not going to cut up another Beetle. This thread will document the build process, and maybe the results of my races if people would like to see that.
Planned Work:
Front Suspension:
- Topline MAXX lowering struts w/80lb yellow springs (purchased)
- Topline 7/8'' sway bar (purchased)
- Complete front suspension and steering rebuild (most parts purchased)
Rear Suspension:
- Lower rear suspension
- Rebuild stub axles
- Replace CV joints (may upgrade to stronger axles)
- Topline Rear Sway Bar (dependent on how car handles after other modifications)
Brakes:
- Topline rear disc brake conversion w/parking brake (car already has front discs)
- Replace all metal hard lines besides main line through tunnel
- Stainless steel braided brake hoses
- New front wheel bearings
- New front brake rotors
- New master cylinder and reservoir
- High performance pads (researching options)
- Rebuild parking brake lever mechanism
Engine:
-Type 4 engine conversion (Undecided displacement or configuration; aiming for 150+ hp. Block purchased)
- Weber IDFs (44s or 48s)
- Raby DTM cooling shroud (undecided, I don't like that it has no provision for a thermostat)
- Tangerine Racing exhaust
Transmission:
- Rebuilt transmission (researching options and optimal gearing)
- Quaife LSD
Body:
- Repair rust
- Paint floor pans and undercarriage
- Weld up crescent vent holes
- Replace all window seals and trim
- Install pop out rear windows
- Floor pan bracing
- "Kafer Brace" (transmission and rear suspension brace)
- New rubber body seals and trim all around
- Clean up chrome on bumpers and install original rubber strip and end caps
- New shock absorbing bumper brackets for rear bumper
- H4 halogen headlights
- Hella 500 driving lights
- Fast Fab strut tower brace
- New running boards
- Kamei-style front spoiler
- Rear over window spoiler
- Replace windshield (has crack)
- Quality paint job in VW Brilliant Orange (or another shade of orange)
- Paint hood matte black
Interior:
- New tar boards
- TMI carpet kit
- Glass Action 911-style dashboard
- Corbeau Sport Seats
- New door panels
- VDO tachometer, oil pressure, oil temp, cylinder head temp, and voltmeter gauges
- New sun visors
- Replace rear seat padding with foam and install new seat cover
- Topline power pedal
- Grant suede racing wheel
- New seat belts
- Install new radio w/ 2 speakers in front foot wells
- Fire extinguisher w/bracket
Other:
- Black EMPI 8 spoke wheels w/ Goodyear Eagle Sport Tires (for street use and temporary autocross setup)
- Dedicated set of wheels w/ race compound tires for autocross use (undecided)
- Replace wiring front and rear wiring harnesses
Here's how the car should look when finished (minus the black hood and driving lights)
I'll begin work on it after I return from a vacation in early January. I hope everyone enjoys this build!
-Sam _________________ Samuel Hartford
1974 Super Beetle
Board Member of the Greater Toledo Volkswagen Club
Member of Northwest Ohio Region SCCA |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Mon Dec 14, 2015 8:13 pm Post subject: Re: My Crazy 1974 Super Beetle Autocross Build |
Never give up, Sam.
Looks like you're going to have some fun.
Merry Christmas,
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
Joined: May 17, 2003 Posts: 4863 Location: Harmony, PA
Posted: Mon Dec 14, 2015 8:20 pm Post subject: Re: My Crazy 1974 Super Beetle Autocross Build |
Sounds like a great project! I'm envious! I would look into what modifications would change your racing classifications. Modifying suspension/brakes will most likely elevate you in to a faster class where you may, or may no longer be competitive. The standard 4 x 130 brake kits work well, but a late Super shares some suspension characteristics of Porsche 924/944's. You may be able to get some stock Porsche braking setups that could be used with little, or no modification. This would also open up some wheel options to be used with larger/wider tires. |
Posted: Mon Dec 14, 2015 9:07 pm Post subject: Re: My Crazy 1974 Super Beetle Autocross Build |
[email protected] wrote: |
Thanks! I have looked into this somewhat. Street Touring allows all the suspension, brake, and wheel modifications I've outlined so far, minus the body and trans bracing I believe. When I go to the Type 4 motor (which will be one of the last things I do) I will get bumped up to Street Modified.
I have thought about doing a 944 brake swap, but decided against it for the time being because I just don't like the look of most Porsche alloys on a Beetle. When you go to a Porsche wheel pattern on a Super Beetle the backspacing requirements basically limit you to using factory Porsche wheels from what I've read so far. I think high performance 195/60/15s will be quite sufficient with the stock 1600 motor. However, I may run into problems finding the correct size tire size for race compound tires. I may be forced to go for a larger diameter wheel for those. If anyone has experience with wheel and tire setups for an autocross Beetle I would love to hear from you.
1974 Super Beetle
Posted: Mon Dec 14, 2015 9:08 pm Post subject: Re: My Crazy 1974 Super Beetle Autocross Build |
Tim Donahoe wrote: |
Never give up, Sam.
Merry Christmas,
Tim |
Merry Christmas, Tim. _________________ Samuel Hartford
1974 Super Beetle
ROCKOROD71 Samba Member
Joined: January 18, 2012 Posts: 2770 Location: Boston, MA
Posted: Tue Dec 15, 2015 7:32 am Post subject: Re: My Crazy 1974 Super Beetle Autocross Build |
Real interested to follow along on this one too. Type 4 conversion interests me very much, as I own a type 4 powered bus, and in my dreams I go Subaru on that and shove the type 4 in my bug someday so both cars can keep up in today's traffic!
Good on you for keepin it alive Sam!
Suspension upgrades I am guessing would be crucial. The death foam rot behind the crecents: I have yet to have this start on my 71, and it lives outside (knock on wood) I feel like every time I see a bad case of it on the Samba its a 73, 74, 75....maybe they changed something in those years? Might consider "shaving" the crecents with donor metal welded in if goin all in on that. Otherwise the missing metal should lower the weight of the car! On that note there are lots of do-dads you could lose to drop the weight, or swap, like carbon fiber hoods/trunks, fiberglass fenders....
Anywho...Good luck, I look forward to reading all about it! _________________ 1971 STD BEETLE- DD-1st car, 1st love. keepin' it stock! 1600DP, Solex 34-3 Mexi Bosch SVDA Dist NOW w/POINTS
1977 WESTY "KrustyKamper" 2L FI
79SuperVert wrote: |
30 years from now, the next guy may not want your girlfriend, but he may want your classic car, depending on how nice you were to it. |
asiab3 wrote: |
Careful guys, a petulant child can grow up to be president these days. |
**winter drivers: no survivors!**rust warrior**#keepbodyshopsbusy** |
Posted: Tue Dec 15, 2015 11:22 am Post subject: Re: My Crazy 1974 Super Beetle Autocross Build |
The Type 4 swap is going to be extremely exciting for me too. I was drawn to it due to its reputation for reliable power. Sure, you can get 150 hp out of a Type 1, but then it becomes a very high maintenance, short lived motor. For a Type 4 150 hp is nothing; they can go higher without problems. However, since this is my first longblock build, I'm going to keep it pretty simple, so the is less of a chance for me to screw it up.
Do you know of a source for carbon fiber VW parts? I feel like a carbon fiber hood and deck lid would look pretty boss. Maybe they could make me a front spoiler while they're at it . I'm not paying $800 for a plastic Kamei one.
1974 Super Beetle
slalombuggy Samba Member
Posted: Tue Dec 15, 2015 12:37 pm Post subject: Re: My Crazy 1974 Super Beetle Autocross Build |
You're going to want to put some bigger torsion bars in the back. Even in my buggy I run 27mm bars because it would sit down on the back so hard on big fast corners. The front inside wheel would come up 6 inches and the front would start to wash out with only one tire on the ground. And also if you are going with a T4 motor you need some more spring for the heavier motor.
If you don't want to spend $800 for a Kamei spoiler, you're not going to like the cost of carbon fiber parts. There is one company I saw making some CF parts for drag racers, but a deck lid was $400 and fenders were I think about $5-600 a pair.
As for engines. 150hp is easy with a T1 and you can make it live a good life. Just buy good parts.
brad
Posted: Tue Dec 15, 2015 12:38 pm Post subject: Re: My Crazy 1974 Super Beetle Autocross Build |
I remember this thread:
http://www.thesamba.com/vw/forum/viewtopic.php?t=310338&highlight=carbon+fiber
and another from a guy maybe in Turkey or somewhere like that who was starting up a CF parts co. That thread I linked to has a lot of the German Look guys chiming in, like Joel from Australia. they would be the ones to ask about all that stuff! I am a boring stock guy! _________________ 1971 STD BEETLE- DD-1st car, 1st love. keepin' it stock! 1600DP, Solex 34-3 Mexi Bosch SVDA Dist NOW w/POINTS
asiab3 wrote: |
Posted: Tue Dec 15, 2015 1:40 pm Post subject: Re: My Crazy 1974 Super Beetle Autocross Build |
slalombuggy wrote: |
brad |
I'm going to have to respectfully disagree here. This excellent thread on a Karmann Ghia set up for circuit racing http://www.shoptalkforums.com/viewtopic.php?f=51&a...p;start=15 goes into detail on why increasing the stiffness of the rear torsion bars is a bad idea unless you are going through very high speed turns. Porsche engineers found that decreasing the stiffness of the rear torsion bars improved the handling of rear engine cars such as the 356, and VW followed suit with the Beetle. In an autocross, even the fastest cars don't reach much more than 60mph on the straights, so the cars are never subjected to the extremely fast, high-G turns found in road racing. Also, the block of a Type 4 motor is only a couple pounds heavier than a Type 1. Once fully built and put into the car, the weight difference between a Type 1 and an upright-converted Type 4 is minimal.
I realize that carbon fiber parts are expensive because they are very labor intensive to produce, and they aren't an absolute necessity for my car. My issue with the Kamei spoiler is that it is literally just a piece of plastic that almost any of the aftermarket VW suppliers could produce for very little cost, but for some reason don't, which has inflated the prices of NOS Kamei spoilers to absolutely absurd proportions. You said it yourself, a set of carbon fiber fenders costs $200 less than a Kamei spoiler. It's the principle.
1974 Super Beetle
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Tue Dec 15, 2015 2:46 pm Post subject: Re: My Crazy 1974 Super Beetle Autocross Build |
http://www.thesamba.com/vw/forum/viewtopic.php?p=7835388&highlight=#7835388
Neither of the cars in this thread are Supers, but there is still some good stuff. My car is the blue car, and I doubt I have 150hp, but I have plenty for my current tires. To get a "very" competitive auto-x car, you'll have to go a bit further from the comfortable daily to closer to the "not so comfortable" beasty car. That can be especially true of a car with the humble origins as the Beatle has.
I doubt you'll need a full 150hp motor to make your car quick, but you will need some serious seat time to drive it quick, and that is mostly a "you have it or you don't" deal. Even if you "don't have it", it is still a blast to compete, so don't let that stop you. I recommend you go slow with the mods and really learn to drive the car and then make the changes you need to stay within a certain class as long as possible, then when you are competitive there, go to the next class.
The biggest things are tires and driver. That has been my experience, and that is with R comp classes and non R comp classes, you want the best tire the rules will allow. (That is my car's biggest handicap right now.)
Have fun, and don't fall too far down the hole... |
Posted: Tue Dec 15, 2015 3:17 pm Post subject: Re: My Crazy 1974 Super Beetle Autocross Build |
That's what I plan on doing. Easy stuff first, big stuff later. (I don't have the finances do do all this stuff at once anyway, lol) The motor will probably be the very last thing to get touched on this car. All the other mods I've planned can be carried out without changing classes. I am also ok with sacrificing some comfort for performance, just not to the point where there's no interior, no radio, no sound insulation of any kind, etc.
Driver skill is most certainly more important than any amount of car modifications when it comes to autocross. I've only done one event so far, so I have a long way to go. I wasn't hopeless out there though. I feel like with enough practice I could be a competent driver. The people I'm competing against are no experts either. Even if I don't win, it's still a massive amount of fun, and everyone gets a kick out of seeing such a slow car tearing it up.
1974 Super Beetle
Last edited by Walking Contradiction on Tue Dec 15, 2015 6:02 pm; edited 1 time in total |
DesertBob Samba Member
Joined: February 09, 2004 Posts: 1245 Location: Goodlettsville, Tennessee
Posted: Tue Dec 15, 2015 3:23 pm Post subject: Re: My Crazy 1974 Super Beetle Autocross Build |
Looking forward to following this thread. Sound like the same direction I have been heading. Mine: 1974 Super Beetle, 1776 with Dual 36 DRLA Dells, Top Line MaxStrut (red spring), front sway bar, rear sway bar and strut brace. Running Excel Struts and Shocks. They are OK but I think I will be going Bilstein or Koni soon. Running 4 wheel disc brakes with Porsche Turbo Twists (205/40x17 front and 225/45x17 rear). The chassis could handle more motor. Sticks hard in the turns with very little sway. Now that is on the back roads of Tennessee and not an Autocross track. Still pretty comfortable to drive.
_________________ All it takes is a little imagination, some mechanical ability, and neighbors who mind their own business
74 Super Beetle (German Look Project)
Full Flow 1776 with 36 Dells, 4 wheel drilled and slotted disc brakes, Porsche 7x17 Turbo Twists, Topline Maxx Struts, Camber kit, 7/8" Front Sway bar, Rear Sway bar, Urethane bushings all around. |
Posted: Tue Dec 15, 2015 7:02 pm Post subject: Re: My Crazy 1974 Super Beetle Autocross Build |
OK, just trying to share some of my 20 years experience racing my buggy in autocross.
https://www.youtube.com/watch?v=COyOmisaV30
brad |
Posted: Tue Dec 15, 2015 8:02 pm Post subject: Re: My Crazy 1974 Super Beetle Autocross Build |
And I appreciate it. I had no way of knowing you had such experience. The man that wrote the post I referenced also has decades of experience in autocross and road racing. Most problems in life have more than one solution, and that's ok. I'll find out what works for me when I get out on the track.
I looked at the rules again, and for the Street Touring, the limitations for wheels and tires are a maximum wheel width of 7.5'', a maximum tread width of 225mm, and a tread wear rating of 200 or higher. That means I can't do anything crazy yet, like Hoosier A7 slicks or something like that. Since I don't need large wheels to clear larger brake rotors, I am going to stick with 15''x5.5'' wheels with tires such as Dunlop Direzza ZIIs or Hankook RS-3s until I change classes. These will provide much better grip than the Goodyears I was suggesting without breaking the bank too much. Larger width and diameter wheels add a significant amount of unsprung weight which I would like to avoid.
1974 Super Beetle
ps2375 Samba Member
Posted: Tue Dec 15, 2015 8:45 pm Post subject: Re: My Crazy 1974 Super Beetle Autocross Build |
The 200 tread-wear is now for all classes other than Street Prepared, Prepared and Modified.
For a wheel and tire combo, if you are going to have a dedicated set, I'd look at a 16" wheel, as you'll have a better selection of tire widths and profiles to pick from. And since they are for "racing", they don't need to be pretty, but finding a wheel you want with the 4X130 bolt pattern will be your other chore. I has contemplated a set of wheels from Diamond Racing Wheels, they ca do the bolt pattern, width and offset you specify for a reasonable amount. They are a steel wheel, but aren't too heavy and are reasonable cost. And they come in black or silver.
Your other choice is to change bolt pattern, the cost is just as bad since then you need to buy wheels for dd duty also. |
Posted: Tue Dec 15, 2015 9:18 pm Post subject: Re: My Crazy 1974 Super Beetle Autocross Build |
I am definitely going to get a dedicated set of wheels and tires at some point. You're right, there just aren't a whole lot of wheel choices for the stock bolt pattern. In my quick search I didn't see any 16'' wheels in 4x130 either. May I ask what wheels / bolt pattern / tires you are currently running?
1974 Super Beetle
ps2375 Samba Member
Posted: Tue Dec 15, 2015 9:35 pm Post subject: Re: My Crazy 1974 Super Beetle Autocross Build |
I am on a 4X130 15" 5 or 5.5" wheel. 205/65 rear tire and a 185/65 front. If I am ever able to go a dedicated wheel/tire, it'll be on at least a 16" wheel with at least a 6" wide front and what ever I can fit in the rear. I'll prolly do what I mentioned and get a set of steel wheels and keep the 4X130 bolt pattern. I have Ghia disks upfront and type2 or 3 drums(they were installed long before I took possession of the car) in the rear. Plenty of brakes for anything this car will ever do.
Maddel Samba Member
Posted: Tue Dec 15, 2015 11:18 pm Post subject: Re: My Crazy 1974 Super Beetle Autocross Build |
Wow, that is some crazy stuff. I bet it's a ton of fun. Those look like a cross between a rally car and a sand rail.
Thank you very much for that link. As long as the cost of shipping from Germany isn't too crazy that should save me quite a bit of money. I don't think the part is expensive enough to have any customs duties. You have no idea how hard it is to find a Kamei spoiler in the United States.
1974 Super Beetle
