modok Samba Member
Joined: October 30, 2009 Posts: 26785 Location: Colorado Springs
Posted: Tue Dec 15, 2015 12:45 am Post subject: Custom tools for 8-dowel, and others, wheres waldo?? |
Here is a bunch of tool I have made or would like to share.
Most important is the dowel pin puller, which i made haphazardly in 15 minutes from rocker shafts and weld, and it works great! Just welded tab on one side, drilled a 5/16 hole in the end and through the tab, and then split the tab. Pulled many dowels with it. The slide hammer is a 55mm piston pin.
Although not as easy to see, there are two no-go gauges, which are just bits of shaft turned to a particular diameter then flats cut on the sides. i made them double sided. .314/.315 and .316/.317 These can gauge valve guides and also dowel pin holes. i have a handful of rods and valve stems also of varuis diameters to gauge holes. Take a crank and flywheel that aren't a matched set...... lets see how many of the holes line up? how big are they?
Usually, it's not perfect. And that's what the bag of 11/32 dowels and reamer is for.
I will let you guess what all the other tools are. Most you can identify but I bet some you can't!!
modok Samba Member
Posted: Tue Dec 15, 2015 12:47 am Post subject: Re: Custom tools for 8-dowel, and others, wheres waldo?? |
More!
Casting Timmy Samba Member
Joined: August 04, 2012 Posts: 1221 Location: Kansas City, Kansas
Posted: Tue Dec 15, 2015 5:46 am Post subject: Re: Custom tools for 8-dowel, and others, wheres waldo?? |
I see wheels on brackets for balancing rods end to end. Above that a tool you can use for compressing valve springs using a drill press. |
spencerfvee Samba Member
Posted: Tue Dec 15, 2015 6:15 am Post subject: Re: Custom tools for 8-dowel, and others, wheres waldo?? |
great job modok
modok wrote: |
MacLeod Willy Samba Member
Joined: February 18, 2014 Posts: 933 Location: Ontario Canada
Posted: Tue Dec 15, 2015 6:49 am Post subject: Re: Custom tools for 8-dowel, and others, wheres waldo?? |
Interested to know what the 9/16 deep socket welded to (appears to be a outside tooth gear) is for |
Posted: Tue Dec 15, 2015 6:55 am Post subject: Re: Custom tools for 8-dowel, and others, wheres waldo?? |
MacLeod Willy wrote: |
Never mind, its a timing belt not a gear. Assuming an oil filter wrench but why all the trouble to make one? |
nsracing Samba Member
Posted: Tue Dec 15, 2015 7:48 am Post subject: Re: Custom tools for 8-dowel, and others, wheres waldo?? |
Wow, Modok! You sure you are not in West VA?
Hey if they do what they are designed for, then very good.
Like the Russians would say... "it does not have to look pretty. just have to be able to shoot a bullet." (talking about their rifle designs) |
mark tucker Samba Member
Posted: Tue Dec 15, 2015 9:29 am Post subject: Re: Custom tools for 8-dowel, and others, wheres waldo?? |
Ive made somany special tools& jigs it's hard to remember them all....or find them. the issue I ran into is me not marking what they are so I dont make something else out of them then realize what it was half way through ,so i try to label them all now. most liike store bought, but some are crude.like the trans dif preload tool I made a few months ago. out of a ole chrysler hemi pully,a bmw motorcycle wheel ballancing addaptor(harborfright),a pully puller(harborfright),dial indacator and some steel flat stock for gussets....lotsa gussets..looks like shite but works like a charm...however charms work most i build is billet, but....like the trans press fixture I made out of 2x6 syp(southern yeller pine) quick,cheep eazy, works awesome and light weight with no hard places to ding anything that shouldent be dinged. |
A E Numan Samba Member
Joined: March 12, 2006 Posts: 238 Location: Portland Oregon
Posted: Tue Dec 15, 2015 9:35 am Post subject: Re: Custom tools for 8-dowel, and others, wheres waldo?? |
Please! show the individual tool and explain how you use it. Dowel puller first! |
modok Samba Member
Posted: Tue Dec 15, 2015 9:54 am Post subject: Re: Custom tools for 8-dowel, and others, wheres waldo?? |
Yes exactly, oil filter wrench.
I made it so I could remove an oil filter??? wasn't much trouble. I thought I might have invented something. |
theDrew Samba Member
ralf Samba Member
Posted: Tue Dec 15, 2015 10:44 am Post subject: Re: Custom tools for 8-dowel, and others, wheres waldo?? |
i like the oilfilter belt thingy, not just for vw's as u know modok u have a few inline4's its handy
DP manifold could be for portmatching, the radiused inlet tells me it could double as a flowbench manifold _________________ Flow Through a Curved Conduit
porting my SP head for my brother's project
https://youtu.be/OS_mVjQuqgk |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3439 Location: San Diego
Posted: Tue Dec 15, 2015 10:50 am Post subject: Re: Custom tools for 8-dowel, and others, wheres waldo?? |
It would be nice if someone could do a write up on how to ream/match the crank dowel holes with the flywheel. Tools? |
modok Samba Member
Posted: Tue Dec 15, 2015 5:23 pm Post subject: Re: Custom tools for 8-dowel, and others, wheres waldo?? |
ralf wrote: |
DP manifold could be for portmatching, the radiused inlet tells me it could double as a flowbench manifold |
Bingo, that's a big beef for port matching and flowbench. It's ported out pretty big but I fill in the inside with putty to do smaller ports. |
modok Samba Member
Posted: Tue Dec 15, 2015 5:27 pm Post subject: Re: Custom tools for 8-dowel, and others, wheres waldo?? |
chrisflstf wrote: |
I was going to do that but maybe I put too much junk in the picture, sorry. How many pictures can I load on here for free anyhow? |
modok Samba Member
Posted: Tue Dec 15, 2015 5:37 pm Post subject: Re: Custom tools for 8-dowel, and others, wheres waldo?? |
I'll get these out of the way.
-The square tube has a round tube in it 12.2mm ID. In this tube loosely fits a VW valve guide.
In the guide is a 5/16 drill bit welded to a small U joint. I made this tool to drill out broken exhaust bolts from chevy 350 and 4.3 engines when they break the one by the firewall, which is often.
The tube bolts to the head and pilots the drill-bit, while I'm on the other side of the fender well with the drill. I've used it three times.
-The two piston pins welded to a block functions the same as V-blocks. I use this to check runout of valves or lifters, or setup on 12" disk sander and tip valves and small rods.
-the oil filter wrench works great!
-two simple valve spring compressor adapters for drill press.
-The pen is a "firing indicator", it has a neon light in it and you hold it against a spark plug wire and observe the light for trouble shooting. I think everybody should have one of these. |
