volksaddict Samba Member
Posted: Sun Feb 29, 2004 6:45 am Post subject: oil pump for early cases, 6mm studs |
Hey what's the deal? I'm finding the early style oil pumps for the cases with small 6mm studs to be NLA. I've had a couple people say to put step studs in the case backwards and use the 8mm style oil pump, is that the best we can do now with what's available? Parts that used to be as common as a 72 super beetle are beginning to dry up, this sucks! |
keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19395 Location: Samba Center for Behavioral Science
Posted: Sun Feb 29, 2004 10:13 am Post subject: |
You can use the up to 70 model pump if your keeping the flat cam the gears on some later "HD" pumps may be bigger and the oil holes a bit bigger but I have used the later pumps in "F" cases and ealier 40 hp cases... |
BillyRx Samba Member
Posted: Wed Nov 29, 2006 3:36 pm Post subject: |
Hey Keifernet I'm building a 62 40hp motor and it seems the oil pump studs are too short. I've double checked the clearance between cover and gears and they're in spec. The pump body is seated in case and gear engages cam. However, I don't have enough thread on studs to torque cover down. I'm using original cam and the same oil pump that was in the motor. Any help would be appreciated. _________________ 63 Ragtop Beetle
63 Ragtop Beetle Ruby Red
63 double door panel |
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Wed Nov 29, 2006 11:32 pm Post subject: |
Remove the short ones, then run to the hardware store and get some longer bolts/studs. |
Posted: Thu Nov 30, 2006 7:02 pm Post subject: |
miniman82 wrote: |
Is there anything special about removing studs? Are they pressed in or screwed in. Do you heat case? ect.... _________________ 63 Ragtop Beetle
Posted: Thu Nov 30, 2006 9:12 pm Post subject: |
just lock two nuts against each other on the stud, and unscrew the stud from the case. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
