Mark Evans Samba Member
Joined: April 21, 2004 Posts: 1931 Location: Alsea,Oregon
Posted: Mon Dec 21, 2015 6:23 am Post subject: '55 Parking Brake with AirKewld Disc |
Putting together my '55 (finally) with the Air Kewld disc brake setup with parking brake. The cables supplied in the kit look like standard type cables that would just run to the parking brake handle assembly like '56 and later beetles. I haven't torn apart the entire original cable assembly in the pan (yes, the type that go to the front of the pan). Will stock new brake cables work with the Air Kewld setup? My original cables were cut at the exit tube outlets on the pan by someone else many years ago. _________________ '63 Ragtop |
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Mon Dec 21, 2015 9:13 am Post subject: Re: '55 Parking Brake with AirKewld Disc |
The AirKewld kit contains cables long enough to go to the front, the cable ends are bare and the kit includes the threaded ends that mechanically attach to the cable once pulled through. The threaded pieces attach via set screw.
Check your kit for these pieces. You have to cut the cables to length once pulled thru. It's a major pain in the ass, as it's a tight fit to install those ends
I have the same kit... |
Posted: Mon Dec 21, 2015 1:47 pm Post subject: Re: '55 Parking Brake with AirKewld Disc |
Thanks for your post, it explains and helps a LOT! One detail I failed to mention is I purchased this kit back in 2006, apparently there have been some changes made to the parts supplied in the kits. I spoke with Pete and he said that the earlier kits had CB Performance parts in them. This all is making things much clearer. _________________ '63 Ragtop |
Airkewld Samba Member
Joined: November 14, 2003 Posts: 3150 Location: Goodyear, AZ USA
Posted: Mon Dec 21, 2015 4:25 pm Post subject: Re: '55 Parking Brake with AirKewld Disc |
Mark Evans wrote: |
Thanks for your post, it explains and helps a LOT! One detail I failed to mention is I purchased this kit back in 2006, apparently there have been some changes made to the parts supplied in the kits. I spoke with Pete and he said that the earlier kits had CB Performance parts in them. This all is making things much clearer. |
Correct, it is how we began selling brake kits. We used to sell CB kits that we would cross drill and stud and sent detailed for our clients. _________________ TheSamba members-only discount - Samba24
Win a FREE Chassis Rebuild - https://airkewld.co/WinAChassis
Learn from a PRO on Patreon - https://www.patreon.com/Airkewld
FAQ - https://airkewld.co/FAQ
View our Industry Leading Products - https://www.airkewld.com/Products-s/2322.htm
We made a iPhone Ringtone with a Classic VW Turbo Engine - https://airkewld.co/RingtoneTurbo
YouTube Channel - https://airkewld.co/SubSamba |
EVfun Samba Member
Posted: Mon Dec 21, 2015 5:20 pm Post subject: Re: '55 Parking Brake with AirKewld Disc |
Mark Evans wrote: |
Putting together my '55 (finally) with the Air Kewld disc brake setup with parking brake. The cables supplied in the kit look like standard type cables that would just run to the parking brake handle assembly like '56 and later beetles. I haven't torn apart the entire original cable assembly in the pan (yes, the type that go to the front of the pan). Will stock new brake cables work with the Air Kewld setup? My original cables were cut at the exit tube outlets on the pan by someone else many years ago. |
1956 and later? My '57 has the cables terminate at the ebrake handle, unlike '55 and older but like later Bugs, however they are different than the '58 and newer ebrakes. My wheel cylinders are at the bottom and the ebrake cables loop around so they enter from the back. Isn't that normal for oval ebrakes? _________________
Wildthings wrote: |
Posted: Wed Dec 23, 2015 6:37 am Post subject: Re: '55 Parking Brake with AirKewld Disc |
I'm sure you're correct. I was just meaning that '56 and later were all together different. I have emailed with Pete at AirKewld and we have come up with a solution. Thanks Pete! _________________ '63 Ragtop |
Posted: Mon Feb 12, 2018 12:35 pm Post subject: Re: '55 Parking Brake with AirKewld Disc |
FYI-unfortunately, the solution was for me to purchase more products. _________________ '63 Ragtop |
txoval Samba Member
Posted: Mon Feb 12, 2018 5:11 pm Post subject: Re: '55 Parking Brake with AirKewld Disc |
Mark:
I think I posted about this in another thread, but here is what I ended up doing:
1) I used the original 55-earlier cables and cut off the end that attaches to the original drum brake levers
2) I took the threaded ends in Airkewld kit that attach via an Allen set screw, cut off the threads completely and using a bench grinder shaped the part into a cone, leaving the set screw end operational
3) fed the stock cables through, connected the threaded ends at the front adjustment plate at the midpoint of the threads
4) connected the rear end of the cable to the bracket/caliper and measured the cable to the emergency brake lever
5) cut the cable and slid on the modified set screw piece
6) adjusted cables at front to proper setting
By moving the set screw attachment to the rear, I had plenty of room to work
I wish I had pics, but I recently sold my 54... |
Posted: Tue Feb 13, 2018 7:27 am Post subject: Re: '55 Parking Brake with AirKewld Disc |
txoval, yes we pm'd a few times to figure this out (thanks again). I was just going through some old posts. I was certainly not happy with the follow up decision made by AirKewld. _________________ '63 Ragtop |
txoval Samba Member
Posted: Tue Feb 13, 2018 9:36 am Post subject: Re: '55 Parking Brake with AirKewld Disc |
I agree, for $1000+ they should make a cable that fits without the BS
All it would require would be to provide a modified stock cable with a "ball end" at the rear connection. With the large adjustment of the threaded end, they should be able to measure the cable and make it right.
I think overall Airkewld makes good products, this one just needs to be revised.
The other issue is market/demand...I would bet the demand for 55 and earlier rear disk brake kits with parking brake is minimal, not excuse, just reality
If I build another oval it will be a 56-57... |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13270 Location: Tejas!
Posted: Tue Feb 13, 2018 10:49 am Post subject: Re: '55 Parking Brake with AirKewld Disc |
Mark Evans wrote: |
txoval, yes we pm'd a few times to figure this out (thanks again). I was just going through some old posts. I was certainly not happy with the follow up decision made by AirKewld. |
belongs in his feedback - not necessarily just here _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
