Rob's '63 Rag thread
Page: Previous  1, 2, 3 ... 10, 11, 12, 13, 14  Next
EMPIImp69
EMPIImp69 is offline
PostPosted: Wed Sep 04, 2019 6:56 pm    Post subject: Re: Rob's '63 Rag thread Reply with quote
Was wondering if anyone painted their ragtop vinyl? I've used SEM vinyl paint in the past with good results. Vinyl is in great shape, it just has some pretty stubborn stains on it. Might try straight bleach on a spot.
Also started to hit the rear vents with the sand blaster. Will be a slow process..but starting to get there.
1969 Empi Imp #1325
1963 Ragtop Bug
Use this to balance your wide 5 steelies -->
http://www.thesamba.com/vw/classifieds/detail.php?id=1830990
EMPIImp69
PostPosted: Sun May 17, 2020 6:33 pm    Post subject: Re: Rob's '63 Rag thread Reply with quote
Back on this car again as I get closer to paint.
Welded in the heat tubes, sealed them up.
More work smoothing the hood out
Stripped inside decklid of paint, rust, dirt and grease
Had to make a relief cut in this qtr patch b/c it wasn't allowing the door to close enough. All good now
Smoothed out engine tray patch
1969 Empi Imp #1325
1963 Ragtop Bug
EMPIImp69
PostPosted: Tue May 26, 2020 7:19 pm    Post subject: Re: Rob's '63 Rag thread Reply with quote
Decided to completely strip hood. Only like a third of the way done.
Going around the car touching up pinholes with spot filler
Finally finished stripping the paint in the rear vents. Used paint stripper with drill and scotch brite and sandblasting
Put a temporary paint booth up
1969 Empi Imp #1325
1963 Ragtop Bug
EMPIImp69
PostPosted: Mon Jun 01, 2020 5:34 pm    Post subject: Re: Rob's '63 Rag thread Reply with quote
Finished stripping the hood to bare metal
Finished up the fans for the paint booth.
Got the 2k filler primer laid down
Next up after all the block sanding will be ready for the basecoat.
1969 Empi Imp #1325
1963 Ragtop Bug
EMPIImp69
PostPosted: Tue Jun 02, 2020 4:58 pm    Post subject: Re: Rob's '63 Rag thread Reply with quote
Stripped down the last of the painted parts
1969 Empi Imp #1325
1963 Ragtop Bug
EMPIImp69
PostPosted: Sun Jun 07, 2020 7:32 am    Post subject: Re: Rob's '63 Rag thread Reply with quote
Hit the fenders and door bottoms with undercoat.
1969 Empi Imp #1325
1963 Ragtop Bug
Smurf
Smurf is offline
PostPosted: Sun Jun 07, 2020 9:21 am    Post subject: Re: Rob's '63 Rag thread Reply with quote
Looking good
1962 Beetle
1977 Westfalia (Subaru Conversion)
"Traveling in a fried-out Kombi
On a hippie trail head full of zombie"
-Men at Work
TinCanFab
TinCanFab is offline
PostPosted: Mon Jun 08, 2020 10:06 am    Post subject: Re: Rob's '63 Rag thread Reply with quote
What's the airflow like in your little booth with those 2 fans? When I painted my truck in my garage and no fans, and only the door open, my eyes were burning and watering so bad it was hard to finish by the 4th coat.
I've been looking around for a paint booth to rent in my area, but it's becoming difficult these days. Putting a Bug on a trailer and bringing all those loose pieces seems like a nightmare waiting for a scratch. I've been painting all 19 pieces for a buddy's motorcycle and it's been a real challenge to keep dirt out.
Check out my truck brought back from the dead... http://www.thesamba.com/vw/forum/viewtopic.php?t=420762&highlight=sprayed+blood
They're never really ever finished 58 rag build...
http://www.thesamba.com/vw/forum/viewtopic.php?t=658092
EMPIImp69
PostPosted: Mon Jun 08, 2020 7:16 pm    Post subject: Re: Rob's '63 Rag thread Reply with quote
Hey Tincan, the booth can get tight at times, and you have to move stuff around, but I made the most of it. The fans do ok, but occasionally I need to blow off the filters or change them out to cut down the dust. I wet down tarp on the floor.
Finally laid some color, looks green in the booth but its Gulf Blue.
Then hit everything with clear
Cleared the steering column piece I painted a while ago
1969 Empi Imp #1325
1963 Ragtop Bug
TinCanFab
PostPosted: Tue Jun 09, 2020 8:58 am    Post subject: Re: Rob's '63 Rag thread Reply with quote
I think I'm going to have to bite the bullet and do the same kind of setup. Looks great!
EMPIImp69
PostPosted: Tue Jun 09, 2020 5:00 pm    Post subject: Re: Rob's '63 Rag thread Reply with quote
Thanks, today I started to wet sand parts and use Wizard's turbo cut to buff out some runs and little nibs here and there in the paint. My decklid has some clearcoat overspray that I'm going to wetsand and buff out too.
1969 Empi Imp #1325
1963 Ragtop Bug
EMPIImp69
PostPosted: Thu Jun 11, 2020 5:37 pm    Post subject: Re: Rob's '63 Rag thread Reply with quote
Wetsanded and buffed the decklid and a fender. Still need to machine polish.
Accidentally leaned it on a sawhorse and scratched, will have to touch up and fix
1969 Empi Imp #1325
1963 Ragtop Bug
Dibaltic
Dibaltic is offline
PostPosted: Sun Jun 14, 2020 8:42 am    Post subject: Re: Rob's '63 Rag thread Reply with quote
The paint came out nice!
Dake
Dake is offline
PostPosted: Sun Jun 14, 2020 4:30 pm    Post subject: Re: Rob's '63 Rag thread Reply with quote
Your paint looks awesome. Nothing feels as good as doing it yourself. Very Happy
EMPIImp69
PostPosted: Sun Jun 14, 2020 6:57 pm    Post subject: Re: Rob's '63 Rag thread Reply with quote
Thanks guys
1969 Empi Imp #1325
1963 Ragtop Bug
EMPIImp69
PostPosted: Wed Jun 17, 2020 3:10 pm    Post subject: Re: Rob's '63 Rag thread Reply with quote
Still more cut n buffing going on.
Also had to drill some holes for the bumper brackets
1969 Empi Imp #1325
1963 Ragtop Bug
EMPIImp69
PostPosted: Fri Jun 19, 2020 6:24 am    Post subject: Re: Rob's '63 Rag thread Reply with quote
Got the front fenders polished and a door
1969 Empi Imp #1325
1963 Ragtop Bug
hewica8
hewica8 is offline
PostPosted: Fri Jun 19, 2020 2:09 pm    Post subject: Re: Rob's '63 Rag thread Reply with quote
That color is niiiice! Excellent work.
63 Beetle Build: The Army Brat
EMPIImp69
PostPosted: Fri Jun 19, 2020 4:55 pm    Post subject: Re: Rob's '63 Rag thread Reply with quote
Thanks, here's the last loose part buffed out. Next will be onto body soon for final bodywork and paint.
1969 Empi Imp #1325
1963 Ragtop Bug
Chickensoup
Chickensoup is offline
PostPosted: Fri Jun 19, 2020 5:58 pm    Post subject: Re: Rob's '63 Rag thread Reply with quote
Your almost there!!! keep it up. and that's a lovely color btw.
#your_feelings_dont_matter
'65 Tourist Delivery Beetle
'66 baja- crumbled
'69 sunroof standard- parting out, PM ME if you need parts
'05 passat wagon TDI rolling coal mobile
'04 jianche flywing mx100 w/ head work and other goodies
-Aiden
Page 11 of 14
