Rob's '63 Rag thread
Page: Previous  1, 2, 3, 4 ... 12, 13, 14  Next
thomas.
thomas. is offline
PostPosted: Thu Jan 28, 2016 6:35 am    Post subject: Re: Rob's '63 Rag thread Reply with quote
Sharp64 wrote:
That's just a handle to a pretty common scissor style if im not mistaken.
From the classifieds a repop;
http://www.thesamba.com/vw/classifieds/detail.php?id=1090316
EMPIImp69
EMPIImp69 is offline
PostPosted: Thu Jan 28, 2016 7:39 am    Post subject: Re: Rob's '63 Rag thread Reply with quote
I think your right, it almost looks too thin to be a crank handle. It's the same thickness as the correct lug/jack handle I need.
1969 Empi Imp #1325
1963 Ragtop Bug
Use this to balance your wide 5 steelies -->
http://www.thesamba.com/vw/classifieds/detail.php?id=1830990
EMPIImp69
PostPosted: Tue Feb 09, 2016 6:50 pm    Post subject: Re: Rob's '63 Rag thread Reply with quote
Polished out the slide rails for the rag assembly. Been renovating a bathroom in the house so not much done on the bug.
1969 Empi Imp #1325
1963 Ragtop Bug
EMPIImp69
PostPosted: Thu Feb 25, 2016 6:28 pm    Post subject: Re: Rob's '63 Rag thread Reply with quote
Got my beam narrowed 3.5" and wheels widened to 15x8s and 15x6s. Decided to go with wide steelies instead of the polished 5 spokes. Not sure yet what color I'll paint them yet.
1969 Empi Imp #1325
1963 Ragtop Bug
EMPIImp69
PostPosted: Wed Mar 09, 2016 5:36 pm    Post subject: Re: Rob's '63 Rag thread Reply with quote
Built a body dolly. Made it tall enough so frame can roll under it. Body coming back off soon
1969 Empi Imp #1325
1963 Ragtop Bug
EMPIImp69
PostPosted: Sun Mar 13, 2016 6:12 pm    Post subject: Re: Rob's '63 Rag thread Reply with quote
Got the shell on the dolly. Started stripping the rear apron of paint. Going to be a long road ahead of paint stripping, sanding and new paint prep.
1969 Empi Imp #1325
1963 Ragtop Bug
EMPIImp69
PostPosted: Tue Mar 22, 2016 6:53 pm    Post subject: Re: Rob's '63 Rag thread Reply with quote
Had this rear apron latch cut out of another car and welded it onto the aftermarket rear apron I have. Still need to grind the welds and line up the decklid better.
Also got some new tires for the rear 8" smoothies 225/50/15 and some more parts off CL including a Scat 35 cam for the engine. Wires are old school.
1969 Empi Imp #1325
1963 Ragtop Bug
EMPIImp69
PostPosted: Tue May 10, 2016 6:01 pm    Post subject: Re: Rob's '63 Rag thread Reply with quote
Been working on the bug again. Got some shock towers, welded them to the beam and shortened the leaves. Painted the beam again, painted the frame head, steering box and bolted the beam back on.
1969 Empi Imp #1325
1963 Ragtop Bug
EMPIImp69
PostPosted: Tue May 10, 2016 6:07 pm    Post subject: Re: Rob's '63 Rag thread Reply with quote
I picked up some 1.25" wider fiberglass rear fenders but I'm not sure if I'm going to use them yet.
I also am converting this later model fender to early style in case I go with stock size steel fenders
Other side
1969 Empi Imp #1325
1963 Ragtop Bug
EMPIImp69
PostPosted: Tue May 10, 2016 6:11 pm    Post subject: Re: Rob's '63 Rag thread Reply with quote
Also put in new cable boots. Still need to replace clutch crossshaft and bushings.
1969 Empi Imp #1325
1963 Ragtop Bug
EMPIImp69
PostPosted: Tue May 10, 2016 6:34 pm    Post subject: Re: Rob's '63 Rag thread Reply with quote
Here's what I did on the beam after I cut down the stock shock towers.
Had to mark and dimple the leaves
1969 Empi Imp #1325
1963 Ragtop Bug
EMPIImp69
PostPosted: Tue May 17, 2016 5:43 am    Post subject: Re: Rob's '63 Rag thread Reply with quote
Pulled it outside, started sanding down some of the surface rust. Still more to go.
Pulled the harness out
I ended up using a later model fender on the pass side, so I filled in the bumper bracket area
Primed the fenders & cut the opening for the bumper bracket. Still need to drill for the overrider hole.
1969 Empi Imp #1325
1963 Ragtop Bug
grandpa pete
grandpa pete is offline
PostPosted: Tue May 17, 2016 7:21 am    Post subject: Re: Rob's '63 Rag thread Reply with quote
Why is there a hose clamp on your Bowden tube ??
63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery
EMPIImp69
PostPosted: Tue May 17, 2016 4:03 pm    Post subject: Re: Rob's '63 Rag thread Reply with quote
Its keeping the dust boot from moving.
1969 Empi Imp #1325
1963 Ragtop Bug
EMPIImp69
PostPosted: Tue May 17, 2016 6:43 pm    Post subject: Re: Rob's '63 Rag thread Reply with quote
Cleaned up the tie rods and shortened them about an inch and tapped the ends. May need to shorten them a little more. Going to change driver side tie rod ends.
1969 Empi Imp #1325
1963 Ragtop Bug
EMPIImp69
PostPosted: Sun May 22, 2016 5:48 pm    Post subject: Re: Rob's '63 Rag thread Reply with quote
Pretty much wrapped up the front end and put in the pedal assembly.
Put in new cross shaft and bushings
Finished drilling the hole for over rider in this fender.
Did some more sanding and bodywork.
Used Evercoat Rage on the quarter panel. Stuff is nice and smooth, goes on like butter and sands well too.
1969 Empi Imp #1325
1963 Ragtop Bug
EMPIImp69
PostPosted: Sat May 28, 2016 5:57 pm    Post subject: Re: Rob's '63 Rag thread Reply with quote
Got the tires mounted on the polished 5 spokes I got. Pretty much level front and rear.
1969 Empi Imp #1325
1963 Ragtop Bug
grandpa pete
PostPosted: Sat May 28, 2016 6:06 pm    Post subject: Re: Rob's '63 Rag thread Reply with quote
Coming along ; I like the silver gray chassis Smile
63 two fold rag
EMPIImp69
PostPosted: Sat May 28, 2016 6:12 pm    Post subject: Re: Rob's '63 Rag thread Reply with quote
Thanks Grandpa, that's just Rustoleum hammered silver.
1969 Empi Imp #1325
1963 Ragtop Bug
EMPIImp69
PostPosted: Tue Jun 07, 2016 5:29 pm    Post subject: Re: Rob's '63 Rag thread Reply with quote
Picked up a NOS driver door. Will be using this one since its better than the other 2 driver side ones I have.
Started sanding it down, its in like perfect shape.
1969 Empi Imp #1325
1963 Ragtop Bug
Page 3 of 14
