What does a 50 year old transaxle need?
dbuche
dbuche is offline
PostPosted: Mon Apr 20, 2015 2:01 pm    Post subject: What does a 50 year old transaxle need? Reply with quote
Now that the weather isn't so nasty, my 65 project is finally moving along again.The pans are in and the chassis painted and now I need to think about reinstalling the transaxle. But before I do I am wondering if I shouldn't do more than just change the fluid. The car was a daily driver before I started the restoration. It ran great and had no problems shifting, so I don't think anything is wrong. That said, I'd feel like a fool if I put it back together only to have to take it out again because I neglected to take care of something a 50 year old transaxle would naturally need.
I do think putting in a new clutch would be smart, but because my car was converted to 12 volt I don't know what to buy.
thanks in advance
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Mon Apr 20, 2015 2:30 pm    Post subject: Reply with quote
Sounds like the engine is out so it should be easy to see what flywheel and clutch setup you have. Post a photo.
These transaxles are pretty robust and if they were never ran low on oil they will last a good long time. There's really no "user-maintenance" things to do except change the oil and the rubber axle boots (make sure that if you have split replacement boots on there, that they are installed with the seam off to the side and not straight up)
-Andy
lavo56
lavo56 is offline
PostPosted: Mon Apr 20, 2015 3:24 pm    Post subject: Reply with quote
While the tranny is out, check your motor mounts and the rubber boot the clutch and accelerator tubes go thru as they exit the chassis.
Steve
Eric&Barb
Eric&Barb is offline
PostPosted: Mon Apr 20, 2015 3:36 pm    Post subject: Reply with quote
Do you have the accelerator cable sheath in place?
http://www.thesamba.com/vw/forum/viewtopic.php?t=400171&highlight=accelerator+boden+tube
Good time to wander thru the parts manual and pick out all the pieces you are missing.
http://oacdp.org/type1part.html
Torsion bar rubber bushings 311 511 245 are probably pretty worn out if original.
How is the nose cone shifter bushing? A lot easier to replace now.
In Stereo, Where Available!
61SNRF
61SNRF is offline
PostPosted: Mon Apr 20, 2015 6:57 pm    Post subject: Reply with quote
All of the above and...
...check to see if the shift detent plugs are still in the trans and in good shape. They were made of plastic and totally fall out causing an oil leak when they get old like these have...
If they are still there, test their integrity by probing gently with a sharp pick to see if they crumble or flake apart. If so, you would want to replace them now when the trans is out...
http://vwparts.aircooled.net/Transaxle-Detent-Plug-Kit-3-Pack-p/5017.htm
There is also a fourth smaller one in the lower part of the gear carrier housing, have a look at it too for same reasons....
-Bruce
An ounce of prevention is worth a pound of cure.
dbuche
dbuche is offline
PostPosted: Wed Apr 22, 2015 5:52 pm    Post subject: What does a 50 year old transaxle need? Reply with quote
I'll look over those plugs and bushings this weekend. I did think about a new nose cone, but not about just that bushing or the ones for the torsion bars. The accelerator cable sheath seems ok.
Here is a pic of the clutch. Whoever modified it to 12 volt used a clutch made in Brazil. I want a new one from Germany if possible, though I don't know what to order.
Bret2094
Bret2094 is offline
PostPosted: Wed Apr 22, 2015 5:59 pm    Post subject: Re: What does a 50 year old transaxle need? Reply with quote
I don't see what's wrong with that one myself
Bret
1959 baja beetle ragtop( going back to Full body)
1959 beetle
1960 Beetle frame Custom buggy
1962 Karmann Ghia
1967 beetle( august 66, first car)
1967 beetle (parts car)
1977 Westfalia Camper
1972 Plymouth Duster
Just another 22 year old jackass who caught the bug, and lives by the motto " NO fatchicks allowed" , I've got too many cars as is (buses N/A)
Miklo
¡Chale!
Miklo is offline
PostPosted: Thu Apr 23, 2015 7:16 am    Post subject: Reply with quote
That brazilian Sachs is pretty decent clutch.
What havent seen mentioned is the input shaft seal... Another must on 50 year old transmission.
WagenKült
'55 Type1 "Ozma"
'70 Type2 "Hannah"
'66 Type1 "Charlotte" RIP
OG over Aftermarket!
Dr OnHolliday wrote:
As I remember it, lowriding was not one of the criteria that Adolf gave to Dr. Porsche...
Martin Southwell
Martin Southwell is offline
PostPosted: Sat Apr 25, 2015 2:16 am    Post subject: Reply with quote
Whilst you have the gearbox out, why not also change the input shaft seal? I always do, and helps prevent a contaminated clutch in future. Plus change the starter motor bush, which is a piece of cake to do at this stage, and costs little or nothing to do.
tasb Premium Member
The Distributor Distributor
tasb is offline
PostPosted: Sat Apr 25, 2015 7:03 am    Post subject: Reply with quote
Remove the starter and clean all the mating surfaces where it contacts the starter housing. Clean all the starter electrical connections and the wire contacts.
Roads Scholar & distributor restorations
1956 oval third owner 36 hp- slow drag Champion 2012, 2014, 2015, 2017
1957 Kombi low mileage 36 hp governor equiped M 178 Slow Drag Winner 2014, 2015, 2018
1960 sunroof beetle owned since 1991 36 hp
1965 hrdtop Deluxe Microbus owned since 1990 M 620 factory 12 v 1500cc
Eric&Barb
PostPosted: Sat Apr 25, 2015 7:23 am    Post subject: Reply with quote
Also grease up those surfaces to keep oxygen and thusly corrosion for as long as possible. Dielectric grease or bulb grease are best.
60's Burnout
60's Burnout is offline
PostPosted: Sat Apr 25, 2015 4:08 pm    Post subject: Reply with quote
2nd gear synchro? That's the first one to fail, since it gets the most use. But if you don't remember grinding the gears while it was running, you might pass on it. Only hard part to replacing it is the Belleville washer you have to compress to get the snap ring on or off the shaft.
bluebus86
Banned
bluebus86 is offline
PostPosted: Sat Apr 25, 2015 6:25 pm    Post subject: Reply with quote
before you re-install tranny, use a wire to clear open the breather hole near the top. it is often clogged with grime. a clogged breather can cause leaks at seams/seals. if you want, clean up the case and paint it, the magnesium case is pretty reactive to chemicals an salt, a coat of paint will help reduce corrosion. a nice thin coat of matt black would look good and be protective.
dbuche
dbuche is offline
PostPosted: Thu Apr 30, 2015 6:28 am    Post subject: What does a 50 year old transaxle need Reply with quote
Thanks for al the tips.
I am ordering all the seal and gasket kits and all plugs and bushings, but I haven't found the smaller detent plug yet.
laststarfighter
laststarfighter is offline
PostPosted: Sun Jan 10, 2021 7:01 am    Post subject: Re: What does a 50 year old transaxle need? Reply with quote
Being an old thread, I'm afraid no one is looking at it. But if so can anyone help me find the location of the breather hole near the top mentioned? Thank you I have a 71 Super Beetle.
67rustavenger Premium Member
67rustavenger is offline
PostPosted: Sun Jan 10, 2021 7:19 am    Post subject: Re: What does a 50 year old transaxle need? Reply with quote
Starting on the right side of the image above.
First section is the nose cone.
Second is the gear carrier, I think!
The breather hole is on top of the gear carrier section. That is if my memory serves me correctly.
See the correct answer below. Embarassed
61SNRF
61SNRF is offline
PostPosted: Sun Jan 10, 2021 8:54 am    Post subject: Re: What does a 50 year old transaxle need? Reply with quote
It's the smaller hole in the top center of the nosecone...
-Bruce
Cusser
Cusser is offline
PostPosted: Sun Jan 10, 2021 12:38 pm    Post subject: Re: What does a 50 year old transaxle need? Reply with quote
A birthday party !!!!
I gave my 1970 a 50th birthday party last year !!!!
1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2005 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297
laststarfighter
PostPosted: Sun Jan 10, 2021 8:05 pm    Post subject: Re: What does a 50 year old transaxle need? Reply with quote
Thank you SNRF61 for the picture of the breather hole location.
While cleaning the transmission out of the car today, I found another mystery hole on the driver's side transmission side cover at the top. There was not one on the other side. The hole was almost completely clogged. and I started to clear it with a pick but wondered if I might be damaging some type of screen inside. Any ideas on what this hole is and if I should try to clear it somehow?
shows the cover plate and a close up of the hole is
Thank you[/img]
61SNRF
61SNRF is offline
PostPosted: Mon Jan 11, 2021 7:16 am    Post subject: Re: What does a 50 year old transaxle need? Reply with quote
@laststarfighter
That hole is an unused part of the casting and not drilled through. If it were there would be a big trail of oil leaking from it.
You're safe to move ahead with your cleaning job Wink
-Bruce
