58Dub Samba Member
Joined: June 02, 2004 Posts: 1713 Location: Davison, MI
Posted: Sun Dec 27, 2015 3:53 pm Post subject: CB 36hp doghouse shroud |
does anyone know if CB has the directional fins inside their 36hp doghouse shroud? _________________ 58 Beetle (now just a pile of parts in the corner)
60 Beetle (2221 turbo under construction)
70 Beetle Baja project |
Dan Ruddock Samba Member
Joined: October 25, 2012 Posts: 3594 Location: Sarasota, in my adopted state of Florida
Posted: Sun Dec 27, 2015 4:21 pm Post subject: Re: CB 36hp doghouse shroud |
Why not just find a OG 36hp shroud. Mine is working very good.
Dan |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Sun Dec 27, 2015 4:43 pm Post subject: Re: CB 36hp doghouse shroud |
58Dub wrote: |
does anyone know if CB has the directional fins inside their 36hp doghouse shroud? |
Have you asked them?
[email protected]
Monday - Friday 8am-5pm PST
1-800-274-8337 (outside CA)
1-559-733-8222 (CA only) _________________ Glenn
Member #1009
#BlueSquare |
58Dub Samba Member
Dan Ruddock wrote: |
Dan |
Dan do you run an oil cooler in the shroud? I didnt know an actual 36hp shroud would fit on a 1600 type _________________ 58 Beetle (now just a pile of parts in the corner)
Posted: Sun Dec 27, 2015 5:07 pm Post subject: Re: CB 36hp doghouse shroud |
Yes it will fit. The cooler is in place but has no oil in it. It has a external cooler with a oil stat on it.
Dan |
58Dub Samba Member
Posted: Sun Dec 27, 2015 5:14 pm Post subject: Re: CB 36hp doghouse shroud |
Glenn wrote: |
58Dub wrote: |
[email protected]
1-559-733-8222 (CA only) |
Thanks Glenn... im aware of their hours, just thought Id see what the folks on the forum say _________________ 58 Beetle (now just a pile of parts in the corner)
58Dub Samba Member
Posted: Sun Dec 27, 2015 5:16 pm Post subject: Re: CB 36hp doghouse shroud |
Dan |
thanks Dan
I guess Id just need to find a way to mount the place holder cooler in it _________________ 58 Beetle (now just a pile of parts in the corner)
tattooed_pariah Samba Member
Joined: April 24, 2006 Posts: 2047 Location: El Cajon, CA
Posted: Sun Dec 27, 2015 5:44 pm Post subject: Re: CB 36hp doghouse shroud |
58Dub wrote: |
Dan |
thanks Dan
I guess Id just need to find a way to mount the place holder cooler in it |
if you aren't running oil through it, why leave it in place? block off plates are cheap.. _________________ -pariah (just a novice from "that other VW site")
'72 Volksrod "Effigy"
"Never worry about stepping on people's toes. People who get their toes stepped on are either sitting down, or standing still on the job."
-Admiral Arleigh Burke, USN(ret.) |
58Dub Samba Member
Posted: Sun Dec 27, 2015 5:46 pm Post subject: Re: CB 36hp doghouse shroud |
tattooed_pariah wrote: |
58Dub wrote: |
Dan |
thanks Dan
if you aren't running oil through it, why leave it in place? block off plates are cheap.. |
I thought it was used to help direct the air in a non doghouse shroud _________________ 58 Beetle (now just a pile of parts in the corner)
Todd66 Samba Member
Posted: Sun Dec 27, 2015 7:04 pm Post subject: Re: CB 36hp doghouse shroud |
I don't know about CBs, but I know the scat shroud does. If it helps. |
Todd66 Samba Member
Posted: Sun Dec 27, 2015 7:05 pm Post subject: Re: CB 36hp doghouse shroud |
mark tucker Samba Member
Posted: Sun Dec 27, 2015 7:20 pm Post subject: Re: CB 36hp doghouse shroud |
if it's a dogystyle shroud you put the cooler outside in the doghouse it wont fit inside. |
58Dub Samba Member
Posted: Sun Dec 27, 2015 7:26 pm Post subject: Re: CB 36hp doghouse shroud |
mark tucker wrote: |
yep, got it Mark... Dan had mentioned to use a stock VW 36 shroud. Since that had a cooler in the shroud stock, I wasnt sure if you could run one without it in there and not mess up the cooling. _________________ 58 Beetle (now just a pile of parts in the corner)
Posted: Sun Dec 27, 2015 8:52 pm Post subject: Re: CB 36hp doghouse shroud |
Yes needs to be there for correct airflow. If removed the cylinders get more air and heads get less (not good). With hot oil in it the air get heated before it is used to cool the heads/cylinders also not ideal. I also as you can see I gutted the cooler but the screen is there, the cooler had balooned so I cut away the tubes.
Dan
[/img] |
58Dub Samba Member
Posted: Sun Dec 27, 2015 9:10 pm Post subject: Re: CB 36hp doghouse shroud |
Thanks Dan... what size engine are you using it on? _________________ 58 Beetle (now just a pile of parts in the corner)
Posted: Sun Dec 27, 2015 9:16 pm Post subject: Re: CB 36hp doghouse shroud |
Beehive 1835 with stage 2's and IDA's
Dan
[/img] |
58Dub Samba Member
Posted: Mon Dec 28, 2015 5:00 am Post subject: Re: CB 36hp doghouse shroud |
Looks great, Dan. Nice work. _________________ 58 Beetle (now just a pile of parts in the corner)
dsrtfox Samba Member
Posted: Mon Dec 28, 2015 10:03 am Post subject: Re: CB 36hp doghouse shroud |
Is that the engine for the 356 in your photo ? |
Posted: Mon Dec 28, 2015 10:59 am Post subject: Re: CB 36hp doghouse shroud |
dog house shroud in the thread title......you cant put the non dogystyle cooler in the dogystyle shroud. but if you add the "doghouse" to the non dogystyle shroud yes you need to do some finnage work. .....but why? just use a shroud made to do so. I personaly dont see that choped up mess of a old cooler doing anything execpt for another mess of things..or if not using the inside or dog cooler just use the dogystyle shroud and block it off so it dose flow air where the cooler was in the doghouse. shrouds are cheep engines are not. ...or add fins to the non dogyshroud to be like the dogy shroud. not that hard but not that eazy either. a old dogystyle shropud could be used to either get the peices out of or...remove the rear portion of both&transfer it.(some good working skills needed to do this right. ) |
Posted: Mon Dec 28, 2015 11:06 am Post subject: Re: CB 36hp doghouse shroud |
Yes the motor is now running in my 356 but only temporarly until I can assess the performance of the beehive valve springs, then the 1904cc 356 engine will go back in the car to prep it for sale.
So far I have taken it to 6500 with no signs of float and soon I will take it to 7100 after I do some more fine tuning.
Dan |
