To All You Radio Installers, Need Some Guidance
houseofboyd
houseofboyd is offline
PostPosted: Mon Dec 28, 2015 8:04 pm    Post subject: To All You Radio Installers, Need Some Guidance Reply with quote
Ok, my '68 Beetle has never had a radio installed. After months of looking, I found a period correct Ranger by Tenna. This is the radio that would be installed at the dealership for around 80 bucks. This is a NOS radio in new condition, so I'm pleased. I'm no electronics guru, so I'm hoping somebody can help with the install. I know the obvious, black wire from the case is ground, blue wire with inline fuse is the hot wire and the other black wire is the internal light (I'll jump off the speedo light for that)...the thing with the blue wire in the lower right corner of the pic, what is that and where does it go? Any input is appreciated... Smile
Our 1968 Zenith Blue Beetle: http://www.thesamba.com/vw/forum/viewtopic.php?t=619501
My '74 SB Build On The Samba: http://www.thesamba.com/vw/forum/viewtopic.php?t=609943
Our Web Site: http://www.kentuckyhotwheels.com
1968 VW Beetle
2012 Turbo VW Beetle
cletus_zuber
cletus_zuber is offline
PostPosted: Mon Dec 28, 2015 8:46 pm    Post subject: Re: To All You Radio Installers, Need Some Guidance Reply with quote
That is a noise suppressor. I've seen pics of those mounted at the generator, the coil or at the radio itself. Goes inline with the power wire I believe.
Kadrons & 019
vwfreek61
vwfreek61 is offline
PostPosted: Mon Dec 28, 2015 8:48 pm    Post subject: Re: To All You Radio Installers, Need Some Guidance Reply with quote
Looks like a noise suppressor for the generator. or ignition. There was one on my Type 3 Squareback bolted to the generator, but I don't remember exactly where the wire was connected.
Kenneth
1964 Bug with Saxomat
1976 VW/Harley Trike Autostick
1987 Vanagon Westy w/2.0 ABA
houseofboyd
PostPosted: Mon Dec 28, 2015 8:57 pm    Post subject: Re: To All You Radio Installers, Need Some Guidance Reply with quote
Thanks for the replies. I'm assuming it goes on the coil wire. The connector on the end looks as if it "wraps" around the coil wire.
Any more input is appreciated...
1968 VW Beetle
houseofboyd
PostPosted: Mon Dec 28, 2015 9:21 pm    Post subject: Re: To All You Radio Installers, Need Some Guidance Reply with quote
I'm assuming something like this...
1968 VW Beetle
air-h2o-air
air-h2o-air is offline
PostPosted: Mon Dec 28, 2015 9:33 pm    Post subject: Re: To All You Radio Installers, Need Some Guidance Reply with quote
try radio without it first...If you dont need the noise choke...leave it off
and if radio is period correct...don't forget to adjust antenna trimmer
houseofboyd
PostPosted: Mon Dec 28, 2015 9:34 pm    Post subject: Re: To All You Radio Installers, Need Some Guidance Reply with quote
Thanks...will do! Plan to install it this weekend.
1968 VW Beetle
windfish
windfish is offline
PostPosted: Mon Dec 28, 2015 9:39 pm    Post subject: Re: To All You Radio Installers, Need Some Guidance Reply with quote
Yep, noise suppressor.
The diagram below suggests it was used to buffer the turn signal, at least for that Sapphire model; that clamp on the end could wrap around the terminal at the relay?
http://www.thesamba.com/vw/archives/manuals/sapphirev/diagram.jpg
I believe I've still got one on my bug, if you're curious I'll follow the wire and see how it's attached. Looks like the above used a split terminal.
houseofboyd
PostPosted: Mon Dec 28, 2015 9:43 pm    Post subject: Re: To All You Radio Installers, Need Some Guidance Reply with quote
Was looking for a diagram like that...thanks a bunch!
1968 VW Beetle
Cusser
Cusser is offline
PostPosted: Tue Dec 29, 2015 6:47 am    Post subject: Re: To All You Radio Installers, Need Some Guidance Reply with quote
Is that radio just AM like the Saph in my 1970 was? That suppressor may just help for AM stations and not be needed if you do only FM.
1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2005 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297
houseofboyd
PostPosted: Tue Dec 29, 2015 7:17 am    Post subject: Re: To All You Radio Installers, Need Some Guidance Reply with quote
Yes, just an AM radio. I just got it for aesthetics, but I still want it to work decently...I currently use my phone and bluetooth speaker for tunes when I'm driving around...Going to try it without the suppressor first to see if it's actually needed...
1968 VW Beetle
houseofboyd
PostPosted: Thu Dec 31, 2015 8:28 am    Post subject: Re: To All You Radio Installers, Need Some Guidance Reply with quote
Part 1 of the radio install completed...
http://kentuckyhotwheels.com/2015/12/vintage-radio-install-part-i/
1968 VW Beetle
