Clara Samba Member
Posted: Mon Dec 28, 2015 10:43 pm Post subject: Cleaning out heater tube with a shop vac |
Used a shop vac to clear a heat tube today. The heat flow out the front was minimal to nil, and the inside of the windshields was fogging up.
The hose fit nicely to the 67 tube.
I wish I took a video of it sucking down the mouse nests, the vac hose looked like a snake gulping down several angry mice.
The can was empty when I started
Next moved the hose over to the other connection on the vac so it blew the air forward through the heater tube. I put a T-shirt on the dash vents so the garbage would blow onto the floor. I connected another tube to suck up the little bits of detritus in the cab, then turned the shop vac back on. Now it had good flow! Not too much stuff came out of the heat vents, just some small bits of fluff and plants.
Last reconnected the heater pipe, and indeed the engine blew air nicely at the windows!
It barely blew any garbage into the bus, the shop vac had got 99.99% of it. _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
crukab Samba Chef
Joined: December 13, 2002 Posts: 6116 Location: Vermont
Posted: Tue Dec 29, 2015 4:54 am Post subject: Re: cleaning out heater tube with a shop vac |
Ahhh The Jersey Looker, should be a good amount of trailbash dirt under that Bad Bus. _________________ Tom
My Pops:
In the yard right now:
'51 Dodge 5 window truck
'65 Bug
'66 Singlecab
'82 Rabbit Truck Diesel from CALI
'86 Doublecab W/T
'88 Dodge Ram pickup
'11 Jetta Wagon |
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9789 Location: Exit 7, New Jersey
Posted: Tue Dec 29, 2015 6:20 am Post subject: Re: cleaning out heater tube with a shop vac |
Jersey Looker getting some love.
Maybe you could mount up the Cragars? _________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all! |
campingbox Samba Member
Joined: November 14, 2000 Posts: 10196 Location: Petaluma, CA
Posted: Tue Dec 29, 2015 8:14 am Post subject: Re: cleaning out heater tube with a shop vac |
j.pickens wrote: |
Maybe you could mount up the Cragars? |
And pull them off the kombi? |
Clara Samba Member
Posted: Tue Dec 29, 2015 8:56 am Post subject: Re: cleaning out heater tube with a shop vac |
crukab wrote: |
Ahhh The Jersey Looker, should be a good amount of trailbash dirt under that Bad Bus. |
There was something falling in my eye when I was removing that right side heater tube. _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
motofly196 Samba Member
Joined: June 01, 2008 Posts: 1467 Location: Eastern WA
Posted: Wed Dec 30, 2015 12:06 pm Post subject: Re: cleaning out heater tube with a shop vac |
That's a great idea Clara! I tried vacuuming the heater tubes out with my Single, but it wouldn't work. I ended up running water through mine to get all the gunk out. I jacked up the front and ran a garden hose from under the dash (engine out). I also had to bleach run bleach in there to get the "dead" smell out of the tubes. Followed by an air hose with the gun handle zip-tied to clear all the water out. Smells good when the heater is on now. I got a few carcasses out of it, and ALL of the coconut husk seat material!! |
brettsvw Samba Member
Joined: November 22, 2007 Posts: 2145 Location: Florida
coolerthanelvis Samba Member
Joined: June 30, 2003 Posts: 924 Location: San Diego, CA
Posted: Wed Dec 30, 2015 2:47 pm Post subject: Re: cleaning out heater tube with a shop vac |
motofly196 wrote: |
On commercial buses, both of the heater boxes connect to the center tube, so if you want to vacuum it out you'll have to block off the other heater box connection. _________________ Shawn
SV2s member #420
'68 Westy
"Do or do not, there is no try."
-Silent Bob |
Stocknazi Samba Member
Posted: Wed Dec 30, 2015 4:06 pm Post subject: Re: cleaning out heater tube with a shop vac |
If you can't get all the crap out of the tube with a shop vac, try using a leaf blower connected to the tube. Really makes a mess up front, but really gets the air moving. _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
Clara Samba Member
Posted: Wed Dec 30, 2015 10:38 pm Post subject: Re: cleaning out heater tube with a shop vac |
coolerthanelvis wrote: |
motofly196 wrote: |
On commercial buses, both of the heater boxes connect to the center tube, so if you want to vacuum it out you'll have to block off the other heater box connection. |
True that. This was a 13 window, if it was a kombi I'd have had to block off the other part of the Y.
I've had to roto rooter out heater tubes before, with a clutch cable on a drill, but this time maybe it was loosely packed and the shop vac just sucked out the blockage.
It was really quick. Luckily, there was no nasty smell.
The earlier buses if you jack the front up you can put a hose into the center tube and wash it out the back easily enough, but that's a bit trickier with the later bus with the heater grills. _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
mattcuddy Samba Member
Joined: October 22, 2003 Posts: 2036 Location: Philly, PA
Posted: Wed Jan 06, 2016 11:10 am Post subject: Re: Cleaning out heater tube with a shop vac |
Clara wrote: |
Last reconnected the heater pipe, and indeed the engine blew air nicely at the windows! |
Heat?!?! You spoil me. Next time I see this bus it'll be like driving a Lexus. |
73sports Samba Member
Joined: September 26, 2004 Posts: 2107 Location: Warrington, PA
Posted: Thu Jan 07, 2016 11:58 am Post subject: Re: Cleaning out heater tube with a shop vac |
Funny, I was just thinking that of all the things that could be done to this bus after arriving in the bus Mecca of the PNW; improved heat flow would have been lower on the list. _________________ I will never lie, but sometimes the truth changes.
Central Jersey VW Society |
BonTonRoulet Samba Member
Joined: September 29, 2020 Posts: 360 Location: Mississippi
Posted: Thu Dec 01, 2022 8:45 am Post subject: Re: Cleaning out heater tube with a shop vac |
A shop vac might work, but a Stihl gas powered leaf blower will definitely work here. You can even have the shop vac hose hooked up to the rear of the heater tubes and blow through the rear cargo "log" and the front windshield vents/cab vents with the leaf blower at the same time.
Now, a trick I recently thought of and implemented, if you aren't going to hook the heater mufflers/flexible hose/heat exchanger of your engine system in your bus for a while and want to deter rodents or anything else that might venture into places from those connections at the rear of the chassis, a tennis ball is your answer.
1) Take a tennis ball. Preferably one declared "dead" by your neighbor the tennis player. Apparently, tennis balls have a very short life span for their intent before being thrown to a dog, or in this case, a neighbor with a split window VW bus.
2) Drill a hole in the tennis ball. Now it can be collapsed in your hand and you can drill another hole about an inch or so away from the first hole by putting the drill through the first hole and drilling the other hole from the inside of the ball out.
3) Using a pair of forceps/hemostats/favorite roach clip slip the forceps through the holes in the ball, grab a nice sized zip tie with them then pull the zip tie back through the ball and out.
4) Connect the ends of the zip tie together but don't pull it tight, rather use it as a pull loop.
5) Compress the tennis ball with your hand zip tie loop out and jam it into the heater tube in the rear of the chassis of your bus.
6) Marvel at your accomplishment knowing you have defeated the potential varmints and anything else that would make yet another home in your heater tubes. _________________ Never argue with an Idiot. They'll only bring you down to their level and beat you with experience. |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14258 Location: Casa de Oro, California
Posted: Thu Dec 01, 2022 6:55 pm Post subject: Re: Cleaning out heater tube with a shop vac |
^^^ So the zip tie loop is so you can remove it later? |
Posted: Thu Dec 01, 2022 7:39 pm Post subject: Re: Cleaning out heater tube with a shop vac |
Absolutely! The zip tie makes for an easy pull handle to get the ball out of the tube, and the tennis ball without a hole to effectively deflate it really was too tight to fit. _________________ Never argue with an Idiot. They'll only bring you down to their level and beat you with experience. |
Clara Samba Member
Posted: Sat Dec 03, 2022 12:04 pm Post subject: Re: Cleaning out heater tube with a shop vac |
I went with the shop vac rather than blow so to not throw detritus into the bus. Generally if I just hook up the heat a lot of stuff blows into the cab.
Before heat the windshields did not defog. This a visibility issue in damp climates. After I hooked up the heat, the glass cleared of moisture This made it much easier to see, nicer to drive.
Mice climb through front heater vents. They take seat stuff and put it into the main heater tube and nest there as well as under the front seat. So. Turn the heat to defrost on the project bus? _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
Bruce Amacker Samba Member
Joined: December 26, 2007 Posts: 1786 Location: Cleveland, Ohio
RWK Samba Member
Posted: Mon Dec 05, 2022 6:02 am Post subject: Re: Cleaning out heater tube with a shop vac |
Yes on the clean-out! I did a 71 bus that had very little air flow, opened the clean out and stuck a heavy wire back towards the front beam, used vacuum and the wire with a hook, clog was at the thinned down section that goes over the beam, most of the crap was insulation that shed from from flex heater tube connector, filled a gallon zip lock bag. _________________ 73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530 |
