bikinijack Samba Member
Joined: December 30, 2015 Posts: 11 Location: Marshall Islands
Posted: Wed Dec 30, 2015 7:16 pm Post subject: Immobilizer issue - 1999 Mexican Beetle |
I just had a 1999 VW bug built in Mexico shipped to me in the Marshall Islands. It is now the only bug in the entire country.
When they shipped it from Japan they unhooked the battery cables. When they went to get the bug off the ship here they hooked up the battery cables, jumped the car, it started right up and they drove it to customs area.
However, when we went to pick it up we didn't understand about the little dashboard key for the immobilizer. So we were disconnecting and reconnecting the battery, etc. trying to figure out how to start the car. Then we realized what the immobilizer key was all about. The problem was even when we put that key in, the car still will not start.
The starter turns over but no power is getting to the engine. I am told that I have to find a way to either reset the immobilizer or disable it altogether. Can someone advise us how to do this procedures (I have a very good mechanic). Any other suggestions would be helpful. |
busdaddy Samba Member
Posted: Wed Dec 30, 2015 7:28 pm Post subject: Re: immobilizer issue |
bikinijack wrote: |
I just had a 1999 VW bug built in Mexico shipped to me in the Marshall Islands. It is now the only bug in the entire country.. |
Congratulations!
No 2 immobilizers are the same and how they are installed is entirely dependant on the whim of the installer, your first step is to find out what brand and model it is and download the installation instructions from the interwebs. Or in a worst case scenario find out where it's joined to the black wire from the ignition switch, get rid of it and reconnect the black wire together so it'll run. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Antonio Trejo VW Parts Dealer
Joined: December 17, 2003 Posts: 937 Location: Mexico City
Posted: Wed Dec 30, 2015 8:59 pm Post subject: Re: immobilizer issue |
Yes, that is exactly what they look like... |
hopkin Samba Member
Joined: June 25, 2012 Posts: 2480 Location: Ottawa, Ontario
Posted: Wed Dec 30, 2015 9:18 pm Post subject: Re: immobilizer issue |
Here are instructions on how to bypass the immobilizer:
http://www.1600i.de/1600i-elektronik/Wegfahrsperre-ultima/immobiliser.html _________________ 1971 Super Beetle (past)
1974 SunBug (past)
1972 914 (past)
1991 Honda Civic (Original Owner)
1996 'Open Air' Mexican Beetle (current)
2015 Golf (current)
2017 Dune Edition (daughter's car) |
Posted: Wed Dec 30, 2015 10:28 pm Post subject: Re: immobilizer issue |
Thanks Hopkin, but my unit is like the one in the picture above that Antonio posted. it does not use the red and black transponders, it has a key (as pictured) and the immobilizer box is exactly like the one in his picture and different than the one you suggested on the 1600i.de site. but thanks so much for responding! |
Posted: Fri Jan 01, 2016 1:06 pm Post subject: Re: immobilizer issue |
Any other suggestions? |
Posted: Fri Jan 01, 2016 8:07 pm Post subject: Re: immobilizer issue |
who but who can tell me *exactly* how to either reset or disable the immobilizer for a 1999 VW bug built in Mexico? |
hopkin Samba Member
Posted: Fri Jan 01, 2016 8:57 pm Post subject: Re: immobilizer issue |
Antonio Trejo wrote: |
I want to forget about the one year only (1997) remote alarm system. The device was too sloppy. |
That's the one that was in my '96. I modified the module so that it permanently bypasses the immobilizer (using the instructions on 1600i.de).
(I jumped the terminals inside the module to give the appearance that the module is installed, rather than a wire jumped across the terminals).
Not the answer to your question, but this pdf on 1600i.de has the schematics for your alarm system (section 13).
http://www.1600i.de/download/Mexican-Beetle-Circuit-Diagram.pdf
I found this thread about mk3 & mk4 immobilizers, maybe something helpful here:
http://www.myturbodiesel.com/wiki/immobilizer-faq-...ment-tips/ _________________ 1971 Super Beetle (past)
1974 SunBug (past)
1972 914 (past)
2015 Golf (current)
Posted: Mon Jan 04, 2016 8:55 pm Post subject: Re: immobilizer issue |
This is the immobilizer in my beetle, any help would be appreciated. We've tried all kinds of tricks with the battery, etc., but no power is getting to the engine.
Posted: Mon Jan 04, 2016 9:27 pm Post subject: Re: immobilizer issue |
Antonio, I checked the PM, nothing there, please send again. many thanks. |
Posted: Thu Jan 07, 2016 6:24 pm Post subject: Re: immobilizer issue |
We rewired the immobilizer so that it is bypassed but the car is still not getting power to the engine... What could this be? Any ideas? |
Bruce Samba Member
Posted: Fri Jan 08, 2016 2:58 am Post subject: Re: immobilizer issue |
bikinijack wrote: |
The starter turns over but no power is getting to the engine. |
When you say no power is getting to the engine, does that mean there is no spark? Or that the injectors aren't delivering fuel?
You have this type of immobilizer fob, right?
[/URL]
When you plug it into the socket in the dash, does the red light stop flashing? _________________
Posted: Fri Jan 08, 2016 3:44 pm Post subject: Re: immobilizer issue |
Yes, Bruce, that is the fob we have. We put the fob in and the red light stops blinking. There is just no power getting to the engine, the fuel
Is being injected. |
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Fri Jan 08, 2016 4:12 pm Post subject: Re: immobilizer issue |
bikinijack wrote: |
Recheck ALL wiring. Sounds like something was missed. |
