cjargo Samba Member
Posted: Sun Nov 13, 2016 11:42 pm Post subject: Re: Assembly required - '63 Vert Bug - Buildup. |
Here is Strato's first lube. The guys at the shop flipped out when they saw the car then took photos, did the job, and didn't charge me. To even the generosity, a couple of large pizzas will be anonymously delivered this week.
Next week I'll update everything that been done since my last post.
_________________ '63 Vert. Bug - '58 Bug Ragtop RHD - '63 Vert. Bug -
'78 911 SC Targa - '69 911 E - '57 Vert. Porsche - '84 GTI - '69 Bus - '57 Bug - '68 Bug / Sunroof -
'65 Bug - '63 Bug - '74 Bus - '72 Karmann Ghia
'67 Bus / Sundial - '59 Karmann Ghia |
cjargo Samba Member
Posted: Fri Nov 25, 2016 1:20 am Post subject: Re: Assembly required - '63 Vert Bug - Buildup. |
Here's what Strato has been up to..... Tomorrow will be the last of the rollup windows.
zabo Samba Member
Posted: Sun Nov 27, 2016 7:22 pm Post subject: Re: Assembly required - '63 Vert Bug - Buildup. |
cjargo wrote: |
the build is amazing -but i am confused after all this why you took it to a shop for an oil change _________________ 1960 6 volt sedan- 1978 adventurewagen
–wanted bill spreen atlanta dealer tag frame |
cjargo Samba Member
Posted: Sun Nov 27, 2016 11:41 pm Post subject: Re: Assembly required - '63 Vert Bug - Buildup. |
zabo wrote: |
cjargo wrote: |
the build is amazing -but i am confused after all this why you took it to a shop for an oil change |
Thanks for the kind words on the build. Strato was there for a lube only. Oil changes are done at home. If you're alluding to the fact that this place doesn't sell oil with high enough levels of zinc and phosphorous, which our solid engines are designed for, I hear ya. But that's a separate topic on a different form. Cheers. _________________ '63 Vert. Bug - '58 Bug Ragtop RHD - '63 Vert. Bug -
cjargo Samba Member
Posted: Mon Nov 28, 2016 1:16 am Post subject: Re: Assembly required - '63 Vert Bug - Buildup. |
Today was was the last of the roll up windows to be installed. BIG DAY. I never would have guessed the door windows on a vert have around 150 parts per door. I'm thankful for the Bentley VW bible and to Bob for his selfless help. Thanks! Onto some progress....
Old vent window weather stripping & OG Aluminium bar.
New rubber & philips screws then polished OG aluminium insert.
Passenger rear window detail. Rechromed frame, new rubber, pre channel clean up and final assembly. Next week I'll post a done picture.
OG screws and washers. BEFORE
AFTER / Zinc plated. This is probably the only time anyone will ever see these.
Same window installed and sealed.
Original top door jam seal (right) new (left). If someone wants the original one let me know.
Arm rest detail. Cleaned up then painted the arm rest with a satin black interior paint. The scratched up aluminium molding was sanded with a wet 1200 grit and metal polish then buffed out on a proper buffing wheel.
Here it is almost finished, just needs assembly. Turned out ok.
cjargo Samba Member
Posted: Mon Dec 05, 2016 12:20 am Post subject: Re: Assembly required - '63 Vert Bug - Buildup. |
Only one day to work on Strato this week so was only able to trim then installed the front & rear rubber floors mats from WW, plus start to install the driver side carpet. The carpet around the front drivers side speaker pod and heater vent still needs a bit more fitting. Oh yeah, also installed a cool emergency brake combo lock that fits on the button end of the hand brake, which works by setting the E-brake, then spin the 3 tumblers, thus not allowing the emergency button to be depressed unless you put in the 3 digit tumbler code. Great security device.
grandpa pete Samba Member
Posted: Mon Dec 05, 2016 2:27 pm Post subject: Re: Assembly required - '63 Vert Bug - Buildup. |
cjargo wrote: |
installed a cool emergency brake combo lock that fits on the button end of the hand brake, ] |
Never heard of or saw one of these before ; Where did you find it ?.....How much was it ????
thks _________________ 63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery |
cjargo Samba Member
Posted: Mon Dec 05, 2016 5:44 pm Post subject: Re: Assembly required - '63 Vert Bug - Buildup. |
grandpa pete wrote: |
cjargo wrote: |
thks |
Hey there GP! The short version is: "Me neither, in a box of VW parts, and it was free."
Long version:
A friend dropped off 3 boxes full of random VW tools & parts which he cleaned out from his dads garage of 50 years, and the E-lock was one of the items. There isn't any markings or manufacturer info anywhere. Initially I thought it was a one off since his dad was a fabricator, but then a few months ago a (WTB) post popped up which had a photo of the same E-lock so they are out there. This would be a cool item for WW to knock off and sell as a theft deterrent. _________________ '63 Vert. Bug - '58 Bug Ragtop RHD - '63 Vert. Bug -
GB2S Samba Member
Posted: Sat Dec 10, 2016 9:52 am Post subject: Re: Assembly required - '63 Vert Bug - Buildup. |
How did you cleanup the gas cap? Looks amazing.
Geoff _________________ 1963 Ragtop |
cjargo Samba Member
Posted: Sat Dec 10, 2016 10:31 am Post subject: Re: Assembly required - '63 Vert Bug - Buildup. |
GB2S wrote: |
Geoff |
Thanks, yeah it was worked a bit. A buffing wheel with a number 3 then 1 compound using gentle pressure. Letting the compound do the work is key otherwise the edges may get rounded. Next degreased it, sprayed adhesion promotor, then shot a few coats of gloss clear with UV protection. For a more original finish a semi gloss or a flat clear would do the trick. Without the clear it will tarnish within a week. _________________ '63 Vert. Bug - '58 Bug Ragtop RHD - '63 Vert. Bug -
cjargo Samba Member
Posted: Mon Dec 12, 2016 1:29 am Post subject: Re: Assembly required - '63 Vert Bug - Buildup. |
CARPET OVER RUBBER FLOOR MATS.
Even though the carpet is a amateur install at best, they aesthetically looked better than the rubber floor mats that I started with. The carpets will be a redo due to a thread run from one of the seat belt bolts, but they'll be fine for now. Eventually they will be replaced with a very dark blue (almost black) wool carpet, that's if I can ever find it.
SPEAKERS
All the silver was blacked out on the grills and tweeter bezels. The bezel before and after picture is below. It's a much simpler and cleaner look in the foot wells.
3 POINT SEAT BELTS.
The retractor is a bit chunky towards the back of the doors, but the safety factor out weighs the aesthetics. Seems like a good product from Retro Belts USA.
E-BRAKE COMBO LOCK.
Hey GP, this picture is for a better look. It's held on with 2 hidden allen set screws.
Since the door sills need some desperate clean-up, I'll be on the hunt this week for stainless steel door sills.
LEFT TWEETER BEZEL IS BLACKED OUT.
cjargo Samba Member
Posted: Sun Dec 18, 2016 1:48 am Post subject: Re: Assembly required - '63 Vert Bug - Buildup. |
Tomorrow the interior should be finished out then onto the top frame with installing the weatherstripping and wood. Fortunately all the old parts are accounted for which will be used if they are worthy, otherwise I'll dip into the new parts. Currently the top frame has been powder coated then assembled to some extent, all the original chrome parts were rechromed, then a full set of nuts bolts & washers in stainless steal are available if I need them. Plus a full set of new wood top parts, but since most of the old wood is in good shape I'll just be using just a few pieces. This will be my first top assembly so I'm a little nervous. Patience is key.....
cjargo Samba Member
Posted: Sun Jan 01, 2017 12:45 am Post subject: Re: Assembly required - '63 Vert Bug - Buildup. |
Here's the new plate... I originally requested "TYPE 151" which was taken along with every imaginable variation.
Wood is almost done, just the header left. After weatherstriping it's off to the top shop.
cjargo Samba Member
Posted: Tue Mar 07, 2017 12:03 am Post subject: Re: Assembly required - '63 Vert Bug - Buildup. |
After working 62 days straight, I finally have some time off and hope to finish the build with in the next month or two.
REAR VIEW MIRROR RESTORE
Seems like restoring a convertible mirrors is one of those tough DIY restore jobs - so here is a version that I hope will work for less than 20 bucks:
The results are amateur and I hope to have something looking better tomorrow
Pitted Chrome
1) Knock off old chrome and rust with a Fine File.
2) Sanded the same areas with 300, 600, and 1000 grit.
3) Polish aluminium and metal.
cjargo Samba Member
Posted: Tue Mar 07, 2017 11:33 pm Post subject: Re: Assembly required - '63 Vert Bug - Buildup. |
Here is the final pass on dolling up the steel and aluminium on the rear view with 1500 grit then a buffing wheel with metal polish.
Sharkhide keeps it from rusting or oxidizing.
Next restore the original mirror.
cjargo Samba Member
Posted: Fri Mar 10, 2017 12:23 am Post subject: Re: Assembly required - '63 Vert Bug - Buildup. |
Finished up silvering the original mirror. Soaking the mirror in acetone and using a 0000 steel wool helped remove the old chipped silvering. Then used Mirror effect from Rustolium to reapply the silvering back, which took 5 coats, and 20 minutes till dry completely. Then used a rubber hammer to bend the mirror frame around the original mirror. In the future I will polish the glass longer. The end result is fine for now.
SILL PLATES
Both WW and Chuck's convertibles have great looking sill plates. Since the Aluminium ones from Chuck's scratch easily, 3 coats of UV protection clear were applied then color sanded and polished. Both plates will be mounted together. Yes, there will be 2 sill plates per side. The WW lines match the running boards lines, and the WW pattern matches the silver patterned inserts in the center of the seats. The install pictures will be posted tomorrow.
WW Sill Plates
Chuck's Sill Plates
How they'll be assembled together.
luftkuhlers Samba Member
Joined: February 21, 2015 Posts: 94 Location: Germany
Posted: Fri Mar 10, 2017 1:04 am Post subject: Re: Assembly required - '63 Vert Bug - Buildup. |
great car and awesome work!!!
and thank you very much for posting the detailed worksteps.. |
cjargo Samba Member
Posted: Sat Mar 11, 2017 4:33 pm Post subject: Re: Assembly required - '63 Vert Bug - Buildup. |
luftkuhlers wrote: |
Thanks for the kind acknowledgement and you're welcome. I've learned more from the talented Samba community than I've given. So paying it forward is the least I can do.
Final Sill install.
The corners of the sills which curve up is a eye sore. So I'm in the process of fabricating a fibreglass facia to smooth out the look. You can see the facia pieces sitting on top of the seat. Still needs a bit more work.
jmarshall024 Samba Member
Joined: April 16, 2008 Posts: 127 Location: Hopedale, MA
Posted: Sat Mar 11, 2017 8:08 pm Post subject: Re: Assembly required - '63 Vert Bug - Buildup. |
Fantastic work on this! I have a 59 convertible. I hope I can someday do something similar to mine.
Do you have any threads showing the process you're using to restore these original parts to like new condition - i.e. tools used, rubbing compounds etc? |
vwnut1 Samba Member
Posted: Sun Mar 12, 2017 11:21 am Post subject: Re: Assembly required - '63 Vert Bug - Buildup. |
Beautiful!!!
Time to enjoy or on to the next VW project? To some the journey is more enjoyable than the destination:) _________________ 1957 VW Oval Resto Mod |
