ovsa Samba Member
Joined: January 17, 2016 Posts: 108 Location: alberta
Posted: Thu Feb 04, 2016 8:10 pm Post subject: Re: Lifted Eurovan with 16x7" rims |
sorry i hadn't seen your reply until just now.
i am going from VW stock 15" steel to 16" Audi aluminium.
thanks |
tds3pete Samba Member
Joined: April 04, 2004 Posts: 914 Location: Seattle, WA
Posted: Fri Feb 05, 2016 9:46 am Post subject: Re: Lifted Eurovan with 16x7" rims |
ovsa wrote: |
thanks |
I made the same switch and did not need longer lug bolts, centering rings or spacers. That's what's nice about an Audi wheel switch as opposed to many others. _________________ '58 Westy camper-come and gone
'73 Westy-bought new in Holland,now gone
'86 Syncro weekender-come and gone
'79 Westy...Oscar
'95 Eurovan Camper/5 spd...Marsha Mellow |
ovsa Samba Member
Posted: Thu Feb 25, 2016 5:23 pm Post subject: Re: Lifted Eurovan with 16x7" rims |
hi,
going to tackle the lift this weekend. I have all the gear:, 16" rims, tires, spacers, bilstiens and a home made 27mm x 6" deep socket.
Haven't crawl under the front yet to look at the torsion bar adjustments but before i do i was wondering:
I am tightening (cw or ccw? ) the 27mm nuts to raise the front equal to the back, right ? Do i use a level on the floor of the van on both axis. (front to back& side to side)? How does the string line/ tape measure deal work. I assume i need a nice level surface.
i have heard changing the torsion might put the cv's out of whack. How do i know if that has happened?
I am also going to replace tie rod ends. Should I go for a pro alignment after all that is done.
One more: what's your suggestion on the lift: 0.75 or 1.5"?. i made four .75 spacers so i can go either way.
Thanks alot |
Xtremjeepn Samba Member
Joined: October 21, 2012 Posts: 1539 Location: Colorado
Posted: Fri Feb 26, 2016 9:16 am Post subject: Re: Lifted Eurovan with 16x7" rims |
ovsa wrote: |
hi,
Crawling under the middle of the van will get you better results (The torsion bar adjusters are located behind the front row of seats)
ovsa wrote: |
Tightening raises the van.
I inflate all the tires to max to make sure there is no variations in them when sitting on level ground. Then just measure the fender lip, at the center of the wheel, at each corner. This will give you a pretty good idea what each corner is doing.
ovsa wrote: |
i have heard changing the torsion might put the cv's out of whack. How do i know if that has happened? |
The CVs can wear into a pattern over time. The lift simply changes the operating angle of the CVs and *can* expose a worn CV. They will make noise, click, grind, etc after trying to wear into a new grove.
The lifts seem to be fully within the operating range of the CVs. The issue is more of just exposing worn parts.
ovsa wrote: |
I am also going to replace tie rod ends. Should I go for a pro alignment after all that is done. |
That really depends on how good the alignment was to begin with. If your tires are wearing perfectly flat and you have no pulling/wandering or other handling issues then you can get way with measuring the new tie rod ends to be exactly the same length as the old ones and you will restore your existing alignment.
ovsa wrote: |
Thanks alot |
GO BIG OR GO HOME
....just kidding Its entirely up to you. I can say that I may stop making the .75" spacers because everyone just seems to order two sets to get 1.5". _________________ http://www.cavevan.com |
ovsa Samba Member
Posted: Fri Feb 26, 2016 11:16 am Post subject: Re: Lifted Eurovan with 16x7" rims |
thanks, great help.
just wondering; some people recommend adding more spacer on the driver's side to compensate for the extra weight of the camping gear in the EVC. Do you think using .75" on the passenger side and 1.5" on the other is a good idea or is it better to make up the difference using the torsion bar adjustments?
trying to stay away from doing this twice.
thanks again |
Posted: Fri Feb 26, 2016 7:06 pm Post subject: Re: Lifted Eurovan with 16x7" rims |
ovsa wrote: |
thanks, great help.
thanks again |
First you should see if your van leans.
Second, you should see if the torsion bars are adjusted equally.
Sometimes springs sag over time. So I'd swap the rear springs left to right IF you have a lean problem first. _________________ http://www.cavevan.com |
ovsa Samba Member
Posted: Fri Feb 26, 2016 9:01 pm Post subject: Re: Lifted Eurovan with 16x7" rims |
good idea, thanks |
ovsa Samba Member
Posted: Sat Feb 27, 2016 5:36 pm Post subject: Re: Lifted Eurovan with 16x7" rims |
I started putting the audi wheels ET 42 on the vehicle and i have a question.
everything lines up good but i notice the engagement from the hub to the rim is not that deep.
the rim sits flat to the wheel hub and the studs engage all the way but not sure if the hub collar (?) goes deep enough into the rims.
i measured and it is just under .500 of an inch. there is still .720 free space in the center bore. total depth of the cnter bore is 1.200
not sure if this is what it is suppose to look like so wanted to be sure before putting it on the road.
here is a photo so you have an idea of what i'm trying to explain
thanks again
Posted: Mon Feb 29, 2016 10:36 am Post subject: Re: Lifted Eurovan with 16x7" rims |
ovsa wrote: |
thanks again
That's normal. You are good to go. _________________ '58 Westy camper-come and gone
'79 Westy...Oscar
ovsa Samba Member
Posted: Mon Feb 29, 2016 10:38 am Post subject: Re: Lifted Eurovan with 16x7" rims |
Great, thanks |
jjvincent Samba Member
Joined: January 11, 2016 Posts: 1268 Location: Bethlehem, PA
Posted: Mon Feb 29, 2016 12:27 pm Post subject: Re: Lifted Eurovan with 16x7" rims |
Even to make you feel better, you don't even need a centering ring. It's there just to make it easier to mount your wheels. |
ovsa Samba Member
Posted: Tue Mar 01, 2016 5:16 pm Post subject: Re: Lifted Eurovan with 16x7" rims |
o. k. job complete. All i have to do right now is tweek the torsion bar to get it level and put on bigger tires (225/70) . I bought the rims with car tires on them
now i'm wondering if i didnt go too high. I have about 19 inches from wheel well lip to center of rear wheel. Used 1.5" spacers on each side. My concern is road stability.
What do you think?
Like the ground clearance though.
ovsa Samba Member
Posted: Wed Mar 02, 2016 1:23 pm Post subject: Re: Lifted Eurovan with 16x7" rims |
having a bit of a problem:
After installing the Bilstiens, 1.5" spacers on each side and the 16" rims i measure 18.75" from the fender lip to the center of the rear wheels.
I pretty much tightened the T-bar nuts as high as they'll go (i think, because i couldn't move them anymore with a 18" breaker bar.)I ended up with 16.5" on the drivers side and 17" on the passenger side.
I measured the amount of free threads on the adjusting stud: I get 3.25" on the drivers side and 3.0" on the passenger.
Either i don't have enough strength to keep turning those nuts or i am as high as i can go. It could be that the threads are gunked up too.
Not sure what i should to, take out 0.75 of spacer, get a four foot snipe and pull like mad or just let it be?.
any suggestions?
thanks |
rcowan Samba Member
Posted: Wed Mar 02, 2016 1:51 pm Post subject: Re: Lifted Eurovan with 16x7" rims |
You aren't out of adjustment. I'm betting that the threads are all gunked up. Possibly lowering it a couple turns, adding (more?) oil, and trying again will help. If I remember right, they are threaded to within about a .25" of the body..... Corrosion can be a problem though. I have removed them from the body and cleaned them on the real bad examples. Hopefully you aren't to that point! |
ovsa Samba Member
Posted: Wed Mar 02, 2016 1:57 pm Post subject: Re: Lifted Eurovan with 16x7" rims |
o.k thanks , i'll try that on the next go around.
how hard is it to take them right out for cleaning? |
Itsamoto Samba Member
Posted: Wed Mar 02, 2016 3:19 pm Post subject: Re: Lifted Eurovan with 16x7" rims |
ovsa wrote: |
I looked into this as I wanted to POR15 (or equivalent) the suspension to protect it -- and I'm pretty sure you have to drop the subframe to get them out.
I don't think its worth it - to pull them out. |
rcowan Samba Member
Posted: Wed Mar 02, 2016 3:28 pm Post subject: Re: Lifted Eurovan with 16x7" rims |
The threaded rods come out but simply turning them 90 degrees.
Obviously, you have to jack up the van and support it with jack stands. Then the nut that you are adjusting up to lift the van needs to be removed. Once that nut is removed, just turn the treaded rod 90 degrees and it drops out of the body. At least that's how my '99 is....... |
Posted: Wed Mar 02, 2016 3:57 pm Post subject: Re: Lifted Eurovan with 16x7" rims |
rcowan wrote: |
LOL -- obviously I didn't look carefully enough!
Don't listen to me because I like to do it the hard way. |
Posted: Wed Mar 02, 2016 5:35 pm Post subject: Re: Lifted Eurovan with 16x7" rims |
If you are wanting to make it hard, do it the right way.
Don't take out the T-Bolt that way. Best way to get a 4" hole saw, cut out the whole floor and frame support. The when you want to reinstall, weld back in the metal you cut out.
I was going to suggest flipping the van over and using a plasma cutter to cut out big sections of the van but I'm afraid you'd catch the carpet on fire. I'm a safety first kind of guy.
Need any more ideas, I offer them for free. |
Posted: Wed Mar 02, 2016 6:39 pm Post subject: Re: Lifted Eurovan with 16x7" rims |
rcowan wrote: |
Just the same on the '95 _________________ '58 Westy camper-come and gone
'79 Westy...Oscar
