Go Westy throttle body installation
obd
obd is offline
PostPosted: Sat Jan 09, 2016 2:48 pm    Post subject: Go Westy throttle body installation Reply with quote
Just installed rebuilt Go Westy throttle body. Van was running pretty well with the old throttle minus TPS plugged in. The van would idle at 2800 rpm with TPS plugged in. Hoped the new throttle body would solve my problem. Started up after install. RPM's surge to 2500 or so then dies. Doesn't seem to matter if TPS is plugged in or not. What did I do wrong? Pretty sure new one is back in exactly the way the old one came out. Are there adjustments I am neglecting? Thanks for any assistance.
icolquhoun
icolquhoun is offline
PostPosted: Sat Jan 09, 2016 3:59 pm    Post subject: Re: Go Westy throttle body installation Reply with quote
sounds like a large vacuum leak
djkeev Premium Member
djkeev is offline
PostPosted: Sat Jan 09, 2016 4:04 pm    Post subject: Re: Go Westy throttle body installation Reply with quote
Did you install a new rubber seal to the intake manifold?
All hoses are back on where they came from?
Look for dislodged electrical connectors.
Dave
Ghia
Vanagon
Beetle
obd
obd is offline
PostPosted: Sat Jan 09, 2016 4:08 pm    Post subject: Re: Go Westy throttle body installation Reply with quote
maybe the old plenum needs to be replaced. Only place i can imagine a large vacuum leak.
obd
obd is offline
PostPosted: Sat Jan 09, 2016 4:40 pm    Post subject: Re: Go Westy throttle body installation Reply with quote
I'm an idiot. I blame it on the lighting in my garage. The gasket/plenum was still stuck on the old throttle body. I had installed new one directly to the intake with no gasket hence large vacuum leak. All is well now. Thanks guys.
obd
obd is offline
PostPosted: Sat Jan 09, 2016 4:41 pm    Post subject: Re: Go Westy throttle body installation Reply with quote
Go Chiefs!
Vinzanto
Vinzanto is offline
PostPosted: Sat Jan 09, 2016 8:37 pm    Post subject: Re: Go Westy throttle body installation Reply with quote
My throttle body is good...CHIEFS!!!
1984 Vanagon Westfalia Wolfsberg
Butcher
Butcher is offline
PostPosted: Sat Jan 09, 2016 10:06 pm    Post subject: Re: Go Westy throttle body installation Reply with quote
SEA....HAWKS!
obd
obd is offline
PostPosted: Mon Jan 11, 2016 10:41 am    Post subject: Re: Go Westy throttle body installation (1986 Syncro) Reply with quote
Thought I was all good with my new throttle body. Idled great, fired up better than ever. I warmed it up to drive to work this morning and noticed exhaust smelled rich. Drove a few blocks and the van died upon acceleration. Seems to idle at just under 1000 rpm. Any other adjustments to consider. Maybe do a reset on the ECU? It has been awhile since the throttle control valve was plugged in.
obd
obd is offline
PostPosted: Mon Jan 11, 2016 10:42 am    Post subject: Re: Go Westy throttle body installation Reply with quote
by the way, 1986 Syncro
