daroota Samba Member
Posted: Tue Jan 12, 2016 8:09 am Post subject: Heated Steering wheel? |
I've looked around and haven't found anything for the manual steering wheel. I believe it's 450mm diameter. (17.716inches)
I think it would be an excellent solution to cold drives (got an air cooled van without power steering hence the large wheel)
So has anyone found one that works?
Thanks _________________ 1982 Westy-Air Cooled, Fuel Injected, 4 Speed Manual
Air Cooled Vanagon's FaceBook Group:
www.facebook.com/groups/AirCooledVanagon/ |
teej Samba Member
Joined: November 26, 2010 Posts: 897 Location: Seattle
Posted: Tue Jan 12, 2016 6:27 pm Post subject: Re: Heated Steering wheel? |
deleted _________________ 1986+ Wolfsburg Weekender Pop-Top 2.3 WBX Manual Trans
Posted: Tue Jan 12, 2016 6:57 pm Post subject: Re: Heated Steering wheel? |
Thought about heated gloves, but I'd like a little something for other drivers (if I let them drive)
I'm also going to get heated seat inserts when I refoam, but not the VW ones that burn everyone. _________________ 1982 Westy-Air Cooled, Fuel Injected, 4 Speed Manual
Merian Samba Member
Gloves with batteries |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
Terry Kay Banned
Posted: Tue Jan 12, 2016 9:56 pm Post subject: Re: Heated Steering wheel? |
You've got the wrong ride.
Think Benz or Lexus.
Or--transplant one of the above vehicles steering wheels into your van.
Poof-- a heated wheel. _________________ T.K. |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10251 Location: N. Idaho
Posted: Tue Jan 12, 2016 10:10 pm Post subject: Re: Heated Steering wheel? |
A little off topic, but when I heard cars were coming with this feature, I thought it was a little over the top. Then I drove an Audi A8 on a couple week winter trip. Holy crap that is a GREAT feature in the winter. Part of my original thought on it was that by the time the friggin steering wheel is warm the heater would be putting out and all would be well. Uh uh. Man, 30 seconds into a cold startup and you are literally gripping the wheel and drawing heat from it while the rest of the frigid car is sucking the heat out of you. How wrong I was.
As for the Vanagon, wow - do they make an aftermarket wheel for cars, or are you talking about buying a heated cover? I can't imagine how an aftermarket solution (cover or wheel) would work due to the wiring challenge.
Doug _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
Butcher Samba Member
Joined: December 05, 2015 Posts: 1285 Location: Right Here
Posted: Wed Jan 13, 2016 8:08 am Post subject: Re: Heated Steering wheel? |
If you want a heated steering wheel, I know Mercedes uses 40+ volts to make it work. The reason for the high voltage is for the speed of the heat and the current needed if 12v was used. Anything less would take too long.
So heated gloves would be the best idea but if someone wins the Power Ball, it should be a piece of cake.
In my area, it does not get that cold, but it is a nice feature to have. |
danfromsyr Samba Member
Posted: Wed Jan 13, 2016 2:03 pm Post subject: Re: Heated Steering wheel? |
maybe you can mount one of these radiant heaters to the sunvisor.
it even comes with a nifty map light.
and maybe use an inverter to power it if you don't have a long enough cord for where you wish to travel
this is all just kidding of course.. _________________
Abscate wrote: |
acegallagher Samba Member
Joined: February 02, 2015 Posts: 78 Location: Denverish
Posted: Wed Jan 13, 2016 2:20 pm Post subject: Re: Heated Steering wheel? |
this is all just kidding of course.. Rolling Eyes |
Don't joke about that. I'm already amazed at the kind of household appliances people will run on 12 volt and then bolt in their 30K vans like it's OE. You're asking for trouble. |
Posted: Wed Jan 13, 2016 8:15 pm Post subject: Re: Heated Steering wheel? |
Wheel swap won't work... because there is no power steering (all armstrong) for the big wheel.
I'm thinking a wrap or something type. I've got a nice wrap on my steering wheel already, and having some sort of heating in it would be nice.
I do have a BA6 as well and it's nice on the feet and window, but my fingers always seem cold when driving around below freezing in Canada. (I have to check my grounds on it again because sometimes it wouldn't start up, and sometimes it would)
I've got large hands, and find that I don't get enough circulation in gloves to keep my fingers warm (most gloves at least)
And I ask about the heated steering wheel because yes I too have tried one and loved it. Searched the forums and found nothing on it for the old large wheel, so I thought I'd ask if anyone has done something. A transformer could easily step up the voltage in a van for a nice heated wheel.
lol nice Danfromsyr, but being 6'2" that may impair my vision of the road, or at worse burn my hair.
I'll maybe look at how they are made and try to figure out something and share. anyone else I'd be happy to see what you come up with. _________________ 1982 Westy-Air Cooled, Fuel Injected, 4 Speed Manual
Merian Samba Member
Posted: Wed Jan 13, 2016 8:44 pm Post subject: Re: Heated Steering wheel? |
besides the voltage problem, it has to be powered as the wheel is turned
so you need a rotary contact like the turn signals use but larger - and BOˇH have to fit in the existing housing so you'll need to completely redesign all those parts |
Posted: Wed Jan 13, 2016 8:54 pm Post subject: Re: Heated Steering wheel? |
Or switch up the horn location and use that for a power source.
It is a possibility, as long as I upgrade the current wires to handle the load. _________________ 1982 Westy-Air Cooled, Fuel Injected, 4 Speed Manual
Merian Samba Member
Posted: Wed Jan 13, 2016 9:09 pm Post subject: Re: Heated Steering wheel? |
you need a horn - not to mention that the power for a heater is a LOT more than is designed into the horn connection |
Posted: Wed Jan 13, 2016 9:14 pm Post subject: Re: Heated Steering wheel? |
Also, a head's up if you are serious about using the horn ring for power (not sure if joking), that I have seen several where the dragging contact gets ground to a spear point and then chews holy heck out of the copper ring. Obtaining those parts was a pain when I checked years ago, so look down the parts road before you commit much time/effort.
Posted: Wed Jan 13, 2016 10:21 pm Post subject: Re: Heated Steering wheel? |
I really do not think people would do this, but you would need something to handle a good 30A or more. Triple the battery voltage [three batteries] would lower the current needed which would allow you to use the smaller gauge wiring and maybe a horn contact. 4 batteries would even be better. |
jackbombay Samba Member
Joined: October 19, 2007 Posts: 2723 Location: Eastern Idaho
canasync Samba Member
Posted: Thu Jan 14, 2016 7:50 pm Post subject: Re: Heated Steering wheel? |
I too thought that this was a ridiculous feature till I got a '98 528i with a heated wheel. It was just great! Everytime I drive our outback when it's -15C or more I miss having it. It seems like the steering wheel is always the last thing to get warm! _________________ 1987 Syncro
3 knobs
PumpeDüse TDI (17mm Garret Turbo, bigger injectors, stage 4 malone tune, intercooled)
Cruise Control
Remote Start/locks
Custom Lift
Custom Bumpers with receivers
Coast Mountain Hightop - Comming Soon
1985 2wd Vanagon Pre-runner in the making
soon to be powered by 2.5L Subaru
Custom Lift |
spacecadet Samba Member
Joined: June 02, 2012 Posts: 158 Location: San Francisco
Posted: Fri Jan 15, 2016 1:36 pm Post subject: Re: Heated Steering wheel? |
the beginning of a new way of vans catching on fire... I just pointed the one heater vent on the drivers side up and towards the steering wheel, worked great. _________________ Daily Drivers Only
1990 Volvo 740 Turbo(Sold)
1986 Mercedes 300 Coupe (Sold)
1954 Volvo PV544 (Sold)
1990 Dodge D250 Cummins (Totaled)
1990 Vanagon GL 2.1 Automatic (Sold)
1968 Ford F250(Current) |
DuncanS Samba Member
Posted: Wed Jan 20, 2016 10:01 pm Post subject: Re: Heated Steering wheel? |
A million years ago I had a 40hp split window in New England with, of course, no heat. The wipers would start to ride up on a build-up of ice so I took a piece of 110 v heat tape and cut 1/10th sections and siliconed them to the wiper. One end was grounded to the wiper blade and the other went through a hole with a grommet inside to a toggle switch. Worked like a charm. When the ice built up, I'd flip the switch and the ice would pop off after about 15 seconds.
So....thinking of doing the same thing with the steering wheel. Groove out the underside, lay in the wire and fill the space back up with silicone. Forget the electrical connections for now. Has anyone tried this? I'm thinking of taking a donor wheel and giving it a shot.
Also, anyone know about this?
http://www.gentherm.com/en/page/steering-wheel-heating
Duncan |
