EverettB Administrator
Joined: April 11, 2000 Posts: 69824 Location: Phoenix Metro
campingbox Samba Member
Joined: November 14, 2000 Posts: 10196 Location: Petaluma, CA
Posted: Thu Dec 20, 2007 10:16 pm Post subject: Re: Double Cab rear seat base hardware |
EverettB wrote: |
Can someone post a photo of the original hardware used to mount the rear seat base to the body?
I'm primarily interested in the hardware used for the top corners of the seat base but the floor hardware will be useful too.
Thank you. |
Chrome, but you get the idea.
Posted: Thu Dec 20, 2007 10:17 pm Post subject: |
Posted: Thu Dec 20, 2007 10:26 pm Post subject: |
Quote from;
http://www.amayesing.com/59dcparts.htm
"Note the hold down plates that go on the floor are the same plates used to secure a bug gas tank (or at least for mid 60's era bugs)"
Maybe Dr. Mayes can help with a picture of the backside of the hardware? |
grumpyveedub Samba Member
Joined: March 17, 2004 Posts: 469 Location: Central Arkansas
Posted: Thu Dec 20, 2007 10:28 pm Post subject: |
also look like bug gas tank hold downs, maybe. |
Matthew Tolbert Samba Member
Posted: Thu Dec 20, 2007 11:54 pm Post subject: |
would a 66 D cab have the floor clamps like the ones pictured or would it have something different? it has the same ones that are on the back but i have not seen anything in the floor that would accept any type of clamp. thanks for any info you can give. _________________ Matthew Tolbert
1958 ragtop
1961 doublecab
1965 Notchback S |
Mikee Samba A.D.D. Boy
Joined: March 22, 2004 Posts: 3510 Location: Puyallup WA
Posted: Fri Dec 21, 2007 12:17 am Post subject: Re: Double Cab rear seat base hardware |
EverettB wrote: |
Thank you. |
thanks for this thread, it will help on my new beast! _________________
localboymark wrote: |
One man's "patina" is another man's cancer. |
bugnut68 wrote: |
I would have kicked the guy right in the dick, balls, ass and face and destroyed his weed. Hippies suck. |
DaveM Mad Samba Scientist
Joined: June 11, 2002 Posts: 3010 Location: Dry side of Oregon
Posted: Fri Dec 21, 2007 8:35 am Post subject: |
campingbox wrote: |
Quote from;
The bolt is a normal carriage bolt. I'll go through my pictures and see if I have something specific. If I remember right, the bolt has no logo. The plates on the floor are the same as my 64 beetle gas tank hold downs. |
thom Samba Member
Joined: October 12, 2000 Posts: 5943 Location: Sacramento
Posted: Fri Dec 21, 2007 8:48 am Post subject: |
Are those plate on backwards? I thought the lip was supposed to go on the outside, so the clamp was level. _________________ -Thom
1956 Single Cab
1957 Porsche 356A Sunroof
1957 23-Window Deluxe
1963 Unimog 404
1965 E-Type |
Posted: Fri Dec 21, 2007 11:51 am Post subject: |
thom wrote: |
Are those plate on backwards? I thought the lip was supposed to go on the outside, so the clamp was level. |
I thinking 59 and 60 are on the iside, it said something like that on dropegates _________________
bugnut68 wrote: |
Posted: Fri Dec 21, 2007 12:19 pm Post subject: |
Thom is correct, the plate in the picture below is upside down.
I went and took the following picture of the hardware and did notice I had the plates in their correct position.
_________________ Sounding like a broken record as to why You should be measuring protein during harvest in order to better your agronomic practices. |
Posted: Fri Dec 21, 2007 1:02 pm Post subject: |
DaveM wrote: |
oops misunderstood the question
thought he was talking about the tabs
59-60
Curved pedestal, mounting tabs point inward. _________________
bugnut68 wrote: |
Hebster52 Samba Member
Joined: March 14, 2003 Posts: 1773 Location: Finland, Jakobstad
Posted: Sat Dec 22, 2007 2:29 am Post subject: |
Hmm.. We dont have that fancy rear seats in the Double Cabs here in Finland...
Due to some strange tax thing the DC's imported to Finland had to have a so called " temporary bench"... Not any thing like the frames posted above... Just a hinged plywood bench with some vinyl cover... _________________ ~Kris~
The Hebster52
The 912ST
The KidVRod project
The 356 Pre-A replica,SOLD
The 1966 Kommanderwagen, SOLD
The Doppel -67, SOLD
The Singlecab -72, SOLD |
Posted: Sat Dec 22, 2007 8:26 am Post subject: |
EverettB wrote: |
What size are those? M8?
What is the width of the square section of the carriage bolt head?
I have a 3/8" carriage bolt and the square portion is just a tiny bit too big to slide into the slot. |
M8 is the size. As per the square portion, well, it's the size that fits in the slot. Are you sure the metal with the slot in the floor isnt messed up some how? My hardware doesnt look anything special. _________________ Sounding like a broken record as to why You should be measuring protein during harvest in order to better your agronomic practices. |
Posted: Sat Dec 22, 2007 3:19 pm Post subject: |
Hebster52 wrote: |
Due to some strange tax thing the DC's imported to Finland had to have a so called " temporary bench"... Not any thing like the frames posted above... Just a hinged plywood bench with some vinyl cover... |
I wanna see a pic _________________
bugnut68 wrote: |
Posted: Sat Dec 22, 2007 9:26 pm Post subject: |
DaveM wrote: |
EverettB wrote: |
M8 is the size. As per the square portion, well, it's the size that fits in the slot. Are you sure the metal with the slot in the floor isnt messed up some how? My hardware doesnt look anything special. |
No, I think it was just because I had 3/8" bolts and M8 is closer to 5/16". _________________ How to Post Photos
TimGud Samba Member
Joined: March 03, 2002 Posts: 6459 Location: Rio Rico Arizona
Posted: Sun Dec 23, 2007 7:31 am Post subject: |
Anyone have two of those wingnuts for sale? I'm missing two and they are not the same as the regular bus seat hardware. |
