Share some build threads | I am building a 1987 Vanagon GL
ahmadahere
ahmadahere is offline
PostPosted: Sun Jan 17, 2016 10:33 pm    Post subject: Share some build threads | I am building a 1987 Vanagon GL Reply with quote
Hello Follow Enthusiasts
I am building a 1987 Vanagon Westfalia and I would like to see some of your threads for inspiration. I will share photos of my build here as well.
Chad
newfisher
newfisher is offline
PostPosted: Sun Jan 17, 2016 10:45 pm    Post subject: Re: Share some build threads | I am building a 1987 Vanagon Reply with quote
You can click on any members screen name and follow to thier page. Click on "posts" and it will bring up the threads they have started.
sanchius Premium Member
sanchius is offline
PostPosted: Mon Jan 18, 2016 6:18 am    Post subject: Re: Share some build threads | I am building a 1987 Vanagon Reply with quote
Chad
Thanks for asking!
Here's my collection of repair & build threads. Some of these may not be live anymore.
Good luck with your build.
Vanagon links
Vanagon Engine
AFM
http://www.notoriousracing.net/images/e28/E28%20afm%20Repair.htm
http://www.thesamba.com/vw/classifieds/detail.php?id=584819
http://www.loam.org/vw/Vanagon/DigiTool/
http://www.251.org/i/87Vanagon-DigiTool.html
http://members.tripod.com/~fuelie/tuneup.htm
http://members.tripod.com/~fuelie/performance.htm
http://www.limbobus.org/phpBB4/viewtopic.php?t=152&sid=1b439c2b33f363d25b7f03352cb53ea3
http://www.limbobus.org/phpBB4/viewtopic.php?t=125
http://www.thesamba.com/vw/forum/viewtopic.php?t=213216&highlight=hesitation
http://www.van-cafe.com/vanagonparts.jsp?pa=ip&ip=389083196
http://www.geocities.com/harald_nancy/intermitt._syndrome.htm
http://www.thesamba.com/vw/forum/viewtopic.php?t=369815
Coolant change
http://www.vanagonparts.com/cooling_refill.html
http://www.loam.org/vw/Vanagon/VWtoNapaHoses/
http://www.brick-yard.co.uk/forum/bleeding-the-cooling-system_topic29710.html?KW=Bleeding+the+system
Engine rebuild
http://www.thesamba.com/vw/forum/viewtopic.php?t=266554&highlight=endplay
http://www.thesamba.com/vw/forum/viewtopic.php?t=2...p;start=60
http://www.thesamba.com/vw/forum/viewtopic.php?t=254338&highlight=crankcase+leak
http://www.thesamba.com/vw/forum/viewtopic.php?t=2...mp;start=9
http://www.benplace.com/head.htm
http://www.superbeetles.com/Tech_talk/jan.htm
http://www.thesamba.com/vw/forum/viewtopic.php?t=3...p;start=30
http://www.thesamba.com/vw/forum/viewtopic.php?t=329194
http://www.thesamba.com/vw/forum/viewtopic.php?t=323029&highlight=engine+rebuild
http://www.thesamba.com/vw/forum/viewtopic.php?t=3...p;start=60
http://www.thesamba.com/vw/forum/viewtopic.php?t=254338&highlight=engine+rebuild
http://www.thesamba.com/vw/forum/viewtopic.php?t=350303&sid=f72d04d6946614ba06033aa3bc35b2a4
Head gasket
http://www.thesamba.com/vw/forum/viewtopic.php?t=360715&highlight=head+gasket
http://www.bostonengine.com/articles/waterboxes.html
http://wavanagon.googlepages.com/88vanagonglheadgasket
http://www.benplace.com/85westy_2_mecanique.htm
http://www.benplace.com/pascal_vw.htm
http://www.thesamba.com/vw/forum/viewtopic.php?t=3...p;start=55
http://porsche356enginebuild.blogspot.com/2009/06/4-engine-strip-down.html
http://www.thesamba.com/vw/forum/viewtopic.php?t=264403
http://www.thesamba.com/vw/forum/viewtopic.php?t=352182&highlight=engine+rebuild
http://www.benplace.com/type2_engine4.htm
Engine timing & tuning
http://www.thesamba.com/vw/forum/viewtopic.php?t=3...+adjusting
http://www.thesamba.com/vw/forum/viewtopic.php?t=356510&highlight=timing
http://www.thesamba.com/vw/forum/viewtopic.php?t=309932&highlight=vanagon+syndrome
http://www.thesamba.com/vw/forum/viewtopic.php?t=353187&highlight=idle
http://wiki.club8090.co.uk/index.php/Petrol_engines_Bad_idling_2.1
http://www.thesamba.com/vw/forum/viewtopic.php?t=343557&highlight=idle
http://www.sjmautotechnik.com/trouble_shooting/injector.html#mixture
http://www.thesamba.com/vw/forum/viewtopic.php?t=240560&highlight=timing+altitude
http://www.thesamba.com/vw/forum/viewtopic.php?t=357943&highlight=timing+advance+notch
http://www.thesamba.com/vw/forum/search.php?search..._chars=200
http://www.youtube.com/watch?v=yQukm7lNux4
Engine: Valve setting
http://www.thesamba.com/vw/forum/viewtopic.php?t=239926&highlight=finding+tdc
http://www.type2.com/library/engineg/hydral.htm
Engine: Remote starter
http://gerry.vanagon.com/cgi-bin/wa.exe?A2=ind0712D&L=vanagon&P=R18192&m=339624
http://www.wolfsburgwest.com/wired/wired_03_01/wired_03_01.htm
http://www.ratwell.com/technical/FAQ/FAQContent.html#0901
O2 Sensor
http://www.thesamba.com/vw/forum/viewtopic.php?t=349271&highlight=wet
http://www.benplace.com/os_sensor.htm
Oil leak
http://www.benplace.com/oil_pressure_sender.htm
http://www.thesamba.com/vw/forum/viewtopic.php?t=316649&highlight=oil+leak
http://www.thesamba.com/vw/forum/viewtopic.php?t=138839&highlight=main+seal
http://vanagonusedparts.com/library_article.php?id=535
http://www.thesamba.com/vw/forum/viewtopic.php?t=314002&highlight=main+seal
http://www.shoptalkforums.com/viewtopic.php?t=102662
http://www.thesamba.com/vw/forum/viewtopic.php?t=326912&sid=7a5a34ea4204deb3236f9e37a25173a5
http://www.shoptalkforums.net/viewtopic.php?t=100129
http://gerry.vanagon.com/cgi-bin/wa.exe?A2=ind0601A&L=vanagon&D=0&P=22214
http://www.gowesty.com/library_article.php?id=535
http://gerry.vanagon.com/cgi-bin/wa.exe?A2=ind0601A&L=vanagon&D=0&P=22813
http://www.thesamba.com/vw/forum/viewtopic.php?t=295812&highlight=oil+breather
Oil Pressure
http://www.thesamba.com/vw/forum/viewtopic.php?t=179889
http://www.thesamba.com/vw/forum/viewtopic.php?p=6701649&highlight=leaking+oil+pump#6701649
No Start - No Spark
http://www.thesamba.com/vw/forum/viewtopic.php?t=262779&highlight=hall+sensor
http://www.thesamba.com/vw/forum/viewtopic.php?t=219779&highlight=relay+click
http://www.thesamba.com/vw/forum/viewtopic.php?t=349429
No Start - no crank
http://www.thesamba.com/vw/forum/viewtopic.php?t=331551&highlight=starter+crank
http://www.thesamba.com/vw/forum/viewtopic.php?t=299865&highlight=starter+ecu
http://www.thesamba.com/vw/forum/viewtopic.php?t=375383&highlight=starter+ignition
http://forums.vwvortex.com/showthread.php?2359900-...al-tranny)
Water Pump
http://www.ratwell.com/technical/TempSensorII.html
http://www.thesamba.com/vw/forum/viewtopic.php?t=368656&sid=a1b49513521df5ddd5ffbd9966f753e9
Vanagon Fuel
Fuel hose renewal
http://www.benplace.com/fuel_line.htm
http://gerry.vanagon.com/cgi-bin/wa.exe?A2=ind0604C&L=vanagon&D=0&m=288884&P=14563
http://busdepot.com/details.jsp?partnumber=043906091
http://busdepot.com/details.jsp?partnumber=N0202811
http://www.kegkits.com/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=OCLAMP
Fuel tank
http://www.thesamba.com/vw/forum/viewtopic.php?t=2...start=1024
Vanagon Brakes
http://www.thesamba.com/vw/forum/viewtopic.php?p=6...de#6071392
Vanagon Drivetrain
CV joints
http://californiavan.com/frontend/80-84lowerballjoints/
http://forum.80-90.co.uk/viewtopic.php?t=30666
http://www.van-cafe.com/?ip=1150562894&pa=ip
http://www.van-cafe.com/vanagonparts.jsp?pa=ip&ip=1150562894
http://www.van-cafe.com/vanagon_parts.jsp?pa=p&p=2064659985&pct=1456550857&ct=1435197293
http://www.thesamba.com/vw/forum/viewtopic.php?t=279404&sid=3fb6d1878775cef6aa2f734cb44a3c94
http://gerry.vanagon.com/cgi-bin/wa.exe?A2=ind0803d&L=vanagon&D=0&P=36379
http://home.earthlink.net/~mark.cumnock/westfalia/id33.html
http://www.autohausaz.com/search/product.aspx?sid=...%20Washers
http://www.thesamba.com/vw/forum/viewtopic.php?p=7789836&highlight=autozone#7789836
http://www.thesamba.com/vw/forum/viewtopic.php?t=249639
Diff Lock
http://www.thesamba.com/vw/forum/viewtopic.php?t=322474&highlight=locker+servo
http://www.thesamba.com/vw/forum/viewtopic.php?t=319128&highlight=locker
http://www.thesamba.com/vw/forum/viewtopic.php?t=306318&highlight=locker
http://www.thesamba.com/vw/forum/viewtopic.php?t=293574&highlight=locker
http://www.thesamba.com/vw/forum/viewtopic.php?t=268503&highlight=locker
http://syncro.org/DiffLock.html
http://www.club80-90syncro.co.uk./Syncro_website/TechnicalPages/rear_trans.htm
http://www.club80-90syncro.co.uk./Syncro_website/TechnicalPages/Troubleshooting_diff_locks.htm
http://f1.grp.yahoofs.com/v1/0N4WSTILtOB_vTqz_l_ca...ock%20Help
http://forum.80-90.co.uk/viewtopic.php?t=1376
http://vanagonwiki.net/index.php/Differential_Lock_Vacuum_System
http://forum.club8090.co.uk/viewtopic.php?f=4&t=58860
Front Diff Lock
http://www.club80-90syncro.co.uk./Syncro_website/TechnicalPages/Intro_diff_locks.htm
http://www.thesamba.com/vw/forum/viewtopic.php?t=169543
http://www.vagcat.com/epc/cat/vw/T2SY/1991/59/55/598194/
http://jones.colorado.edu/jones/VW/SyncroAlign/
http://jones.colorado.edu/jones/VW/SyncroAlign/FrontDiffParts.pdf
Clutch
http://www.vanthology.com/1Layout/Technical/Clutch3.html
http://www.thesamba.com/vw/forum/viewtopic.php?t=335066&highlight=clutch+fluid
http://www.thesamba.com/vw/forum/viewtopic.php?t=330383&highlight=clutch+fluid
http://www.type2.com/bartnik/tech.htm
cv joint
http://www.benplace.com/cv_joint_maintenance.htm
http://volksweb.relitech.com/cvjoints.htm
http://www.vanagonauts.com/%5B42.7%5D-Constant-Velocity-(CV)-Joints140.htm
http://homepage.ntlworld.com/aidan.talbot/syncroprop/
http://forum.80-90.co.uk/viewtopic.php?t=26153
http://www.blindchickenracing.com/How_to/CVJoints_Axles/cv_joints_101.htm
Audi Wheels
wheel studs
http://www.brick-yard.co.uk/VehicleSpecific/T3/info/mods/longstuds.htm
http://www.thesamba.com/vw/forum/viewtopic.php?t=133767
http://www.thesamba.com/vw/forum/viewtopic.php?t=221965&highlight=audi+alloy
http://www.brick-yard.co.uk/forum/forum_posts.asp?TID=8074&PN=1
http://www.brick-yard.co.uk/forum/forum_posts.asp?TID=7198&KW=studs
http://members.aol.com/realsf/images/longerstuds.jpg
http://gerry.vanagon.com/cgi-bin/wa.exe?A2=ind0111C&L=vanagon&P=R16466&m=160479
http://gerry.vanagon.com/cgi-bin/wa.exe?A2=ind0203B&L=vanagon&D=0&m=160479&P=80071
http://gerry.vanagon.com/cgi-bin/wa.exe?A2=ind0204A&L=vanagon&P=R12929&m=160479
http://www.bugsandbuggies.com/Parts.asp?CN=914&SN=102&GN=13&Subgroup=Wheel+A
http://gerry.vanagon.com/cgi-bin/wa.exe?A2=ind0301B&L=vanagon&P=R13966&m=160479
http://gerry.vanagon.com/cgi-bin/wa.exe?A2=ind0208A&L=vanagon&P=R8553&m=160479
http://gerry.vanagon.com/cgi-bin/wa.exe?A2=ind0208A&L=vanagon&D=0&m=160479&P=24195
http://gerry.vanagon.com/cgi-bin/wa.exe?A2=ind0611A&L=vanagon&P=R12929&m=270896
http://www.thesamba.com/vw/forum/viewtopic.php?t=2...;start=200
http://www.thesamba.com/vw/forum/viewtopic.php?p=2102691#2102691
http://www.thesamba.com/vw/forum/viewtopic.php?t=219816
Alignment (trans, wheels etc)
http://jones.colorado.edu/jones/SyncroAlign/
http://autos.groups.yahoo.com/group/Syncro/messages/36978?viscount=100&expand=1
http://www.vanagonauts.com/44.3a-Syncro-95.htm
brake upgrade
http://syncro.ca/tech/audibrakes.htm
http://www.thesamba.com/vw/forum/viewtopic.php?t=187813&highlight=brake+bleeder+wrench
http://www.vanagonauts.com/index.phtml?catid=190
http://www.thesamba.com/vw/forum/viewtopic.php?t=300165&sid=4fe15b385885cac889dd358a72546051
http://www.bmw-m.net/TechProc/bleeder.htm
http://www.syncro.ca/tech/audibrakes.htm
http://web.archive.org/web/20040419045730/members....oject.html
http://www.thesamba.com/vw/forum/viewtopic.php?t=258879
http://www.thesamba.com/vw/forum/viewtopic.php?t=242786[url]
http://www.thesamba.com/vw/forum/viewtopic.php?t=377844&sid=8665f9354e69d6b25ac7078fbdff9132
Suspension renew
http://www.thesamba.com/vw/forum/viewtopic.php?t=289949&sid=1fb9ec5ac9d49b8a38a6956190841d75
http://www.vanagonparts.com/home.html
http://www.thesamba.com/vw/forum/viewtopic.php?t=396113&highlight=diy+alignment
http://www.t3technique.com/powerflex-bushings/
http://www.thesamba.com/vw/forum/viewtopic.php?t=393079&highlight=vanjoe
http://translate.googleusercontent.com/translate_c...RWjUUrHF_Q
swaybar
http://www.swaybars.com/index.asp?PageAction=VIEWPROD&ProdID=1617
wheel bearing
http://www.thesamba.com/vw/forum/viewtopic.php?t=5...p;start=20
http://translate.google.com/translate?hl=en&ie...tandsetzen
http://shufti.wordpress.com/2011/04/16/vanagon-rear-wheel-bearing-replacement/
Driveshaft
http://www.thesamba.com/vw/forum/viewtopic.php?t=274976
http://www.thesamba.com/vw/forum/viewtopic.php?t=377761
http://www.thesamba.com/vw/forum/viewtopic.php?t=437924&sid=847fba5825bd722af43ae2967ccf9fd8
http://www.vanagon.com/syncros/technica/Driveline/Syncro_3856.html
VC rebuild
http://homepage.ntlworld.com/aidan.talbot/VC/
http://www.mrtrally.com.au/performance/viscous_coupling.htm
http://forum.80-90.co.uk/viewtopic.php?t=29865
http://ig-syncro16.de/forum/index.php?name=ForumsP...ht=Silicon
http://users.rcn.com/derekdrew/vanagon/viscous_couplings_vanagon_syncro.htm
http://www.gowesty.com/library_article.php?id=627
http://forum.busikt3.radom.pl/viewtopic.php?t=313
http://www.facebook.com/photo.php?fbid=478197752199830&set=o.36419276257&type=1&theater
Transmssion
http://www.thesamba.com/vw/forum/viewtopic.php?t=249639&highlight=final
http://www.thesamba.com/vw/forum/viewtopic.php?t=342440
http://www.thesamba.com/vw/forum/viewtopic.php?t=374939&highlight=syncro+transmission
http://www.thesamba.com/vw/forum/search.php?search_keywords=input+shaft+seal&search_forum=20
http://www.brick-yard.co.uk/forum/limey-the-syncro...age19.html
http://www.longenterprises.com/vanagon_syncro_specialty_items.htm
http://www.aztransaxle.com/
http://www.thesamba.com/vw/forum/viewtopic.php?t=321958&highlight=jump+4th
http://www.thesamba.com/vw/forum/viewtopic.php?t=344159&highlight=input+shaft+seal
http://www.thesamba.com/vw/forum/viewtopic.php?t=314916&highlight=input+shaft+seal
http://www.thesamba.com/vw/forum/viewtopic.php?t=257050&highlight=input+shaft+seal
2wd transmission
http://www.thesamba.com/vw/forum/viewtopic.php?t=495334&highlight=2wd+transmission
http://www.thesamba.com/vw/forum/viewtopic.php?t=511450&highlight=2wd+transmission
http://www.thesamba.com/vw/forum/viewtopic.php?t=559474&highlight=transmission
http://www.thesamba.com/vw/forum/viewtopic.php?t=386661&highlight=2wd+syncro
http://www.thesamba.com/vw/forum/viewtopic.php?t=392658&sid=d7b2afcd0ef64e36bbef3fbd2bf2025e
wheel bearings
http://volksweb.relitech.com/frntbrg.htm
Tire size: 30x9.5r15
http://autos.groups.yahoo.com/group/Syncro/message/9353
http://www.tirerack.com/tires/Sizes.jsp?make=BFGoodrich&model=All-Terrain+T%2FA+KO
http://www.thesamba.com/vw/forum/viewtopic.php?t=295658&sid=eb2307827bfb7a60bed03a15705c4fd9
Shifter
http://www.thesamba.com/vw/forum/viewtopic.php?t=4...highlight=
http://www.volkscafe.com/images/lg/1030702019.jpg
http://t25shortshifters.mysite.wanadoo-members.co.uk/
http://www.thesamba.com/vw/forum/viewtopic.php?t=3...p;start=20
http://forum.80-90.co.uk/viewtopic.php?t=7727&highlight=shifter
http://autos.groups.yahoo.com/group/Syncro/message/33624
http://wiki.80-90.co.uk/index.php/Gearbox_Clutch_CVs_Sloppy_gear_change_improving
http://www.geneberg.com/product_info.php?cPath=17_486_2978&products_id=1207
http://autos.groups.yahoo.com/group/Syncro/message/36949
Vanagon Heater/AC
AC
http://www.thesamba.com/vw/forum/viewtopic.php?t=292488&highlight=redtek
http://www.pelicanparts.com/techarticles/911_Nippondenso_rebuild/911_Nippondenso_rebuild.htm
http://www.airpartsonline.com/default.tpl
http://www.sanden.com/support/servicemanual/
http://gerry.vanagon.com/cgi-bin/wa.exe?A2=ind0606e&L=vanagon&D=0&P=4561
http://blakeheinlein.googlepages.com/vanagon-airconditioning
http://www.thesamba.com/vw/forum/viewtopic.php?t=2...highlight=
http://www.thesamba.com/vw/forum/viewtopic.php?t=365626&sid=434f2085a67adf7bc447458a07be55b0
front heater fix
http://www.benplace.com/dash.htm
http://www.vanagain.com/heaterv1.htm
http://www.thesamba.com/vw/forum/archive/index.php/o-t--t-295888--.html
http://www.vanagonauts.com/Heater-Blower-R&-R118.htm
http://www.knology.net/~vw/vanagon/dash/
http://www.thesamba.com/vw/forum/viewtopic.php?t=294872&highlight=
http://www.thesamba.com/vw/forum/viewtopic.php?t=265457
http://www.thesamba.com/vw/forum/viewtopic.php?t=266831&highlight=relay+vent
http://gerry.vanagon.com/cgi-bin/wa.exe?A2=ind0802B&L=vanagon&P=R12529&m=320245
http://www.thesamba.com/vw/forum/viewtopic.php?t=2...p;start=21
http://www.thesamba.com/vw/forum/viewtopic.php?t=163417&postorder=des
http://www.vanagon.com/info/articles/owners-manual/vent-controls.html
http://www.thesamba.com/vw/forum/viewtopic.php?t=329618&sid=973d770d0848408597b8a56faf9a6b62
http://www.thesamba.com/vw/forum/viewtopic.php?t=344654&postdays=0&postorder=asc&start=0
http://gerry.vanagon.com/cgi-bin/wa.exe?A2=ind0907a&L=vanagon&D=0&P=16483
Furnace
http://www.thesamba.com/vw/forum/viewtopic.php?t=3...p;start=46
http://members.aol.com/fkc43/insulat.htm
http://www.thesamba.com/vw/forum/viewtopic.php?t=278508&highlight=propex
http://jeffgully.com/index.php?blog=6&title=heat-at-last&more=1&c=1&tb=1&pb=1
http://www.thesamba.com/vw/forum/viewtopic.php?t=605822&sid=71240362448bb539a8c9dc0638befcf5
Vanagon Electrical
cb radio
http://www.thesamba.com/vw/forum/viewtopic.php?t=143322
http://www.walcottcb.com/
http://www.firestik.com/Tech_Docs.htm
http://4runners.org/writeups/rearfirestik/index.html
http://www.firestik.com/CatalogFrame.htm
http://cbradiomagazine.com/
http://coloradok5.com/forums/forumdisplay.php?s=139e0ea8db4cc3540851d92a26272705&f=20
http://www.sittser.com/ElecReport.htm
http://www.oz.net/%7Etyg/TyG/Westy.htm
http://www.sittser.com/ElecPictures.htm
http://www.vanagon.com/info/articles/upgrades/battery/index.html
http://gerry.vanagon.com/cgi-bin/wa.exe?A2=ind0806a&L=vanagon&D=0&P=12262
http://www.wiringproducts.com/index1.html
http://www.brick-yard.co.uk/forum/forum_posts.asp?TID=11446&PN=2
http://www.thesamba.com/vw/forum/viewtopic.php?t=244500&sid=a476e84b65cdc410c37a93fd5e16aff8
http://home.wavecable.com/~spiders/auxele.htm
http://www.thesamba.com/vw/forum/viewtopic.php?t=354043&sid=1c317dfa74f042f1e9ab4e41b261c6af
http://www.thesamba.com/vw/forum/viewtopic.php?t=246921
http://www.overtons.com/modperl/product/details.cg...amp;r=view
http://www.campingworld.com/browse/skus/index.cfm?skunum=3915
http://www.amazon.com/PAC-SPR200-Battery-Monitor-R...amp;sr=1-2
Gauges: Extra Gauges
http://www.thesamba.com/vw/forum/viewtopic.php?t=1...p;start=60
http://www.thesamba.com/vw/forum/viewtopic.php?t=1...p;start=75
http://www.members.shaw.ca/McTavishPac/cluster/cluster.html
http://www.sthwark.demon.co.uk/
http://members.shaw.ca/McTavishPac/cluster/cluster.html
http://www.secondchancegarage.com/public/186.cfm
http://shufti.wordpress.com/2010/01/04/frank-g-s-modified-instrument-cluster/
http://www.flickr.com/photos/westytech/599414780/
Gauges: Temp gauge
http://www.thesamba.com/vw/forum/viewtopic.php?t=206856&highlight=temperature
http://www.thesamba.com/vw/forum/viewtopic.php?t=176786&highlight=temperature
http://www.thesamba.com/vw/forum/viewtopic.php?t=379237&highlight=temperature+gauge
Vanagon Lights: Head/tail/fog
Headlights
http://www.members.shaw.ca/albell/mods/lightcircuit.html
http://members.aol.com/Fkc43/hdltrela.htm
http://www.thesamba.com/vw/forum/viewtopic.php?t=151848
http://www.thesamba.com/vw/forum/viewtopic.php?t=2...mp;start=0
http://www.thesamba.com/vw/forum/viewtopic.php?t=274814&sid=ed23b40f6ced9790201a8907f67f422e
http://neksiwel.20m.com/custom.html
http://www.cibie.net/cibie_specific_frameset.htm
http://20v.org/jbwire.jpg
http://picasaweb.google.com/bike2vcu/HeadlightUpgrade#
http://www.thesamba.com/vw/forum/viewtopic.php?t=3...p;start=40
http://fahrzeugteile.shop.ebay.de/VW-/65232/i.html...&_sc=1
http://www.weidefamily.net/vanagon/HTML/04/07/01.html
http://www.haywood-sullivan.com/vanagon/foglight_wiring.html
http://www.thesamba.com/vw/forum/viewtopic.php?t=214519&highlight=headlamp+upgrade
http://search.ebay.de/search/search.dll?MfcISAPICo...tPriceSort
http://fahrzeugteile.shop.ebay.de/i.html?_nkw=t3+%...sacat=9884
http://web.mac.com/dot251/251.org/87Vanagon-H4.html
http://www.thesamba.com/vw/forum/album_page.php?pic_id=520989
http://wiki.club8090.co.uk/index.php/VW_Electrics_Headlight_warning_buzzer
http://shufti.wordpress.com/2010/05/15/headlight-on-warning-chime-mod/
http://www.jeepforum.com/forum/f9/h-i-d-s-my-tj-wow-842999/
http://www.vvme.com/5055w-h439003-bixenon-hid-kit-p-31.html?cPath=44_46_35
http://www.ddmtuning.com/product.php?II=101
http://www.clubtitan.org/forums/showthread.php?t=61387
http://fahrzeugteile.shop.ebay.de/i.html?_nkw=t3+%...m270.l1313
http://fahrzeugteile.shop.ebay.de/i.html?_nkw=T3+%...m270.l1313
http://www.frankcondelli.com/hdltrela.htm
http://www.ddmtuning.com/category.php?CA=85
http://shufti.wordpress.com/2010/01/21/fogaux-lights-installed/
http://www.qadas.com/~kanas/Vehicles/Syncro/South_African_Grille_Procedure.html
http://www.brick-yard.co.uk/forum/forum_posts.asp?TID=12857&KW=headlight
https://sites.google.com/site/vanagonheadlightrelays/home
http://vanagonwestfaliaparts.com/wp-content/uploads/2013/01/Headlight-Relays-86-91.pdf
taillights
http://pws.prserv.net/synergy/Vanagon/E_tail_lt.htm
http://www.superbrightleds.com/cgi-bin/store/commerce.cgi?product=CAR
http://www.sylvania.com/ConsumerProducts/AutomotiveLighting/LampReplacementGuide/AutoLRG-Results.htm
http://picasaweb.google.com/itzdshtz/VanagonSyncroProject02#5379313659358829106
http://www.pickupspecialties.com/LED_light_bar/fire_and_ice_led_tailgate_bar.htm
http://www.thesamba.com/vw/forum/viewtopic.php?p=3491958&highlight=#3491958
http://www.wind-sun.com/ForumVB/forumdisplay.php?s=95a8819ea8ef6427ef342bb566e654ed&f=3
http://www.thesamba.com/vw/forum/viewtopic.php?t=592743&sid=3ea99c86d02d348520fe6176383d30f8
http://www.thesamba.com/vw/forum/viewtopic.php?p=7625288&highlight=welcome#7625288
http://autospeed.com/A_107975/cms/article.html
Wiring interior lights/radio off aux batt
https://sites.google.com/site/vanagonheadlightrela...iary-power
Vanagon Exterior
Awning
http://www.aircraftspruce.com/menus/ha/rivnuts.html
http://gerry.vanagon.com/cgi-bin/wa.exe?A2=ind0605b&L=vanagon&D=0&P=30323
http://www.campingworld.com/browse/skus/index.cfm/...kunum=2079
http://www.campingworld.com/browse/skus/index.cfm?skunum=19802
http://www.campingworld.com/hardtofindparts/index.cfm?pSetID=24
http://gerry.vanagon.com/cgi-bin/wa.exe?A2=ind0005...mp;P=34227
http://home.wavecable.com/~spiders/awn.htm
http://www.thesamba.com/vw/forum/viewtopic.php?t=3...p;start=24
bodywork
http://71vwbus.blogspot.com/2008/03/bumping-metal.html
http://www.kch2o.com/forum/eurotrash-profiles/1985-westfalia/page-2/
https://www.youtube.com/user/ButlerCollision?feature=watch
http://www.frontrunneroutfitters.com/Camping-Gear/FRONT-RUNNER-CAMPFIRE-COOKING-GRATE-p79.html
Body: slider
http://www.thesamba.com/vw/forum/viewtopic.php?t=446358&highlight=sliding
http://www.thesamba.com/vw/forum/viewtopic.php?t=446743&highlight=sliding
http://www.leevalley.com/us/wood/page.aspx?c=&p=32182&cat=1,110,43466
http://www.thesamba.com/vw/forum/viewtopic.php?t=381226
http://www.thesamba.com/vw/forum/viewtopic.php?t=483867
$50 paint job
http://www.rickwrench.com/50dollarpaint.html
http://www.thesamba.com/vw/forum/viewtopic.php?t=216758
http://www.thesamba.com/vw/forum/viewtopic.php?t=167756&postdays=0&postorder=asc&start=0
http://www.new.cpfaruba.com/PDFs/English/Devoe/Hydrostrip%20502.pdf
painting the bumper
http://tubaneil.googlepages.com/paintyerbumpers%21
http://www.aircooled.net/new-bin/kwsearch.php
http://picasaweb.google.com/wetwesties/JimLisaSLeavenworth2007#5440749559060800450
spare tire holders
http://www.thesamba.com/vw/forum/viewtopic.php?t=312088
http://www.thesamba.com/vw/forum/viewtopic.php?p=2357729#2357729
trim painting
http://www.thesamba.com/vw/forum/viewtopic.php?t=331723&highlight=paint
Poptop canvas replacement
http://www.thesamba.com/vw/forum/viewtopic.php?t=241396
http://www.limbobus.org/poptop.htm
http://www.thesamba.com/vw/forum/viewtopic.php?t=565815&sid=c1c6f7fd756db1bad18dc05e3560f429
http://www.thesamba.com/vw/forum/viewtopic.php?t=548231&highlight=
http://www.thesamba.com/vw/forum/viewtopic.php?t=5...21bde1ec47
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/22255681.cfm
https://www.expeditionexchange.com/hilift/
http://shop.ebay.com/i.html?_nkw=Scotchlite+680&am...;_osacat=0
http://www2.cip1.com/ProductDetails.asp?ProductCode=VNG%2D95%2D57%2D59%2D2
http://www.busdepot.com/251800010
Vanagon Interior
Seats
http://www.hiss.org/3t3/AdaptionSaabSitze/index.html
http://homepage.ntlworld.com/georgina_shaun/T3_website/fitting.html
http://www.thesamba.com/vw/forum/viewtopic.php?t=356613[/url]
http://www.thesamba.com/vw/forum/viewtopic.php?t=238428&highlight=swivel+seat+base
http://www.heatedseatkits.com/heatedseatkits/iheat2/
http://www.thesamba.com/vw/forum/viewtopic.php?t=370266&highlight=
Interior
http://www.vwkd.co.uk/bb/viewtopic.php?t=88&postdays=0&postorder=asc&start=344
http://www.t-molding.com/store/home.php?cat=3
http://www.reimo.com/en/M5210709-umleimer_gepolstert_15mm/
http://woodworker.com/cgi-bin/FULLPRES.exe?PARTNUM=147-548&LARGEVIEW=ON
https://www.thewavebox.com/
http://www.thesamba.com/vw/forum/viewtopic.php?t=373343&highlight=leds
http://www.haywood-sullivan.com/vanagon/dual_horns_wiring_diagram.gif
http://www.thesamba.com/vw/forum/viewtopic.php?t=2...;start=668
http://www.type2.com/library/heat/heat-soundproof.html
Steering Wheel
http://www.thesamba.com/vw/forum/viewtopic.php?t=296362
http://www.thesamba.com/vw/forum/viewtopic.php?t=259700
Rear hatch release
http://www.griffco.ca/interest/vw/HatchLatch.htm
http://www.thesamba.com/vw/forum/viewtopic.php?t=3...mp;start=0
Gauges: Tach
http://www.oldvolkshome.com/late_van_cluster_install.pdf
http://www.thesamba.com/vw/forum/viewtopic.php?t=2...p;start=20
http://www.thesamba.com/vw/forum/viewtopic.php?t=569278&sid=d411d9ffd59213de382b36c86f2013f8
Expeditions
http://www.bumfuzzle.com/Pages/Main%20Pages/Dates.html
http://bodeswell.org/
http://www.flickr.com/photos/t_w/tags/syncro/page6/
http://www.flickr.com/groups/51543995@N00/pool/
http://www.syncro-nutz.com/gallery.html
http://www.4wdtrips.net/forum/index.php
http://www.horizonsunlimited.com/hubb/
http://www.flickr.com/photos/gowesty_pics/collections/72157603746369953/
http://www.whereisthebus.nl/en/
http://www.faliaphotography.com/
http://www.phrannie.org/phredex.html
http://www.cheaprvlivingforum.com/?forum=183323
http://translate.googleusercontent.com/translate_c...UhCsnQFPbQ
http://www.easy2design.de/bla/tigerbus/metamorphose/
http://translate.googleusercontent.com/translate_c...pbBkYH2URQ
http://translate.google.com/translate?hl=en&sl...md%3Dimvns
http://www.arestlesstransplant.com/
Vanagon Videos
http://video.google.ca/videoplay?docid=1339508995286761246
http://video.google.ca/videoplay?docid=660446700066541980
http://www.youtube.com/watch?v=CnErOM9r4lI
http://www.youtube.com/watch?v=mi8SlYGt0YM&mode=related&search=
http://www.zebrastreifen.com/reiseberichte.htm
MOAB
http://www.coyoteshuttle.com/
http://groups.msn.com/BobsPhotoShare/shoebox.msnw
http://www.20yearsoverland.com/index.html
http://torlasco.tripod.com/
http://www.cheaprvlivingforum.com/?forum=183323&trail=50
https://www.facebook.com/travel2explore.ch
http://ouropenroad.com/about/
http://www.blm.gov/co/st/en/BLM_Programs/geographical_sciences/gis/100kMapIndex.html
http://www.fs.usda.gov/detailfull/fishlake/recreation/?cid=stelprdb5121831
Forums: Other Vanagon Forums
http://autos.groups.yahoo.com/group/subaruvanagon/messages
http://gerry.vanagon.com/archives/vanagon.html
http://www.expeditionportal.com/forum/forumdisplay.php?f=58
http://autos.groups.yahoo.com/group/Syncro/messages/?viscount=100&expand=1
http://translate.google.com/translate?sl=pl&tl...Findex.php
http://www.brick-yard.co.uk/forum/default.asp
http://www.brick-yard.co.uk/forum/t3-section_forums_cat9.html
http://www.shoptalkforums.com/viewtopic.php?t=100129
http://translate.googleusercontent.com/translate_c...X8B42-FDWg
http://www.vwt3.co.at/index.php?name=Forums&file=viewtopic&p=268331
http://forums.vwvortex.com/zeroforum?id=830
http://t3zone.com/index.php
http://forum.club8090.co.uk/index.php
http://forum.club8090.co.uk/viewforum.php?f=37
http://www.ssvc.org.uk/phpbb/viewforum.php?f=38
http://translate.google.com/translate?sl=auto&...mp;act=url
http://translate.googleusercontent.com/translate_c...-WuRzHU0EQ
http://www.ssvc.org.uk/phpbb/viewforum.php?f=8
http://www.furgovw.org/index.php?topic=8639.0
http://www.garagejournal.com/forum/forumdisplay.php?f=3
http://forums.kombiclub.com/index.php
http://campervanthings.com/posts/all/2
http://vwbus.no/forum/viewforum.php?f=55
http://translate.google.com/translate?sl=auto&...%3D27968.0
http://www.volkszone.com/VZi/
http://www.van-life.net/
http://autos.groups.yahoo.com/group/Rocky-Mountain-Syncro-Fest/messages
http://www.van-life.net/archive
http://www.6speedonline.com/forums/garage-forum-61/
Mods
http://s105.photobucket.com/user/tencentlife/library/?view=recent&page=1
http://shufti.wordpress.com/category/vanagon-mods/
http://www.brick-yard.co.uk/VehicleSpecific/T3/info/menu.htm
http://gerry.vanagon.com/cgi-bin/wa.exe?A2=ind0611A&L=vanagon&D=0&m=270896&P=31905
http://www.dugbert.com/van/
http://www.mts.net/~rrh/WestyMods.html
http://www.thesamba.com/vw/forum/viewtopic.php?t=2...;start=320
http://www.thesamba.com/vw/forum/viewtopic.php?t=1...p;start=58
http://faculty.ccp.edu/faculty/dreed/Campingart/vanagon/index.htm
http://faculty.ccp.edu/faculty/dreed/Campingart/vanagon/hacks.htm
http://www.vanagonparts.com/tech_index.html
http://www.kayakwesty.com/mywesty.html
http://groups.yahoo.com/group/Syncro/photos/album/1900344388/pic/list
http://www.flickr.com/photos/kenneth-mitchell/3030743779/in/set-72157609092979148/
http://91syncro.com/info.html
http://www.panelteccorp.com/html/stockpanels.html
http://www.busdepot.com/details.jsp?partnumber=J12123
http://www.flickr.com/photos/14602120@N03/sets/
http://www.busdepot.com/details.jsp?partnumber=46193
http://www.members.shaw.ca/albell/mods.html
http://www.thesamba.com/vw/forum/viewtopic.php?p=7...es#7690643
Parts Places
http://www.van-cafe.com/vanagon_parts.jsp?ct=733914979&pa=ct&p=1464530415
http://www.ebay.com/sch/Cars-Trucks-/6001/i.html?_...84%2C1985)
http://www.ebay.com/sch/i.html?_odkw=vanagon+syncr...p;_sacat=0
http://www.syncro.org/bushings.htm
http://www.volvoclub.org.uk/faq/SpecialTools.html
http://evwparts.com/Vanagon.asp
http://www.volvoclub.org.uk/faq/ElectricalIgnition.html
http://www.syncro-services.com/index_spares_eng.html
http://www.busdepot.com/catalog.jsp?model=44
http://burleysmotorsports.com/zencart/index.php?ma...2n2cg5rfj4
http://www.kirkmeeks.com/syncro_store
Parts: German parts places
https://www.kaefer-co.de/catalog/349/Vorderachsget...yncro.html
http://shop.vw-winkler.de/Heckblenden-wie-Carat
http://www.syncro-werkstatt.de/MRB-Fahzeugtechnik.htm
http://syncro-services.com/en/drievtraingearboxbrakes
http://search.ebay.de/t3_Transporter_W0QQa38ZQ2d24...sofocusZbs
http://www.smallcar.com/index.php?dispatch=products.view&product_id=29803
http://www.t3technique.com/accessories/
pics
http://www.thesamba.com/vw/forum/album_page.php?pic_id=496617
http://www.youtube.com/watch?v=YGKlWqSadlQ&feature=related
http://air-mike.skynetblogs.be/archive-week/2008-39
http://i220.photobucket.com/albums/dd177/Scoobydubbydoo/IMG_1043.jpg
RockyMt activities
http://autos.groups.yahoo.com/group/Rocky-Mountain-Syncro-Fest/post
Syncro
http://www.actionmobil.at/
http://www.mufty.zabo.de/busdrivers/busdrivers.html
http://www.ihana.com/big_trip/index.htm
http://drewsweb.net/pdc04/default.htm
http://www.southing.com/links.htm
http://www.vanagonauts.com/index.phtml?catid=54
http://forums.vwvortex.com/zeroforum?id=33
http://www.vw-bus-land.de/
http://www.gelberbus.de/
http://users.rcn.com/jhecht/gypsy
http://www.relleumkrid.de/tunesien_99.html
http://home.earthlink.net/~matsuwesty/
http://www.buessli.ch/buessli.html
http://vw.transporter.free.fr/galerie/2004/
http://www.bulliportal.de/modules.php?op=modload&name=My_eGallery&file=index
http://www.geocities.com/stella_syncro/
http://www.weidefamily.net/vanagon/default.html
http://www.club80-90syncro.co.uk/
http://www.thesamba.com/vw/forum/viewtopic.php?t=219830&highlight=vanagon+manual
http://www.syncro-bernd-jaeger.de/ENGLISH/index.html
http://members.tripod.com/~wetwesties/index1.html
http://www.vwpix.org/eng/index.php
syncro accessories
http://www.gowesty.com/library.php
http://www.telusplanet.net/public/gary2a/rack/swingtire/swingtire.htm
http://www.vollstoff.de/VW_Typ2_T3/Syncro/syncro.html
http://www.syncrosource.com/index.html
http://www.syncro.photosite.com/
http://www.thesamba.com/vw/forum/viewtopic.php?t=102085
http://www.zebrastreifen.com/links/linksammlung.htm
http://www.sounddeadenershowdown.com/
http://camping.elliott.googlepages.com/aboutoursolarpowerrig
http://www.kustomcoachwerks.com/forums/viewtopic.php?t=2242
http://www.mogsrus.com/23082.html
http://www.funplace2b.co.uk/vw/upgrades.asp
http://secure.mycart.net/catalogs/catalog.asp?prodid=4757900&showprevnext=1
http://www.syncro-services.com/HP-Parts/E-Parts/mounting_gearprotector.pdf
Syncro font
http://www.mycorrado.com/font.html
SVXagon
http://www.thesamba.com/vw/forum/viewtopic.php?t=465355&sid=db0500f98000c0c9022fe40bc70ccb4f
http://autos.groups.yahoo.com/group/SVXVanagon/messages
http://www.outfrontmotorsports.com/subaru_JDM_motors.htm
http://wiki.club8090.co.uk/index.php/Main_Page
http://www.ultimatesubaru.org/forum/forumdisplay.php?f=42
http://motors.search.ebay.com/vanagon-subaru_eBay-...etaEndSort
http://www.subaru-svx.net/forum/forumdisplay.php?s=73c8aa70e6021ecdcec0ce560e063e30&f=41
Engine Prep
http://autos.groups.yahoo.com/group/subaruvanagon/files/ENGINE%20PREP/
http://www.turbovans.com/Stuff%20to%20do%20to%20Subaru%20Engine%20.html
http://www.smallcar.com/checklist.htm
http://www.graphics.cornell.edu/~v/b10scan/
http://www.benplace.com/vw2.htm
http://subaruvanagon.com/tom/Getting%20Started.htm
http://www.partsquick.com/SearchResults.asp?z=z&am...&s.y=0
http://www.salicos.com/TimingBelt.htm
http://autos.groups.yahoo.com/group/subaruvanagon/message/49564
http://autos.groups.yahoo.com/group/SVXVanagon/message/2656
http://www.maniacelectricmotors.com/hiou135ampal.html
http://subarupartspeople.com/searchproduct.asp?mod...ock+Heater
http://www.alcyone.org.uk/ssm/
Other people's conversions
http://public.fotki.com/loogy/photochops/
http://picasaweb.google.com/Madsen.Ken/KenAndCompanySubieConversion?pli=1ySubieConversion
http://www.thesamba.com/vw/forum/viewtopic.php?t=293764
http://www.thesamba.com/vw/forum/viewtopic.php?t=198281
http://www.vwkd.co.uk/bb/viewtopic.php?t=1561&postdays=0&postorder=asc&start=24
http://www.thesamba.com/vw/forum/viewtopic.php?t=237938
http://www.primafoundry.com/cars/Doka%20SVX.htm
http://www.primafoundry.com/cars/SVX%20Doka%20Project%20Diary.htm
http://www.flickr.com/photos/18824076@N03/2979476538/
http://www.flickr.com/photos/jetstar5224/sets/
http://www.shoptalkforums.com/viewtopic.php?f=19&t=136053
Syncaru Conversion
http://home.ec.rr.com/miktip/page2.htm
http://my.tbaytel.net/guskers/gauges.html
http://www.turbovans.com/SVX%20HEADERS.html
http://vanperformance.com/SVXcoolantsystem.htm
http://www.vanperformance.com/catalog.htm
http://www.outbackmotors.com/index.html
http://forums.vwvortex.com/zerothread?id=2954357
http://www.canardzone.com/members/PhillipJohnson/Engine/subaru_EG33.htm
http://forums.vwvortex.com/zerothread?id=2969205&page=2
http://www.subaruvanagon.com/tom/Getting%20Started.htm
http://www.brick-yard.co.uk/forum/forum_posts.asp?TID=27684
http://www.brick-yard.co.uk/forum/forum_posts.asp?TID=28339&KW=Subaru+Install
http://subyjake.googlepages.com/smallcarbellhousing
http://bb.bbboy.net/vwengineconversions-viewthread?forum=3&thread=236
Parts Places
http://www.subaruparts.com/diag/?model=2A&year...ory=013A-1
http://store.yahoo.com/svx-motorsport-accessories/performance.html
http://importedcarparts.com/
http://www.rmwesty.com/index.php?page=shop.browse&option=com_virtuemart&Itemid=1
Install
exhaust
Coolant lines
http://www.benplace.com/subaru_ej_25.htm
http://www.thesamba.com/vw/forum/viewtopic.php?t=3...p;start=15
http://www.benplace.com/mike_syncro/mike107.jpg
http://www.subaruvanagon.com/tom/Cooling%20System.htm
power steering
http://autos.groups.yahoo.com/group/SVXVanagon/message/2441
http://www.weidefamily.net/vanagon/HTML/05/main.html
http://autos.groups.yahoo.com/group/SVXVanagon/message/2896
http://autos.groups.yahoo.com/group/subaruvanagon/messages/36323?xm=1&m=s&l=1
http://www.subaruparts.com/diag/?model=2A&style=4WD&body=&year=1997&scn=0
http://www.salicos.com/EG-33Progress.htm
http://www.vwrx.com/
http://www.krautwagen.com/My%20Subaru%20Vanagon%20Conversion%20Page.htm
http://www.weidefamily.net/vanagon/HTML/05/06/slideshow.html
http://www.salicos.com/EGIntro.htm
http://www.vwrx.com/forum/index.php?board=4;action=display;threadid=38
http://forums.vwvortex.com/showthread.php?2954357
http://www.rv8.ch/index.php?topic=wiring
http://vanagonsyncroproject-herman.blogspot.com/se...-results=8
http://forums.vwvortex.com/showthread.php?2969205/page2
http://www.thesamba.com/vw/forum/viewtopic.php?t=222760&postdays=0&postorder=asc&start=0
http://www.thesamba.com/vw/forum/viewtopic.php?t=445880
http://www.thesamba.com/vw/forum/viewtopic.php?t=4...;start=100
http://www.thesamba.com/vw/forum/viewtopic.php?t=5...e7141dee90
http://www.thesamba.com/vw/forum/viewtopic.php?t=480072
SVXagon Harness
https://groups.yahoo.com/neo/groups/subaruvanagon/conversations/messages/66570
https://groups.yahoo.com/neo/groups/subaruvanagon/conversations/messages/65059
https://groups.yahoo.com/neo/groups/subaruvanagon/conversations/messages/65051
Splitties
http://www.ssvc.org.uk/phpbb/viewtopic.php?f=8&t=30570&start=197
http://www.ssvc.org.uk/phpbb/viewtopic.php?f=46&t=54359&start=0
http://www.volksfahrer.nl/copper18/thumbnails.php?album=toprated&cat=2
http://www.klassicfab.com/marcos.htm
http://www.type2.com/bartnik/csmanual.htm
http://kustomcoachwerks.com/gallery/main.php?g2_vi...87b123ce17
http://www.v6bus.de/v6tdi/index.html
SVXagon NEW
https://groups.yahoo.com/neo/groups/subaruvanagon/files/Wiring%20/%20WIRING%20LENGTH%20CHARTS/
http://doogielabs.com/2010/04/blog-for-saturday-april-10th-2010/
Vanagon Bumpers
http://www.thesamba.com/vw/forum/viewtopic.php?t=512668&highlight=bumper
http://www.thesamba.com/vw/forum/viewtopic.php?t=614400
http://www.thesamba.com/vw/forum/viewtopic.php?p=7499469&highlight=#7499469
http://www.thesamba.com/vw/forum/viewtopic.php?t=616841&highlight=bumper
http://www.thesamba.com/vw/forum/viewtopic.php?t=544143&highlight=bumper
http://picasaweb.google.com/101290228103300323836/...2201103922
Vanagon Starter
http://www.thesamba.com/vw/forum/viewtopic.php?p=7556432&highlight=adapter+diesel+tdi#7556432
http://www.westyventures.com/parts.html
The Syncro years (2005-16) - The 2WD years (2017-23) - Westy & WBX rebuild spreadsheet - Sanchius & Tuna: The Video
Your gold star membership keeps this awesome list going!
djkeev
djkeev is offline
PostPosted: Mon Jan 18, 2016 7:14 am    Post subject: Re: Share some build threads | I am building a 1987 Vanagon Reply with quote
Whoa!
We should put you in charge of FAQ's / Stickies!
Dave
Chad
Thanks for asking!
Vanagon links
Vanagon Engine
AFM
Coolant change
Engine rebuild
Head gasket
O2 Sensor
Oil leak
Oil Pressure
No Start - No Spark
No Start - no crank
Water Pump
Vanagon Fuel
Fuel hose renewal
Fuel tank
Vanagon Brakes
Vanagon Drivetrain
CV joints
Diff Lock
Front Diff Lock
Clutch
cv joint
Audi Wheels
wheel studs
brake upgrade
Suspension renew
swaybar
wheel bearing
Driveshaft
VC rebuild
Transmssion
2wd transmission
wheel bearings
Shifter
Vanagon Heater/AC
AC
front heater fix
Furnace
Vanagon Electrical
cb radio
Gauges: Temp gauge
Headlights
taillights
Vanagon Exterior
Awning
bodywork
Body: slider
$50 paint job
painting the bumper
spare tire holders
trim painting
Vanagon Interior
Seats
Interior
Steering Wheel
Rear hatch release
Gauges: Tach
Expeditions
Vanagon Videos
MOAB
Mods
Parts Places
pics
RockyMt activities
Syncro
syncro accessories
Syncro font
SVXagon
Engine Prep
Syncaru Conversion
Parts Places
Install
exhaust
Coolant lines
power steering
SVXagon Harness
Splitties
SVXagon NEW
Vanagon Bumpers
Vanagon Starter
Ghia
Vanagon
Beetle
nacradriver
nacradriver is offline
PostPosted: Mon Jan 18, 2016 7:45 am    Post subject: Re: Share some build threads | I am building a 1987 Vanagon Reply with quote
That list is awesome.... Thank you
Güdrun -1989 Westfalia - 2013 - 2018
Petra - 1985 Vanagon - 1985 to 1991
Zisa - 1974 VW Van "Bus" - 1974 to 1985
djkeev
djkeev is offline
PostPosted: Mon Jan 18, 2016 10:33 am    Post subject: Re: Share some build threads | I am building a 1987 Vanagon Reply with quote
That's why I quoted it...... Even if the OP changes it, the original list survives! Wink
Dave
Ghia
Vanagon
Beetle
BlueNorthWesty
BlueNorthWesty is offline
PostPosted: Mon Jan 18, 2016 8:34 pm    Post subject: Re: Share some build threads | I am building a 1987 Vanagon Reply with quote
Welcome and good luck. I built my first Vanagon Westy last year. You'll probably be done yours before you get through half of the list above but just in case you're a fast browser, click my build below.
1984 Medium Blue Vanagon Westfalia 2WD w/ rebuilt Auto, Peloquin differential, 3.27 R&P gears, 2002 Subaru 2.5L engine, Girling G60 front brake upgrade, PS, power mirrors
Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=610481&highlight=
ahmadahere
PostPosted: Mon Jan 18, 2016 11:35 pm    Post subject: Re: Share some build threads | I am building a 1987 Vanagon Reply with quote
I just got mine painted.
slo356
slo356 is offline
PostPosted: Mon Jan 18, 2016 11:42 pm    Post subject: Re: Share some build threads | I am building a 1987 Vanagon Reply with quote
LOOKS very blue! Is that 356 Porsche Meissen Blue? If not, its very close.
'65 T1 Sedan
'87 T3 Syncro
ahmadahere
PostPosted: Tue Jan 19, 2016 12:15 am    Post subject: Re: Share some build threads | I am building a 1987 Vanagon Reply with quote
It is a 2015 VW Beetle color called Denim Blue.
djkeev
djkeev is offline
PostPosted: Tue Jan 19, 2016 4:55 am    Post subject: Re: Share some build threads | I am building a 1987 Vanagon Reply with quote
That's the color my Wife wants on her Ghia...... If and when I get back to it!
Dave
Ghia
Vanagon
Beetle
boroko
boroko is offline
PostPosted: Tue Apr 26, 2016 9:18 am    Post subject: Re: Share some build threads | I am building a 1987 Vanagon GL Reply with quote
Nice list! You just about made my bookmarks obsolete.
Thanks bunches for taking the time to post it.
Mark
'87 SyncroWesty: Smokey the Turtle, '85 SubiWesty: Chappie, '84 GTI, '86 GTI in full Rally trim,
previous: 2 Syncro tin tops, 2 Vanagons, 3 busses, 3 Ghias, 2 Jettas, a 411, a gas and a diesel Bunny and about 25 Beetles, one that only drove left.
0cean
0cean is offline
PostPosted: Tue Apr 26, 2016 9:55 am    Post subject: Re: Share some build threads | I am building a 1987 Vanagon GL Reply with quote
Check out Insyncros build threads and SyncroGregs build. I'm always going through them for inspiration and information.
I'm not a mechanic, I just play one on the internet
Cluster Rebuild:
http://www.thesamba.com/vw/forum/viewtopic.php?t=569920&highlight=
Left for Dead the Resurrection Story Build:
http://www.thesamba.com/vw/forum/viewtopic.php?t=613669
(Number of Different Donor VW Vans Body Parts Used: 12)
(Number of completely different vehicles parts used: 3)
