eche_bus Samba Member
Posted: Tue Jan 19, 2016 7:08 pm Post subject: Engine hatch weatherstrip gluing advice needed |
I'm replacing the outside engine hatch weatherstrip and could use a little gluing advice. The new one-piece weatherstrip is made of EPDM and so isn't as stiff as OG, and I've found it won't stay in place without gluing. I can see clearly that VW originally used a thin line of glue under the whole length of this weatherstrip to hold it in place.
I've got 3M Super Weatherstrip Adhesive on hand, but my experience is with applying it to both surfaces, then waiting for it to stop being tacky. Touching the two surfaces together then grabs immediately. Trouble is, I need to be able to shift the weatherstrip around enough to make sure it goes into/over the metal channel properly, so this just isn't going to work.
Q: Is there another glue I should use here or is there another technique using 3M Super Weatherstrip Adhesive that allows a little time to move things around but still bonds properly once dry?
Thanks! |
SGKent Samba Member
Posted: Tue Jan 19, 2016 7:16 pm Post subject: Re: Engine hatch weatherstrip gluing advice needed |
put it down without glue. Use a pencil to make marks every at the beginning and every 1' or so. Lay it down and see if you have too much or too little at the end. Adjust your marks until you get it right - then do the glue. If it is like mine, 3M won't hold it for long as the pressure in the corners will pull it loose. Use the hatch to hold it down for a few days until the glue really sets up. I have yet to find a hatch seal as flexible as the originals but the ones sold will work if you leave the hatch on long enough for it to take a set. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Tue Jan 19, 2016 7:29 pm Post subject: Re: Engine hatch weatherstrip gluing advice needed |
SGKent wrote: |
put it down without glue. Use a pencil to make marks every at the beginning and every 1' or so. Lay it down and see if you have too much or too little at the end. Adjust your marks until you get it right - then do the glue. If it is like mine, 3M won't hold it for long as the pressure in the corners will pull it loose. Use the hatch to hold it down for a few days until the glue really sets up. I have yet to find a hatch seal as flexible as the originals but the ones sold will work if you leave the hatch on long enough for it to take a set. |
I've done a dry fit by installing the entire seal and it fits well, including the corners and where the two ends come together at the bottom. So amazingly (for aftermarket) there is neither too much or too little length.
My concern is that if I apply the 3M glue to the seal and to the bus, then as soon as I set the seal into place, the glue will grab and prevent me from getting the groove in the seal to seat properly over the metal flange that runs around the opening.
I know I could just apply glue to the bus and not the seal, but I don't think I've seen that work in the past so am uneasy to do so. |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Posted: Tue Jan 19, 2016 9:57 pm Post subject: Re: Engine hatch weatherstrip gluing advice needed |
eche_bus wrote: |
SGKent wrote: |
Use your marks as you go to know if you're putting it back from the dry fit correctly. If they are every inch or so and continue to line up as you're going along, you'll know that at the end, it'll not be too stretched or anything and will fit. _________________ Dave Cook
1973 Wild Westerner
My Thing |
Busstom Samba Member
Joined: November 23, 2014 Posts: 3841 Location: San Jose, CA
Posted: Tue Jan 19, 2016 10:36 pm Post subject: Re: Engine hatch weatherstrip gluing advice needed |
I see what you're saying, about sort of angling the seal into place while tucking the inner edges under the flange without getting it stuck. Maybe if you apply the adhesive surgically to the very outer edges only, both on the body and the seal...that would minimize the chances of catching before getting it tucked. (By the outer edges, I still mean the gluing "face" of the sealing surface, not the top, bottom, and sides of the frame, so to speak.)
I'll be up against this job pretty soon here, and SGKent got me thinking...if I can find an adhesive that only needs to be applied to one surface, and doesn't need to flash tacky, then maybe it can be set, restrained if necessary with a few pieces of blue tape, then shut the lid and let it cure. If I recall, mine didn't have that much glue, and the seal pulled out fairly cleanly, unlike a lot of seals do (leaving tons of remnants behind)...it probably doesn't need all that much glue for the purpose there. |
Tcash Samba Member
Posted: Wed Jan 20, 2016 8:08 am Post subject: Re: Engine hatch weatherstrip gluing advice needed |
Throw the seal in the dryer on low heat until is is pliable. You need a slow set product like this 3M™ Scotch-Weld™ Instant Adhesive CA5 Clear. For clean up 3m 08984.
Good luck
Tcash |
Posted: Wed Jan 20, 2016 11:49 am Post subject: Re: Engine hatch weatherstrip gluing advice needed |
The method SGKent suggested to keep track of stretch is a great tip.
The issue that Busstom highlighted is the main one I was getting at. Whereas the base of the seal pretty much just lays into place, the flange/slot edge of the seal requires some fiddling with to get pressed into place in a straight line. The idea to angle the seal into place is spot on. The challenge is doing this with a 3-4 foot long piece of wiggly rubber that gravity wants to pull off the flange. I'm convinced the original seal would stay in place, but I've already experienced that this new seal doesn't have the stiffness or molded features sufficient to perform this way.
Perhaps a way to do this is to first apply glue to the seal and bus and let dry to the touch as per directions. Then, drape sheets of paper (Post-It Notes?) over the glue on the bus, to allow the seal to be inserted around the flange without risking contact with the bus glue. Then, with a section of the seal in place, remove a sheet of paper, press the section of seal to the bus, and repeat.
Tcash - thanks for the tip about the Scotch-Weld Adhesive. I'm going to experiment with using the 3M Super Weatherstrip Adhesive using some scrap first, and consider that next. |
Tcash Samba Member
Posted: Wed Jan 20, 2016 12:16 pm Post subject: Re: Engine hatch weatherstrip gluing advice needed |
What about double back sticky tape? That would allow you to peel as you go and re-position the seal if needed.
Tcash |
rodgersbadassbus64 Samba Member
Joined: January 24, 2009 Posts: 417 Location: Ortonville, Minnesota
Posted: Wed Jan 20, 2016 8:31 pm Post subject: Re: Engine hatch weatherstrip gluing advice needed |
Super glue works great. I also use it for my safaris on my splitty |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21512 Location: Oklahoma City
Posted: Wed Jan 20, 2016 9:24 pm Post subject: Re: Engine hatch weatherstrip gluing advice needed |
Scotch weld IS superglue (cyanoacrylate). Its a little crispy and hard ro get off if need be. We use it for permanent assembly of surgical foams to plastics.
A high tack silicone RTV applied to one surface would be best. Ray |
ron3865 Samba Member
Posted: Wed Jan 20, 2016 10:36 pm Post subject: Re: Engine hatch weatherstrip gluing advice needed |
I used Loctite Black Contact Adhesive on the engine hatch and door seals. Apply a couple of spots to one side (just enough to hold it in) and it works great. Trouble is that Loctite doesn't make it anymore but I found it online at Zoro.com. I should have bought a couple of tubes as I find I use it for quite a few jobs.
If you want a real pliable seal get one from Wolfsburg West. They make one that is in 4 parts and you trim for final length. Was almost too easy to install. Just use a few dabs of adhesive as it stays in pretty well by itself. |
Posted: Wed Jan 20, 2016 11:04 pm Post subject: Re: Engine hatch weatherstrip gluing advice needed |
ron3865 wrote: |
Really?.....i have no issues finding it online. Loctite 380.
Bear in mind that Loctite is owned by Henkel.....has been for a while. They may be changing some names and part #s. Ray |
speedystar77 Samba Member
Joined: June 26, 2015 Posts: 76 Location: South Central Idaho
Posted: Thu Jan 21, 2016 10:09 am Post subject: Re: Engine hatch weatherstrip gluing advice needed |
FWIW I did this weeks ago and used a thin layer of black Permatex (?) automotive weatherstrip adhesive. I could not get it to stay in position without the adhesive. I had something on hand (silicone solvent) to wipe away any excess while it was still wet. Everything is holding well so far. It did take a few days of hatch closed to get it compressed where the lid latches easily like it did with the original seal. _________________ 1974 Baywindow Westfalia Bus
Tintop Campmobile
Production date: November 29, 1973
1700 cc engine with manual transmission
32/36 DFEV Weber Progressive |
Posted: Thu Jan 21, 2016 10:47 am Post subject: Re: Engine hatch weatherstrip gluing advice needed |
raygreenwood wrote: |
ron3865 wrote: |
Finding it on line was no problem but locally,..Walmart, O'Rielly"s, Ace, Home Depot, etc. didn't have it. When I called the # for Loctite i gave them the product name and # and was told they dropped it from their line and anything out thee was old stock. I hope that info is wrong as that stuff is great for a lot of applications. |
Posted: Thu Jan 21, 2016 11:25 am Post subject: Re: Engine hatch weatherstrip gluing advice needed |
ron3865 wrote: |
ron3865 wrote: |
Hmmmm...interesting! This is of interest to me as Henkel is a major player in my industry...and lots of things are shaking up and consolidating right now....especially with the merger of DuPont and Dow.
There are more than a few nearly identical products on the market so the few times I actually use the Henkel product....its not a huge issue for me...but it is a very good and consistent product. Ray |
Tcash Samba Member
Posted: Thu Jan 21, 2016 12:06 pm Post subject: Re: Engine hatch weatherstrip gluing advice needed |
I appreciate all the anecdotes and ideas and am honestly taking it all into consideration. I'll reiterate that the crux of the issue is that it's TOO flexible as it readily falls out of the flange, just like speedystar77 points out. We're not talking about installing an OG VW seal here which seems more likely to stay put without or with a minimum of glue.
This new seal is made from EPDM, which from a little research last night, I discovered is actually pretty tough to glue.
Cyanoacrylate glue: Yes, that will bond to it, but this class of glue is notorious for a lack of durability in humid environments. Perhaps ScotchWeld is somehow different, so its not entirely out of the question.
3M Super Weatherstrip Adhesive: Turns out the yellow 3M Super Weatherstrip Adhesive I had on hand isn't recommended for use with EPDM. 3M says to use their black one for EPDM (and I thought the only difference was color). Trouble is, it isn't repositionable. Coat both surfaces, touch together, and it GRABS. I'm holding off on this for now.
Permatex Black Super Weatherstrip Adhesive or Weatherstrip Cement (clear): This is the only family other than ScotchWeld that represents itself as repositionable. I spoke with Permatex this morning to ask how long can be repositioned. The answer was "not tested, but it's a modified contact adhesive to allow repositioning". Then I asked which product was recommended for use with EPDM, as their website doesn't say. The answer was "I don't know. I'll have to ask the lead chemist and get back to you." So waiting to hear back.
Loctite Black Contact Adhesive: it's a contact cement and isn't represented as repositionable or for use with EPDM. If someone here can tell me otherwise, I'd be very happy.
Hi Tack RTV: Will this actually bond EPDM? |
poptop tom Samba Member
Joined: July 27, 2004 Posts: 1607 Location: The Hoosier State
Posted: Thu Jan 21, 2016 12:25 pm Post subject: Re: Engine hatch weatherstrip gluing advice needed |
Yes, found that last night, thanks. This is actually where some of my concern comes from about bonding EPDM. It recommends Cyanoacrylates, but highlights the potential moisture issues. |
Tcash Samba Member
Posted: Thu Jan 21, 2016 12:29 pm Post subject: Re: Engine hatch weatherstrip gluing advice needed |
Would it be worth asking if there is something you can mix with the Adhesive to retard the set time?
Tcash |
