vanis13 Samba Member
Joined: August 15, 2010 Posts: 3100 Location: ABQ NM USA.... Except when not
Posted: Tue Jan 19, 2016 10:09 pm Post subject: Emergency brake light only on in start |
The only time the E Brake light is on is when the engine is cranking. I’ve checked the switch at the E brake and that one seems to be doing what it should (going in an out)
Also it seems the seatbelt light is not working how it should.
Before I go playing in the rats nest, I’d love some hints from those in the know what to look for and how the circuit works.
Thanks, _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
Posted: Thu Jan 21, 2016 8:42 am Post subject: Re: Emergency brake light only on in start |
bump _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
B.O.B.Wanders Samba Member
Joined: July 22, 2014 Posts: 351 Location: Atlanta, GA USA
Posted: Thu Jan 21, 2016 3:58 pm Post subject: Re: Emergency brake light only on in start |
I had the opposite problem where the e-brake light would come on every time the main brake pedal was pressed and it was related to the brake pressure switches on the master cylinder.
I replaced the faulty switch and the issue went away. You might find some useful info in this thread:
http://www.thesamba.com/vw/forum/viewtopic.php?t=5...ning+light _________________ 83.5 WBX 2WD Assuan Brown Westy, B.O.B.
"It feels good to be lost in the right direction” - unknown |
gertiebob Samba Member
Joined: February 23, 2015 Posts: 167 Location: Seattle
Posted: Wed Mar 14, 2018 7:30 am Post subject: Re: Emergency brake light only on in start |
Is there an answer for this particular problem. I have that exact issue as of this morning. Light was working properly one minute, next this glowing while cranking starter only.
I see the word "bump" but that is a bit mysterious... I did "bump" the cluster near the light....
Hmmmmm.
Oh, and I mean the original question.
Thanks! |
Abscate Samba Member
Posted: Wed Mar 14, 2018 8:25 am Post subject: Re: Emergency brake light only on in start |
"Bump" is someone adding a response to the thread to move it back to the top of the page for viewing.
Electrical problems have many possible answers, not just one.
Here, I would inspect the brake wiring and the grounds, as lights that come on at weird times are usually ground faults finding new paths. _________________ .ssS! |
Slimvest Samba Member
Joined: March 20, 2014 Posts: 431 Location: Portland, OR
Posted: Wed Mar 14, 2018 8:27 am Post subject: Re: Emergency brake light only on in start |
Had this issue. Bad connection at the ebrake pin switch located in the brake handle assembly. _________________ '87 GL w/ Reimo top |
Posted: Wed Mar 14, 2018 12:03 pm Post subject: Re: Emergency brake light only on in start |
Thanks Slimvest! Of course I should have checked obvious thing first.
Seemed odd that light came on when cranking starter and not otherwise.
Switch at handle was sticking then popping up after awhile while parked with e-brake on...
A bit of silicon lube fixed. |
