Californio Samba Member
Posted: Mon Jan 25, 2016 5:17 pm Post subject: Help identifying Syncro springs |
I'm thinking of replacing my shocks and/or springs to give my 87 Syncro Westy a softer ride--right now it loosens your fillings when you hit a bump.
How can you tell what springs you have?
Right now it's fitted with OME shocks all around, and the springs are either painted or powder coated black. Since this was done by the PO, I have no idea what the springs are.
Any Syncro/Westy springs that would have been on the market 7-15 years ago, black in color, that someone might have mated to OME shocks?
If I can't get OEM shocks on there without replacing the springs to match, I'm considering the VC Trailmaster kit. |
hans j Samba Member
Joined: May 06, 2006 Posts: 2714 Location: Salt Lake City UT
Posted: Mon Jan 25, 2016 5:27 pm Post subject: Re: Help identifying Syncro springs |
You can measure the wire diameter and do some calculations and get the rate. More than likely, they are too stiff because I know OME aren't stiff.
Shwenk springs now has some lighter duty springs that I'm thinking about trying. I've never liked stiff springs. _________________ 1986 Canadian Syncro Westy TDI - 1989 Syncro Single Cab - 2001 Audi S4 - 1981 VW Caddy ABA - 1980 VW Caddy EV - 1973 VW T-181 |
Posted: Mon Jan 25, 2016 5:39 pm Post subject: Re: Help identifying Syncro springs |
Good information.
Another question. Could a bad shock/spring combination produce a handling problem? Everything in the steering system has been replaced, even to the gearbox, but it still drives as though it has slop in it, esp. at 50-65 mph. It is NOT a wheel/tire problem, a steering system problem, or an alignment problem.
This is why we're thinking shocks and springs, unlikely as that may be. |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6346 Location: Honolulu,Hawaii and France
Posted: Mon Jan 25, 2016 5:47 pm Post subject: Re: Help identifying Syncro springs |
Yes but I thought this was only for OEM, which weren't painted. These are shiny black if you scrape the crud off. |
insyncro Banned
Posted: Mon Jan 25, 2016 8:19 pm Post subject: Re: Help identifying Syncro springs |
Stock Springs are powder coated and have paint marks to identify. |
Posted: Mon Jan 25, 2016 10:44 pm Post subject: Re: Help identifying Syncro springs |
OK time to get out the pressure washer and see what's what. I thought the OEM springs were raw steel. |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12005 Location: Santa Cruz, CA
Posted: Mon Jan 25, 2016 10:59 pm Post subject: Re: Help identifying Syncro springs |
Stock springs taper at the ends of the coils, aftermarket springs are the same size all the way to the end.
Stock springs are nice and soft so I would assume you have a aftermarket version. |
Posted: Thu Jan 28, 2016 11:16 am Post subject: Re: Help identifying Syncro springs |
So I just had the van aligned and it turns out the ride height is lower than it should be--18" on one side, 18.5" on the other. This made it so the alignment guy had to manually enter 20" to get the specs from his machine.
In 2014 I drove for about 8K miles with a motorcycle on the front (Honda CT70, maybe 220 lbs. including the rack) through all kinds of territory including hundred of miles of washboard in Saline Valley to 5,000 miles on the interstate from CA to Washington DC...etc.
Question: Is it time to replace springs and if so, how can I compensate for the (now occasional) weight of the CT70 on the front?
I've been thinking of the VC Trailmaster set up because it's integrated and seems to have gotten good reviews. |
hans j Samba Member
Posted: Thu Jan 28, 2016 11:54 am Post subject: Re: Help identifying Syncro springs |
Cutting board spacers to raise up the low side will work just fine. _________________ 1986 Canadian Syncro Westy TDI - 1989 Syncro Single Cab - 2001 Audi S4 - 1981 VW Caddy ABA - 1980 VW Caddy EV - 1973 VW T-181 |
Posted: Thu Jan 28, 2016 4:16 pm Post subject: Re: Help identifying Syncro springs |
Sounds like a good start, but I though you could only put spacers on the rear. |
hans j Samba Member
Posted: Thu Jan 28, 2016 4:30 pm Post subject: Re: Help identifying Syncro springs |
I'd start with the rear and see where the front ends up. Corner weighting does funny things to opposite springs! I've seen some aluminum front spacers used in some kits, but that would probably be too much height. _________________ 1986 Canadian Syncro Westy TDI - 1989 Syncro Single Cab - 2001 Audi S4 - 1981 VW Caddy ABA - 1980 VW Caddy EV - 1973 VW T-181 |
