Larry's 1962 Single Cab Resto "Brrt Brrt"
Page: Previous  1, 2, 3 ... 12, 13, 14 ... 19, 20, 21  Next
Aircool67
Aircool67 is offline
PostPosted: Thu Jun 07, 2018 3:51 pm    Post subject: Re: Larry's 1962 Single Cab Resto "Brrt Brrt" Reply with quote
Looking beautiful!!
Larry, Aircool Designs
[email protected]
Fifty-Eight Rag
Fifty-Eight Rag is offline
PostPosted: Fri Jun 08, 2018 12:06 pm    Post subject: Re: Larry's 1962 Single Cab Resto "Brrt Brrt" Reply with quote
Left side A pillar in.
This one took some persuading because the A pillar was twisted from the previous wreck, but I got it back in line.
1956 Oval
and a barn full of VW parts
1956 Oval build thread
1962 Single Cab Restoration
http://www.thesamba.com/vw/forum/viewtopic.php?p=7959298#7959298
1967 Beetle Restoration
http://www.thesamba.com/vw/forum/viewtopic.php?t=495269&highlight=larrys
Fifty-Eight Rag
PostPosted: Sun Jun 10, 2018 1:04 pm    Post subject: Re: Larry's 1962 Single Cab Resto "Brrt Brrt" Reply with quote
Got the support welded in.
Time to start fitting for a nose job.
Trying to keep as much OG nose as possible.
Fitting nicely.
Once I get this where I want it I'll mark and then locate the lower nose panel first.
1956 Oval
Fifty-Eight Rag
PostPosted: Tue Jun 12, 2018 9:43 am    Post subject: Re: Larry's 1962 Single Cab Resto "Brrt Brrt" Reply with quote
Lower nose panel welded on
1956 Oval
ryans65
ryans65 is offline
PostPosted: Tue Jun 12, 2018 6:46 pm    Post subject: Re: Larry's 1962 Single Cab Resto "Brrt Brrt" Reply with quote
This might be obvious to you but it was totally a duh moment for me BUT: did you make sure your lower hammered lip area of your nose panel interfaces with the lip on your outer valence and also your butt weld seam before you welded it on? I got lucky on mine and it was stupidly close but I had that sinking feeling at one point after the out valence was on where I went hmmmmmmmm and started getting clammy!
Fifty-Eight Rag
PostPosted: Tue Jun 12, 2018 7:01 pm    Post subject: Re: Larry's 1962 Single Cab Resto "Brrt Brrt" Reply with quote
Very Happy Yep...I pre-fitted the nose and marked the lip location on the A pillars so I had reference points. I also have been using a plumb bob for dead center.
1956 Oval
ryans65
ryans65 is offline
PostPosted: Wed Jun 13, 2018 7:18 am    Post subject: Re: Larry's 1962 Single Cab Resto "Brrt Brrt" Reply with quote
Haha nice! I'm still thinking about how lucky I got on that one lol. It just never crossed my mind when I was doing my lower nose work!
Fifty-Eight Rag
PostPosted: Mon Jul 16, 2018 7:27 pm    Post subject: Re: Larry's 1962 Single Cab Resto "Brrt Brrt" Reply with quote
Been awhile since an update so I guess it's time Cool
Got the lower nose skin fitted and welded
1956 Oval
Fifty-Eight Rag
PostPosted: Mon Jul 16, 2018 7:45 pm    Post subject: Re: Larry's 1962 Single Cab Resto "Brrt Brrt" Reply with quote
Started fitting the left dogleg next.
Setting door gaps first...had to heat and tweak the lower hinge a little.
Got it to pull in pretty straight
Welded in
1956 Oval
Fifty-Eight Rag
PostPosted: Mon Jul 16, 2018 7:58 pm    Post subject: Re: Larry's 1962 Single Cab Resto "Brrt Brrt" Reply with quote
Finishing up lower wheelhouse and left side floor section.
1956 Oval
Fifty-Eight Rag
PostPosted: Mon Jul 16, 2018 8:27 pm    Post subject: Re: Larry's 1962 Single Cab Resto "Brrt Brrt" Reply with quote
On to the right side...this one will take much more repair. This section appears to have some old wreck damage that is wrinkled and ugly, plus some blobs of brass all along the outer edge where someone brazed it.
I put a WTB on the classifieds and was fortunate enough to locate a really clean section from a Samba member.
Right side done
1956 Oval
Burlyhammer
Burlyhammer is offline
PostPosted: Tue Jul 17, 2018 4:39 pm    Post subject: Re: Larry's 1962 Single Cab Resto "Brrt Brrt" Reply with quote
Looking good. Great job on that driver door gap!
BulliBill
BulliBill is offline
PostPosted: Wed Jul 18, 2018 10:13 am    Post subject: Re: Larry's 1962 Single Cab Resto "Brrt Brrt" Reply with quote
Man! You are knockin' it out, way to go!
Bill Bowman
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help!
Fifty-Eight Rag
PostPosted: Wed Jul 18, 2018 10:25 am    Post subject: Re: Larry's 1962 Single Cab Resto "Brrt Brrt" Reply with quote
Thanks guys! Very Happy
1956 Oval
Fifty-Eight Rag
PostPosted: Fri Dec 28, 2018 11:56 am    Post subject: Re: Larry's 1962 Single Cab Resto "Brrt Brrt" Reply with quote
Trying to shake off the winter blahs as well as recovering from rotator cuff surgery. I dug through photos of this build that haven't been posted online yet and realized I forgot to bring everyone up to the current level of progress.
Larry's truck was missing the correct 2 year only humpback seat which proved to be scarce as hens teeth to find as well as needing a king's ransom to obtain.
His truck did however come with a mismatch of a seat bottom from the rear of a double cab and a seat back from a pre 1961 bus. We're going to make these work. First we found a set of pre '61 seat back rests and I fitted them. Next I'll make some supports for the seat bottom.
1956 Oval
Fifty-Eight Rag
PostPosted: Fri Dec 28, 2018 12:11 pm    Post subject: Re: Larry's 1962 Single Cab Resto "Brrt Brrt" Reply with quote
Finished the repaired wheel houses and floors ready for paint.
Also, Larry wants to keep this truck looking fairly stock but wanted a modern stereo to crank up his favorite German Polkas. He bought a RetroSound stereo that looks like a stock VW radio but has modern innerts. We also devised a plan to hide the speakers behind/underneath the seat.
Larry made this stealthy speaker mount that slides under the double cab seat bottom since it is straight across like a barn door seat and doesn't drop down to follow the contours of the 1962 floor.
1956 Oval
Fifty-Eight Rag
PostPosted: Fri Dec 28, 2018 12:18 pm    Post subject: Re: Larry's 1962 Single Cab Resto "Brrt Brrt" Reply with quote
The last thing I did before shutting down for my shoulder surgery was to replace the lower windshield surround.
1956 Oval
62DoKaGuy
62DoKaGuy is offline
PostPosted: Mon Jan 14, 2019 9:30 am    Post subject: Re: Larry's 1962 Single Cab Resto "Brrt Brrt" Reply with quote
Repairing another rotten hinge mount. Same technique as the other side.
Taking a section from a bus rear hatch repair piece
This post and approach saved me a load of headache, grief, frustration, and time. Don't know why I didn't think about this before, but I fortunately came across this post recently, while avoiding the treasure chest hinge mount repairs on my own single cab haha.
After decades, the original treasure chest door can be mounted to the body instead of sitting in the storage compartment haha!
Thanks!
,,Wenige Menschen denken, und doch wollen alle entscheiden.'' -der Alte Fritz
...I went at it from both ends but going from the rear didn't seem to do anything, although I did spray some rust breaker in there...
4/62 Double Cab
5/61 Panel (sold)
4/59 Single Cab (sold)
Fifty-Eight Rag
PostPosted: Mon Jan 14, 2019 9:36 am    Post subject: Re: Larry's 1962 Single Cab Resto "Brrt Brrt" Reply with quote
Thanks!
No problem...glad my twisted mind could help. Cool
1956 Oval
BulliBill
PostPosted: Mon Jan 14, 2019 9:38 am    Post subject: Re: Larry's 1962 Single Cab Resto "Brrt Brrt" Reply with quote
I hope your shoulder surgery went well and I wish you a speedy and full recovery! Nice work you are doing on this Transporter!
Bill Bowman
Page 13 of 21
