Where should I put my fog lights? |
Inside the overriders |
88% |
[ 23 ] |
Outside the overriders |
11% |
[ 3 ] |
Total Votes : 26 |
BayCreamPuff Samba Member
Joined: August 10, 2015 Posts: 769 Location: Oakland, CA
Posted: Mon Feb 01, 2016 5:48 pm Post subject: Opinion: Best Position For Front Fog Lights |
Inside
Outside
_________________ Cream Puff
'79 CA Stock FI Deluxe Campmobile
Earl Grey
'87 GoWesty 2.2 Westfalia
Marsha Mellow
'00 Eurovan VR6 Full Camper |
richparker Samba Member
Joined: November 24, 2011 Posts: 6983 Location: Durango, CO
zoobum Samba Member
Joined: June 09, 2015 Posts: 211 Location: Los Angeles
Posted: Mon Feb 01, 2016 8:06 pm Post subject: Re: Opinion: Best Position For Front Fog Lights |
^^2x for inside. |
awreed Samba Member
Joined: January 14, 2010 Posts: 1268 Location: Kirkland, WA
Posted: Mon Feb 01, 2016 9:10 pm Post subject: Re: Opinion: Best Position For Front Fog Lights |
I know I don't have overriders, but narrower looks better than directly under the headlights. |
raygreenwood Samba Member
Posted: Mon Feb 01, 2016 10:30 pm Post subject: Re: Opinion: Best Position For Front Fog Lights |
Who cares how it looks......the best way is as low as possible......bottom side of the bumpers. Driving lights on top. Ray |
Posted: Mon Feb 01, 2016 10:49 pm Post subject: Re: Opinion: Best Position For Front Fog Lights |
raygreenwood wrote: |
Low is good, but is it better to be closer to the center or further out? _________________ Cream Puff
Earl Grey
Marsha Mellow
Posted: Mon Feb 01, 2016 11:46 pm Post subject: Re: Opinion: Best Position For Front Fog Lights |
BayCreamPuff wrote: |
Low is good, but is it better to be closer to the center or further out? |
I was thinking about that one. I guess it depends on your driving style. If they are really foglights....the lower the better....and the beams will spread fairly wide. Center would be fine.
But if you live in deer country like I do.....either give some aim to the sides or put them outside the overriders for the best chance of seeing them. Ray |
sodbuster Samba Member
Joined: August 08, 2004 Posts: 1086 Location: wherever my baywindow takes me.
Posted: Tue Feb 02, 2016 10:46 am Post subject: Re: Opinion: Best Position For Front Fog Lights |
Appearance? go inside if the look is more important that the function.
Proper function? go outside directly under and inline with the headlamps.
mi dos centavos |
Posted: Tue Feb 02, 2016 11:09 am Post subject: Re: Opinion: Best Position For Front Fog Lights |
sodbuster wrote: |
mi dos centavos |
THIS!
Ray |
Kirk Samba Member
Joined: December 05, 2003 Posts: 5487 Location: North Texas
Posted: Tue Feb 02, 2016 12:15 pm Post subject: Re: Opinion: Best Position For Front Fog Lights |
I have mine in the center, and I dont know about "proper function", but mine illuminate the world. _________________ MAKE FORUMS GREAT AGAIN
Bear
Coble
Super
Oppenheim |
Posted: Tue Feb 02, 2016 2:42 pm Post subject: Re: Opinion: Best Position For Front Fog Lights |
Kirk wrote: |
I have mine in the center, and I dont know about "proper function", but mine illuminate the world. |
But are those driving ligjts or fog lamps?
In reality....you "could" make a good high powered fog light from a dedicated driving light by placement (down low) and aim (slightly low of center)....so if you need fogs and cant get dedicated fog lamps.....you could make it work fine.....but if its really "FOG" lamps you need because you are dealing with fog.....tey need to be down as low as possible.
Those look to be driving lights and are placed as such. Nice though! Ray |
Kirk Samba Member
Posted: Tue Feb 02, 2016 2:48 pm Post subject: Re: Opinion: Best Position For Front Fog Lights |
Indeed Ray, I should have read the post better.
My apologies. _________________ MAKE FORUMS GREAT AGAIN
Bear
Coble
Super
Oppenheim |
Posted: Tue Feb 02, 2016 5:20 pm Post subject: Re: Opinion: Best Position For Front Fog Lights |
Kirk wrote: |
My apologies. |
Those are some big mothers though.....which ones are those? Hella makes killer driving lights. Ray |
sneakyjack Samba Member
Joined: January 14, 2010 Posts: 560 Location: SOuthern VT
Posted: Tue Feb 02, 2016 5:41 pm Post subject: Re: Opinion: Best Position For Front Fog Lights |
On either side of the front spare tire.
top of bumper - at least for round headlights
_________________ Nothin left to do....
www.idolmakerfilms.com |
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3555 Location: San Diego (Encinitas)
Posted: Tue Feb 02, 2016 6:18 pm Post subject: Re: Opinion: Best Position For Front Fog Lights |
Fog tends to stop a foot or so above the ground. Fog lights attempt to put light into this semi-clear space. A true "fog" beam pattern is very wide but very short, with a sharp cutoff on the upper portion. You only see this in "real" fog lamps (Cibie, Marchal, some Bosch, etc.) The point of the pattern is to (1) keep the light from upwardly illuminating the fog, thus creating glare, and (2) illuminate objects on the shoulders of the road so as to provide situational awareness. Most no-name fog lamps being sold (and factory-installed front facia lamps) don't have a clue as to proper beam pattern.
Thus, if you have real fog lamps, and want to use them as such, mount them as low as possible. Because the beam is wide, avoid obstructions to the light (like a nose-mounted tire, overriders, etc.) If you have the other kind, mount them wherever you like - doesn't matter. _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
Posted: Tue Feb 02, 2016 6:25 pm Post subject: Re: Opinion: Best Position For Front Fog Lights |
telford dorr wrote: |
Fog tends to stop a foot or so above the ground. Fog lights attempt to put light into this semi-clear space. A true "fog" beam pattern is very wide but very short, with a sharp cutoff on the upper portion. You only see this in "real" fog lamps *Cibie, Marchal, some Bosch, etc.) The point of the pattern is to (1) keep the light from upwardly illuminating the fog, thus creating glare, and (2) illuminate objects on the shoulders of the road so as to provide situational awareness. Most no-name fog lamps being sold (and factory-installed front facia lamps) don't have a clue as to proper beam pattern.
Thus, if you have real fog lamps, and want to use them as such, mount them as low as possible. Because the beam is wide, avoid obstructions to the light (like a nose-mounted tire, overriders, etc.) If you have the other kind, mount them wherever you like - doesn't matter. |
Yes well put......and if you take a look at Hella's site.....in the 500, 700 and 1000 series they offer the fluted glass lens in fog specific as compared to crystal clear for driving lights.
You will alwo note in the specs....that most driving lights list "upright" installation (bracket on top of bumper or roof). ...and most of the fogs list install down or have the option of buyimg them in one configuration or the other because they have been designing the reflectors in a directional manner for quite some time.
It used to be....on some of the original H4's and H-1 lenses....they had a bowtie shaped anti-glare prism at the top and bottom of the lenses.
These could be used for either fog or driving lights with auxiliary bulbs and correct mounting and aiming. Ray |
Brian Samba Moderator
Posted: Tue Feb 02, 2016 6:26 pm Post subject: Re: Opinion: Best Position For Front Fog Lights |
I like this look on late bays _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Posted: Tue Feb 02, 2016 6:29 pm Post subject: Re: Opinion: Best Position For Front Fog Lights |
OP, what was the reasoning for buying these fog lights? Do you need to illuminate the road better during foggy contortions or do you just like how they look? _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
Posted: Tue Feb 02, 2016 8:01 pm Post subject: Re: Opinion: Best Position For Front Fog Lights |
richparker wrote: |
OP, what was the reasoning for buying these fog lights? Do you need to illuminate the road better during foggy contortions or do you just like how they look? |
I'd say 60/40 function to form. I like the way they look, but don't want to mount them where they won't function properly.
I've opted for somewhere in between the photos I posted
Here's the beam from one lamp with the bus up on ramps
Here's the vintage hella kit I picked up on the classifieds
And the beautiful orange fog switch I found on ebay
Earl Grey
Marsha Mellow
Tcash Samba Member
Posted: Tue Feb 02, 2016 8:35 pm Post subject: Accessories |
