vegpedlr Samba Member
Posted: Mon Feb 01, 2016 7:43 pm Post subject: Frozen wiper fluid |
I'm loving my Cooper snow tires, but my windshield wiper fluid isn't working. I'm assuming it's frozen, and because of the location of the reservoir, there isn't engine heat to keep it liquid.
Any tips? |
CdnVWJunkie Samba Member
Joined: February 01, 2004 Posts: 1110 Location: Sarnia, Ontario, Canada
Posted: Mon Feb 01, 2016 7:48 pm Post subject: Re: Frozen wiper fluid |
vegpedlr wrote: |
Any tips? |
Engine heat to keep it liquid? LOL. There is summer and winter washer fluids available. Engine heat has nothing to do with it.
Either put your van in a heated garage overnight or simply remove the reservoir and bring inside a heated space and let thaw out. |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10251 Location: N. Idaho
Posted: Mon Feb 01, 2016 8:04 pm Post subject: Re: Frozen wiper fluid |
A good tip is to randomly engage the washers front and rear (especially) in cold climates. The fluid can evap out the ingredient that keeps it from freezing, so pushing that through keeps the sprayers from getting frozen from aged fluid. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
jackbombay Samba Member
Joined: October 19, 2007 Posts: 2723 Location: Eastern Idaho
Posted: Mon Feb 01, 2016 10:04 pm Post subject: Re: Frozen wiper fluid |
I only ever put the -20* washer fluid in my vehicles so I don't have to worry about it, and when it is colder than -20 there is no water/slush/sludge on the roads to mess my windshield up anyway, but I've never known the -20* stuff to freeze on me, that I knew of, down to -35*.
I did buy a used vehicle from a dealer in Salt Lake city not long ago, and early this winter on a balmy 15* day I found that the washer fluid was frozen, it did thaw after 45 min of driving, so I sat at the gas station and pumped a gallon out while getting gas and bought a gallon of the proper -20* stuff, big blue puddle at the pump, whats a guy to do?
Looks like it'll be 32* in the tahoe area tomorrow, as long as the washer isn't filled with straight water it will melt, and you can leave a big blue puddle somewhere and fill it with the proper stuff! _________________
Gas struts to pop your top easily!
Pop Top strut kits now available for late Bay window Westies
Samba ad here.
DIY artificial rain gutters (ARGs) |
61Scout Samba Member
Joined: November 06, 2011 Posts: 1297 Location: Shoreline/Yakima WA
Posted: Tue Feb 02, 2016 12:37 am Post subject: Re: Frozen wiper fluid |
I was just going to ask that very question, o clairvoyant one.... _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
Posted: Tue Feb 02, 2016 8:32 am Post subject: Re: Frozen wiper fluid |
61Scout wrote: |
If you have the "wrong" stuff in there or are trying to use it up, you can simply add rubbing alcohol to the reservoir to keep it from freezing.
-Kevin |
Good point, but a pint of rubbing alcohol is $2 and a gallon of -20 washer fluid is $2, with the washer fluid I know the freeze protection, adding rubbing alcohol to the tank doesn't provide me with that. _________________
Samba ad here.
greggearhead Samba Member
Joined: June 20, 2004 Posts: 563 Location: Colorado Springs, CO
Posted: Tue Feb 02, 2016 8:53 am Post subject: Re: Frozen wiper fluid |
61Scout wrote: |
-Kevin |
Yep, or methanol - which is what the -20 stuff has in it. Yellow bottle of Heet fuel line antifreeze is straight methanol. I rescued a friends frozen washer fluid with that trick - worked a treat. _________________ 1972 Porsche 911E
1973 VW 412
1984 VW Doka
1991 Vanagon Syncro Westy
Period Lights, VW & Porsche wheels and Recaro/Scheel Seats for sale
https://www.facebook.com/greggearhead
http://greggearhead.com/soco-swap---september-vw-swap-meet.html |
hans j Samba Member
Joined: May 06, 2006 Posts: 2715 Location: Salt Lake City UT
Posted: Tue Feb 02, 2016 10:44 am Post subject: Re: Frozen wiper fluid |
I've had mine freeze even with the -20. But I don't think it was solid in the reservoir, I believe it froze/clogged in the hose or nozzles. I could hear the pump run, but nothing spraying out. Got the van warmed up a bit and it started working, I may have even parked it in the sun. I've also seen it happen a couple times with modern cars that come into my work.
Warm it up, get new fluid in there and see what happens. _________________ 1986 Canadian Syncro Westy TDI - 1989 Syncro Single Cab - 2001 Audi S4 - 1981 VW Caddy ABA - 1980 VW Caddy EV - 1973 VW T-181 |
