Jltrogdon Samba Member
Posted: Thu Jun 23, 2016 11:12 am Post subject: 1983 Vanagon Diesel |
Hi all! New member here! Have opportunity to snag a 1983 Volkswagen Vanagon with a deisel engine. It has not run since around 1990. The engine was rebuilt around that time but it was never put back in the vehicle. Right now the engine is sitting in the back passenger area. Any thoughts? I'm open to any ideas or input! Thanks!!
MidwestDrifter Samba Member
Joined: June 13, 2012 Posts: 769 Location: Kicking Around Australia
Posted: Thu Jun 23, 2016 11:37 am Post subject: Re: 1983 Vanagon Diesel |
Welcome to the madness. The blue 2 tone color scheme is one of my favorites. In the USA I don't believe there were any 83 diesels imported (they stopped in 82?). I am not sure about Canada though.
Should be a fun restoration project. More photos please. After sitting that long its going to need a complete going through. All the rubber will likely be needing replacing, including the hoses and brake parts. A lot of work, but if you enjoy it? _________________ 2004 Dodge/Mercedes Sprinter (Custom Camper)
2000 Jetta TDI
1982 Diesel Westy W/ ABA I4 hybrid (Sold)
Epic Road Tripping since 08/05/12 | http://VagariesAbound.blogspot.com/
My Current Build | http://sprinter-source.com/forum/showthread.php?t=41215 |
Posted: Thu Jun 23, 2016 11:41 am Post subject: Re: 1983 Vanagon Diesel |
Well I don't have any other pics right now. It's actually a family vehicle and I'm getting it for .....FREE!! Lol though it won't be free in the end lol!! It's been so long that I'm not 100% sure that it's an 83.... But I do know that it's a deisel because I'm remember way back when having to make sure the gas station had deisel lol!! I'm hoping to go pick it up 4th of July weekend and I can post more pics then!! If anyone has any experience with these, I'm all ears!!! |
?Waldo? Samba Member
Posted: Thu Jun 23, 2016 12:04 pm Post subject: Re: 1983 Vanagon Diesel |
There were '83 diesel vanagons imported into the US. I own one of them and have worked on several others. The nicer things about the '83 over the '82 are that they all came with the 5-speed trans, updated cooling system, better dipstick/oil filler setup, improved electrical (coolant level sensor/glow plugs), etc...
Definitely snag it up for FREE!!! I'd recommend ditching the stock non-turbo 1.6 and taking the opportunity to upgrade. |
Posted: Thu Jun 23, 2016 12:29 pm Post subject: Re: 1983 Vanagon Diesel |
Andrew A. Libby wrote: |
There were '83 diesel vanagons imported into the US. |
Cool, thanks for the correction. I am guessing they weren't imported in large numbers? It's too bad we never got the 1.6TD JX version...
There is some diesel specific quirks, and the 5 speed trans and linkage is somewhat rare in the USA. Otherwise the van will be very similar to early watercooled vanagons. Lots of great information on this forum (check out the FAQ sticky for tons of links).
Andrew is a great source of information, and has posted lots of details in various diesel threads. You might just go through the forum reading all the recent diesel and TDI threads. Tons too take in.
The stock diesel engine makes very little power. The stock trans gearing is also short for this reason. That makes these vans very slow in stock configuration. Many diesel owners opt to upgrade to one of several turbo diesel engines. I believe all diesel engines prior to 97? 98? will physically bolt up to the transmission. With some work to adapt the intake and exhaust obviously.
Anyways, lots of good info once you start digging. _________________ 2004 Dodge/Mercedes Sprinter (Custom Camper)
2000 Jetta TDI
campism Samba Member
Joined: September 07, 2007 Posts: 4491 Location: Richmond VA
Posted: Thu Jun 23, 2016 1:06 pm Post subject: Re: 1983 Vanagon Diesel |
Congrats! I found an '82 diesel for cheap but it was too much trouble for what it was. I would have gone for it had it been an '83 because of the 5-speed and the improved carrier bars and other pieces that would have been more desirable for the swap to a VW I-4 gasser engine. _________________ '87 Westy in Wolfram Grey Metallic |
Gnarlodious Samba Member
Joined: September 28, 2013 Posts: 2321 Location: Adobe Jungle USA
Posted: Thu Jun 23, 2016 1:34 pm Post subject: Re: 1983 Vanagon Diesel |
Just to let you know that at the time this van was made the speed limit in the USA was a mere 55MPH, so getting to go any faster than that is a strain.
If you do buy any parts on the Samba classifieds or anywhere else just be aware that the ’83 diesel had many parts that were not interchangeable with ’82. So don’t waste your money thinking all diesel parts will fit.
Also, be skeptical that the engine was really rebuilt. More likely someone honed the cylinders and put new rings in it. If that is your “rebuild” then you can expect maybe 20k miles out of the engine. And it may have been done in a backyard shop, these engines are rather weak already so it may spring leaks or have other major failures. Be ready for anything.
Otherwise the diesel Vanagon is a great invention and extremely economical. I’ve been driving one for 16 years and it has never left me stranded. _________________ Vanagon ’83 diesel AAZ w/Giles injection, 5spd 4.57R&P+TBD and a '78 diesel Rabbit |
Posted: Thu Jun 23, 2016 1:58 pm Post subject: Re: 1983 Vanagon Diesel |
I do like the thought of keeping the original deisel engine even though she's a slow poke:) it just depends on its condition. How hard is it to find parts on that baby? I have read that a lot of the 82 and 83 parts are NOT interchangeable....I can't wait to get my hands on it!!! |
danfromsyr Samba Member
Posted: Thu Jun 23, 2016 6:36 pm Post subject: Re: 1983 Vanagon Diesel |
the good thing is in FL there's no hills. much less mtns... so keep off the highways. and it'll do just fine..
though I wouldn't count on any of the engines in these images. _________________
Abscate wrote: |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22648 Location: NYC/Upstate/ROW
Posted: Thu Jun 23, 2016 7:51 pm Post subject: Re: 1983 Vanagon Diesel |
My 1983 Vanagon diesel 5 speed ran at 60 mph all day long.
Great car and 30 mpg and heat in winter _________________ .ssS! |
Posted: Thu Jun 23, 2016 8:22 pm Post subject: Re: 1983 Vanagon Diesel |
Engine parts are plentiful, as the same engine was put into Rabbits, Quantums, and Caddys (pickup truck). Parts peculiar to the Vanagon can be impossible to find, such as an air intake rubber tube and a certain eccentric coolant hose.
The pressure tank is a weak point due to its hanging awkwardly from a wedge mount which causes the tank to crack. You will probably never find an original replacment so best to fabricate a gentler mount for it before it breaks.
The box under the stickshift need attention lest it degrade and ruin parts that are hard to fix and impossible to find, the assembly is only found on ’83 diesel.
If you ever take apart the instrument cluster be EXTREMELY careful not to break off the corners holding the screws. Recommended to reinforce the corners before disassembly, I believe the plastic used is styrene. Also the mylar circuit board is extremely delicate and prone to breakage.
I would also recommend changing the rigid black braided rubber hose that curves down into the clutch master cylinder. A more modern flexible hose can prevent a major fluid spillage that will ruin your sub floor mat.
You should also check the tightness of the shift lever that goes into the transmission with a 13mm socket. If it ever vibrates loose bad things can happen.
Can’t think of anything else. _________________ Vanagon ’83 diesel AAZ w/Giles injection, 5spd 4.57R&P+TBD and a '78 diesel Rabbit |
Posted: Thu Jun 23, 2016 10:01 pm Post subject: Re: 1983 Vanagon Diesel |
Updating the pressure tank to the WBX version is easy. Rather than fabricating a new mount for an old pressure tank that is NLA, I'd just make one for the WBX tank.
All of the diesel hoses are available new from Germany - a complete new set is 150 euros. Silicone replacements are available in the US. |
Posted: Fri Jun 24, 2016 1:29 am Post subject: Re: 1983 Vanagon Diesel |
Still miss my white on blue 1983.....
Posted: Fri Jun 24, 2016 2:26 pm Post subject: Re: 1983 Vanagon Diesel |
Well I have an update....the van is in fact an 82....NOT an 83.... Does that change anything? Should I still go for it? I'm going to lol:) any other advice? |
Posted: Fri Jun 24, 2016 4:33 pm Post subject: Re: 1983 Vanagon Diesel |
You should still get it for free, but IMO the '83 is more desirable for all the reasons I mentioned before. |
epowell Samba Member
Joined: September 23, 2015 Posts: 4733 Location: Czech (mostly) Vancouver (sometimes)
Posted: Tue Jun 28, 2016 9:30 am Post subject: Re: 1983 Vanagon Diesel |
I would go for it in a second, in fact I am looking for exactly that (although just now thanks to Andrew, realizing that an 83 is a better choice). My hope is to find a van like that, with a 1.6na D., and put a turbo on it.
From what I heard, the only really terrible thing about non-turbo diesel engines, is that they do not burn fuel efficiently in the mountains where the natural air pressure is not enough to get enough air into the engine... so what I would do (meaning, the simplest and CHEAPEST way) would be to put a turbo onto the NA engine but make sure to only set it to a tiny amount of boost and fueling because the NA engine lacks piston cooling jets.
Anyhow, I am pretty much a newby to this stuff but I also have an '82 diesel (turbo JX engine) and I just spent the last 6 months with my hands VERY dirty going thru in detail many many many of the fundamental basic things - and thanks to the amazingly knowledgable and generous dudes here, my van is now running great. I would highly recommend taking note of this thread - it is HUGE, but on the first page I put in an index pointing to page numbers of various main topics.
http://www.thesamba.com/vw/forum/viewtopic.php?t=640611&highlight=
Good luck! _________________ www.edwardpowell.com |
