Rust repair in Bay Area, CA
vwdriverfoundvw
vwdriverfoundvw is offline
PostPosted: Thu Oct 01, 2020 2:46 pm    Post subject: Rust repair in Bay Area, CA Reply with quote
Can anyone recommend a body shop that can do rust repair in the bay area or nor cal? My 82 Westy has some rust on the rear and side window sills that may require some new metal. Every body shop I have talked to says they don't do that kind of work anymore but cannot recommend anyone.
charleslabri
charleslabri is offline
PostPosted: Thu Oct 01, 2020 2:56 pm    Post subject: Re: Rust repair in Bay Area, CA Reply with quote
i had the very same issue. No one wants the crap work.
Emerald City Auto Body in bayview said theyd do it.. but they were pretty damned pricey (https://goo.gl/maps/gKbvfiLKmxFqe67U6)
I ended up doing it myself
16CVs Premium Member
16CVs is offline
PostPosted: Thu Oct 01, 2020 6:29 pm    Post subject: Re: Rust repair in Bay Area, CA Reply with quote
You need to go to a Fab or Restoration shop. I donít think body guys should be doing rust repair.
I use a local Fab guy. I tell him what I want and it comes back raw metal. Nothing hiding, then it goes to a body guy.
Stacy
Samba member # 14980
Scottn59c
Scottn59c is offline
PostPosted: Sat Oct 03, 2020 1:19 pm    Post subject: Re: Rust repair in Bay Area, CA Reply with quote
Me too. I had some rust around a failed seal in the front windshield. I removed the windshield and worked on it with an angle grinder and POR-15. Have not had any recurrence or rust in the last two years.
I have a failed seal in the back windshield and a rust spot there too, but I have just elected to let it be. It's not getting any worse, as CA has a very forgiving climate.
Farfignewton!
gerstle
gerstle is offline
PostPosted: Tue Nov 17, 2020 10:00 am    Post subject: Re: Rust repair in Bay Area, CA Reply with quote
@vwdriverfoundvw - Find anything worthwhile? I'm down in Santa Cruz and am trying to decide if it's worth it to me to fix the rust or if I should just move on to something newer...
Californio
Californio is offline
PostPosted: Tue Nov 17, 2020 12:15 pm    Post subject: Re: Rust repair in Bay Area, CA Reply with quote
Felipe at 523rods in Richmond did mine a few years ago, not sure he's still doing that though. He knows Vanagons inside and out including all the rust problems we face.
spillane
spillane is offline
PostPosted: Tue Nov 17, 2020 6:54 pm    Post subject: Re: Rust repair in Bay Area, CA Reply with quote
Yeah go to Felipe's Shop 523 Rods, they do full restorations all day long.
1987 Vanagon GL - 2.3L WBX
koubiak
koubiak is offline
PostPosted: Thu Nov 19, 2020 12:15 am    Post subject: Re: Rust repair in Bay Area, CA Reply with quote
When I bought my van last year I had a pretty bad rust problem on the back windshield I found a shop in SF to do the repair but he quoted me way too much. I chatted with buslab who offered to find a new gate and a recommendation AJ's auto clinic in Oakland. I stopped by and he quoted me something that sound reasonable to me for acquiring a doneur part welding it in and repainting the full things. The work was perfect and fast. I harldly can tell that any work has been done. I know the owner works on Vanagon quite often. So I would highly recommend even if they are not really cheap.
Funnily enough I need to change some of my seals now. The windshield's one is clear leaking from this weeks rain. I am considering doing it myself including any small rust repair if I found any. I am bit scared of finding an horror story... So if you ever see someone in SF fixing its windshield stop and say hi Smile
Good luck!
Edit : a friend and neighbor got some extensive rust repair done in the south bay the cost seemed reasonable I can ask him if you want. please DM me.
mikemtnbike
mikemtnbike is offline
PostPosted: Thu Nov 19, 2020 8:53 am    Post subject: Re: Rust repair in Bay Area, CA Reply with quote
[quote="koubiak"]
quote]
16cvs above does auto glass for a living. I'd for sure be calling (look the # is right there!) for Stacy's professional support on that if I was the Bay area.
1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie"
In an abundance of water, the fool is thirsty.
