buggin65 Samba Member
Joined: April 14, 2011 Posts: 70 Location: Conejo Valley
Posted: Fri Feb 05, 2016 7:57 pm Post subject: Undercoat |
Hey you guys, I'm doing an amateur restoration on the fenders of my 65 bug that I've had since '92, proudly. What do you use for the coating on the underside of the fenders. It looks like tar material is original but most of it is gone. So what would you use? Rubber spray in a can feels too thin, so maybe brush on some Henry's roofing tar? Or, Hercules bed liner in the pint can? Other ideas? Thanks |
glutamodo The Android
Joined: July 13, 2004 Posts: 26324 Location: Douglas, WY
Posted: Fri Feb 05, 2016 8:00 pm Post subject: Re: undercoat |
If you want thick, 3M Schutz isn't bad. You have to get a gun designed to spray it. |
Posted: Fri Feb 05, 2016 8:05 pm Post subject: Re: undercoat |
I'm kinda on a budget, what about the brush on Henry's roofing tar? But I am worried that it won't harden up or something because it is upside down and not exposed to the sun to dry. |
fly2kads Samba Member
Joined: July 09, 2012 Posts: 148 Location: Roanoke, TX
Posted: Fri Feb 05, 2016 8:30 pm Post subject: Re: undercoat |
I just bought a quart can of Rustoleum Undercoating for this job, but haven't had a chance to try it out yet. |
carcrazed Samba Member
Posted: Sat Feb 06, 2016 10:35 am Post subject: Re: undercoat |
Don't use the roofing tar as it will get sticky when it heats up. stop by your local auto parts store and get some spray undercoating. _________________ 1965 Herbie Replica. 1776cc dual Kads.
1961 Beetle 33,000 Original Miles
"Just When you think you are getting ahead, you're always wrong." |
Posted: Sat Feb 06, 2016 11:01 am Post subject: Re: undercoat |
I used that Schutz that I mentioned above back in 1992 when I first restored my 62 Bug, to go over and augment the original undercoating, and it worked pretty good. Eventually it started to crack and flake off and since then I've just augmented it with rattle-can undercoating and I've found that works pretty good.
-Andy |
widefivebug Samba Member
Posted: Sat Feb 06, 2016 4:03 pm Post subject: Re: undercoat |
carcrazed wrote: |
Don't use the roofing tar as it will get sticky when it heats up. stop by your local auto parts store and get some spray undercoating. |
X2
It won't ever completely set and get hard. When it softens and gets sticky in the summer everything loose on the road will be stuck to the inside of your fender. |
HippyTom Samba Member
Joined: December 18, 2013 Posts: 676 Location: Florida, West Pasco
Posted: Sat Feb 06, 2016 5:44 pm Post subject: Re: undercoat |
I sanded and painted the inside of my fenders and fender wells. You may be able to find a Krylon spray paint that is very close to your color. Since it is under the rest of the paint it doesn't have to be an exact match as long as it is real close. Prep the surface correctly and take your time doing it in layers and it will look great. Then, once a year just use a red scuff pad to scuff any chips and shoot the few spots here and there with another layer or two. It will blend in.
If you don't want to deal with the painting, I would recommend using a good, high quality bed liner kit. That stuff is tough and durable and will handle road debris much better than undercoating. I used undercoating on the inside of floor pans before and regretted it. It doesn't set up to a durable finish like bed liner.
panicman Samba Member
Joined: December 18, 2011 Posts: 2290 Location: Canby, OR
Posted: Sun Feb 07, 2016 10:43 am Post subject: Re: undercoat |
This stuff is good.
_________________ Plate of shrimp |
buguy Samba Member
Joined: November 17, 2003 Posts: 4915 Location: Port Orange, FL
Posted: Sun Feb 07, 2016 3:14 pm Post subject: Re: undercoat |
Bed liner or chip guard are both good options. And if you wanted could be tinted to match the car. |
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Sun Feb 07, 2016 7:05 pm Post subject: Re: undercoat |
Stay away from undercoat.
Go with cleaning, prepping, primer, paint...or
The bedliner or chip (rock) guard are other good options. I went with the rock guard option on my 54, which is nice, but in hindsight I wish I went with smooth body color.
Body color was stock, undercoat was a factory option |
Posted: Sun Feb 07, 2016 10:05 pm Post subject: Re: undercoat |
Thanks you guys good to know, nix the Henry's roofing tar. I guess a good bed liner is a good alternative, no need to risk gooey tar not hardening.
Hippytom, I know what ya mean about the Krylon, tide pool was almost an exact match to the bahama blue, but they discontinued it, now i dont have anymore touch up paint!! I have a local paint shop color match the paint and put it in a single use rattle can. |
Aynthm Samba Member
Joined: July 07, 2010 Posts: 1315 Location: Beaverton, Oregon
Posted: Sun Feb 07, 2016 11:31 pm Post subject: Re: undercoat |
I used about 4 cans of this about 5 years ago and nothing has ever stuck to it in summer. It does what it is meant to do and has not cracked or chipped. I only used it on the fenders.
Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5304 Location: Central Florida
Posted: Mon Feb 08, 2016 5:44 am Post subject: Re: undercoat |
buguy wrote: |
When going with a bed liner is the brand important? Is rust oleum liner any good? Rust oleum bed liner is about half the price of the SEM Chip guard. Does it work half as good? Lol. For mine mainly looking at interior surfaces like the pans and package tray. Also, does anyone known if you can put something like Second Skin on top of it? |
Posted: Mon Feb 08, 2016 12:18 pm Post subject: Re: undercoat |
Check Rustoleum colors. They have a large selection also. |
Posted: Mon Feb 08, 2016 10:52 pm Post subject: Re: undercoat |
I used 4-5 cans of the SEM chip guard on my wheel wells and fenders. Notice in the pic below that you can see all of the factory welds; the finish flows very smooth. You can paint color on top of the chip guard also, and I doubt anyone would know (I decided to mask these areas off to save some $$)
This chip guard has now been on the car for years. There has been no lifting, cracking, or signs of incompatibility whatsoever. The finish wipes clean with a damp rag and looks new. Please disregard the droplets in the photo; I had just driven over wet streets when I took the picture.
The finish feels like smooth plastic, and it has a mild sound deadening quality. Post or PM if you have any questions.
Digger89L Samba Member
Joined: May 16, 2013 Posts: 1130 Location: Western Canada (SK)
Posted: Tue Feb 09, 2016 7:39 pm Post subject: Re: undercoat |
"Body color was stock, undercoat was a factory option"
Pretty sure that they didn't offer a factory option undercoating. Dealers did the undercoating ( "...and would you like to add undercoating, seat covers, whitewalls, and a radio?" ) as an add-on money maker. That's why you see some really crappy 'original' undercoating jobs. I've successfully used the Dupli-color rubberized spray-on undercoating on several vehicles ....and you can paint over it to keep the OEM painted underside look. _________________ "If you can't fix it with pop rivets, crazy glue and duct tape, or hold it together with zip ties, velcro or magnets, it REALLY is broken." |
Motomazzo Samba Member
txoval Samba Member
Posted: Tue Feb 09, 2016 8:14 pm Post subject: Re: undercoat |
You're correct, my wording was poor. I meant it as an option you could buy when new...
Digger89L wrote: |
Pretty sure that they didn't offer a factory option undercoating. Dealers did the undercoating ( "...and would you like to add undercoating, seat covers, whitewalls, and a radio?" ) as an add-on money maker. That's why you see some really crappy 'original' undercoating jobs. I've successfully used the Dupli-color rubberized spray-on undercoating on several vehicles ....and you can paint over it to keep the OEM painted underside look. |
buguy Samba Member
Posted: Tue Feb 09, 2016 8:50 pm Post subject: Re: undercoat |
Rustoleum is just fine. Just make sure you don't put it on bare metal. |
