LOTYP3 Samba Member
Joined: February 13, 2007 Posts: 128 Location: Australia
Posted: Sun Feb 07, 2016 2:48 am Post subject: Bearings for steering box rebuild |
So I decided to take on the task of rebuilding the steering box for my 54 project, everything came out without too much hassle but the second bearing at the end of the worm fell apart when it was pressed out! Knew it was all happening too far too easily!
My question is, has anyone had any luck sourcing replacement bearings for the steering box? I've spent the last few hours searching on the net for an answer withou much luck.
Now I have a second oval steering box that I can salvage the bearing from, but I was planning to keep that one as a spare. Any help would be appreciated! |
TheLadyBug Samba Member
Joined: August 17, 2014 Posts: 639 Location: Saskatoon, Saskatchewan, Canada
Posted: Sun Feb 07, 2016 10:06 am Post subject: Re: Bearings for steering box rebuild |
I did not find any bearings for my 54 box. I ended up buying a replacement box as the originals were notorious for leaking and often they were operated dry, wearing out the bearings inside. I've heard stories of those bearings going for a lot of money since they're so hard to come by. _________________ Charmaine
1954 Beetle - because I can
2016 Golf highline - hubby’s daily
2016 Golf R - my daily |
splitjunkie Samba Member
Posted: Sun Feb 07, 2016 4:27 pm Post subject: Re: Bearings for steering box rebuild |
The rubber seals are off the shelf seals for both split and oval boxes so the bearing might be off the shelf parts too.
If the bearings are off the shelf bearings then they might be inexpensive if purchased from a bearing supply house. Even if they are off the shelf bearings, you will pay a premium for NOS VW just because they are VW sourced parts. _________________ Chris
LOTYP3 Samba Member
Posted: Sun Feb 07, 2016 5:19 pm Post subject: Re: Bearings for steering box rebuild |
I found this post in this thread: http://www.thesamba.com/vw//forum/viewtopic.php?p=7564409&highlight=#7564409
Snort wrote: |
Snort wrote: |
Can I take this to mean that the lower bearing rests on a shoulder inside the bore of the body, and can only be removed by pushing it toward the inside? |
Yes, this is correct.
Here is the bearing. It is FAG 47.05.01. The inner race is machined onto the worm gear.
I tried searching that 'FAG47.05.01' part number without any luck. Can anyone shed some light onto this? |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Sun Feb 07, 2016 6:25 pm Post subject: Re: Bearings for steering box rebuild |
while the seals are off the shelf, the bearings are not.. At least when I tried to find some I couldn't.
They come up every once in awhile for sale. How bad are the bearings now? _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
blood Samba Member
Joined: October 01, 2015 Posts: 50 Location: nashville tn
Posted: Sun Feb 07, 2016 6:55 pm Post subject: Re: Bearings for steering box rebuild |
I tried to find the same bearings for my 44. searched but no luck. you can replace the loose balls by measuring the diameter and buying loose bicycle crank ball bearings if the shaft (inner race) and outer race are not too badly galled. the solid rubber output seal was also unavailable so I found a close replacement in a standard wiper seal but had to bore the box body out to fit. If anybody can supply bearings I would like to purchase a set
David |
jason Samba Member
Posted: Sun Feb 07, 2016 6:59 pm Post subject: Re: Bearings for steering box rebuild |
I took mine apart recently. Put new seals in and clened the races. Mine also came apart and I noticed some pits on the balls. I bought 100 bearings for $5.00 and popped them in. |
jason Samba Member
Posted: Sun Feb 07, 2016 7:02 pm Post subject: Re: Bearings for steering box rebuild |
You could probably turn your box for a square bearing. |
LOTYP3 Samba Member
Posted: Sun Feb 07, 2016 7:26 pm Post subject: Re: Bearings for steering box rebuild |
I think my outer race could be salvageable, but my inner race is wrecked.
I have been on the phone with FAG Bearings to try and make sense of that part number, no luck with that exact one, but another lead has me onto another bearing numbered FAG200078C that could work.
They no longer produce the bearing though so I'll need to find a stockist with them still in stock, and then at least get a photo of it to see if I'm even on the right track!
Gotta love these early cars |
LOTYP3 Samba Member
Posted: Sun Feb 07, 2016 7:50 pm Post subject: Re: Bearings for steering box rebuild |
OK it looks like I'm looking for the right thing, didn't even realise this page was only a few clicks away!
http://www.thesamba.com/vw/archives/info/bearingref_t1_kg_t3.php
So that 200078 part number is correct, now its just a matter of hunting that down... |
Jrb572 Samba Member
Joined: August 30, 2013 Posts: 191 Location: St. Louis
Posted: Sun Feb 07, 2016 11:04 pm Post subject: Re: Bearings for steering box rebuild |
I don't know if it's even possible. Can you send it to bearing company to match it up with one they still have available? |
Posted: Mon Feb 08, 2016 9:45 am Post subject: Re: Bearings for steering box rebuild |
As a starting point for research, they are single row angular contact ball bearings with no cage and the inner race is integral to the worm shaft. These are different from your average ball bearing which is referred to as a radial bearing. _________________ Chris
LOTYP3 Samba Member
Posted: Mon Feb 08, 2016 2:09 pm Post subject: Re: Bearings for steering box rebuild |
Thanks for the help.
I've managed to track down a couple FAG200078 bearings in the UK but none with the 'D' suffix. None of the suppliers can give me much more information about the bearing they have beside they fact that it's in stock which is annoying, I might just have to buy one and roll the dice.
I also found this NSN Document that confirms all the numbers match and this particular bearing's use for the 'steering shaft'. Can anyone shed any light on the other serial numbers on this page?
https://www.nsncenter.co.uk/NSN/3110-12-123-8422 |
LOTYP3 Samba Member
Posted: Sun Feb 21, 2016 3:56 pm Post subject: Re: Bearings for steering box rebuild |
Just a quick update, I have sourced the bearings — and they didnt cost me a limb!
Both the FAG and SKF part number are for the same bearing and they're out there, but I had to get in touch with a number of places locally and internationally before I found them.
Snort Samba Member
Joined: April 02, 2005 Posts: 1957 Location: Seattle, WA
Posted: Sun Feb 21, 2016 4:33 pm Post subject: Re: Bearings for steering box rebuild |
That's good news. Perhaps you could share the source of your new bearings for anyone else that might want them. |
LOTYP3 Samba Member
Posted: Sun Feb 21, 2016 4:35 pm Post subject: Re: Bearings for steering box rebuild |
Ended up getting it via Eastern Bearings locally, they sourced it from a UK company that I found but they were able to get a better price via trade rates than me going directly + shipping.
As far as I'm aware I got the last ones from those guys. They have a single SKF bearing in stock as well now too if someone is just looking for a single one. |
j-dub Samba Member
Joined: November 09, 2003 Posts: 865 Location: Phoenix, AZ
Posted: Mon Nov 14, 2022 9:05 am Post subject: Re: Bearings for steering box rebuild |
Bump in hopes that someone has found a source for these bearings. _________________ 1957 Oval rag
"POLICE STATION TOILET STOLEN ... Cops have nothing to go on." |
j-dub Samba Member
Posted: Mon Nov 14, 2022 10:54 am Post subject: Re: Bearings for steering box rebuild |
Just found a source, expensive but if you need them you need them.
https://www.vwnos.com/111-415-227 _________________ 1957 Oval rag
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6617 Location: Houston, Texas
Posted: Mon Nov 14, 2022 1:37 pm Post subject: Re: Bearings for steering box rebuild |
I'm currently manufacturing the brass worm gear as well for these. The bearings and the brass gear are the main wearable parts. _________________ www.vwnos.com [email protected]
