REDKAFER Samba Member
Posted: Sat Jan 27, 2018 7:18 am Post subject: Re: Restoring My New (to me) 1967 Bug |
67ctbug wrote: |
So my rear cross braces are welded like 1/4" back farther than they need to be.... can i just bore out the bolt holes in the body to make it work? |
Are you talking about the bolt holes that go into the cast iron chassis under the seat? I did some research on those for the 67 and from what i gather they were not used on the sedan, only the convertible. That being said, mine lined up so i used them anyway, with the rubber blocks used on the rear exterior body mount.
If youre talking about the bolts that go into the pan using the rectangular washers, i had to do something similar but i only had to bore out about 1/8". I see no problem structurally if you bore these out as the forces here should be low; though if you remove lots of metal it would be a good idea to plug-weld the parts of the hole you arent using. |
Posted: Sat Jan 27, 2018 7:28 am Post subject: Re: Restoring My New (to me) 1967 Bug |
Oh wait, i think i just realized you might be talking about the cross braces that weld to tbe pans and tunnel, not the cross braces that weld to tbe heater channels and rear parcel shelf. In that case, i dont know for certain if theres another geometry that will be affected by its 1/4" offset, but i cant think of any at the moment. Measure em, think about it, measure again, eat a snack, measure again, do some math, and if your comfy with it i say bore em out. |
67ctbug Samba Member
Posted: Sat Jan 27, 2018 10:43 am Post subject: Re: Restoring My New (to me) 1967 Bug |
These holes....
_________________ '67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'73 Dodge W200
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote: |
mukluk wrote: |
Posted: Fri Feb 02, 2018 8:12 am Post subject: Re: Restoring My New (to me) 1967 Bug |
Do you think that by boring those holes out youll still have enough room to get a socket on the bolt? might be tight...
In any case I expect you'll be fine boring those a little bit as long as you keep the edges round and don't go doubling the size of the hole. Remember, sharp angles lead to stress concentrations which lead to rips - that's as true for sheet metal as it is for paper - so dont go using tin snips or anything that doesnt result in a smooth corner. |
Posted: Fri Feb 02, 2018 1:33 pm Post subject: Re: Restoring My New (to me) 1967 Bug |
I think I'll be good, I'll work on that this weekend. _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'73 Dodge W200
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Posted: Sat Feb 24, 2018 3:44 pm Post subject: Re: Restoring My New (to me) 1967 Bug |
Getting there!
'74 Westfalia
'63 Ragtop
'73 914
'73 Dodge W200
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Joined: August 31, 2013 Posts: 12850 Location: North Carolina
Posted: Sat Feb 24, 2018 5:40 pm Post subject: Re: Restoring My New (to me) 1967 Bug |
FWIW, align the patch panel over & overlapping the panel it's to be joined to, & then use a small reciprocating saw with a fine tooth metal blade to cut through BOTH panels. This will ensure a tight, even seam to weld to. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
EA812 Samba Member
Joined: December 07, 2008 Posts: 1223 Location: North central, CT
EA812 Samba Member
Posted: Sun Feb 25, 2018 8:43 pm Post subject: Re: Restoring My New (to me) 1967 Bug |
Thanks for the tips guys! TDCTDI, I marked on the original panel where i wanted to cut and then put tape over it and transferred the lines to the new panel like that. EA812, I don't think I can get any copper behind there. It's all enclosed. _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'73 Dodge W200
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Posted: Sun Feb 25, 2018 8:49 pm Post subject: Re: Restoring My New (to me) 1967 Bug |
However, with the way I described it, if the blade strays, it makes the same cut through both panels leaving a perfect gap the entire length. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Sun Feb 25, 2018 8:55 pm Post subject: Re: Restoring My New (to me) 1967 Bug |
Yeah, I like your way. How would I keep the two panels in the same spot? And can I trim the panel so that it fits to the original one better? _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'73 Dodge W200
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Posted: Sun Feb 25, 2018 9:02 pm Post subject: Re: Restoring My New (to me) 1967 Bug |
Clamp them in place, or, if you align them exactly where you want them, tack them together. In a place where they cannot be clamped, small self-tapping sheet metal screws can be used & then you can weld up the hole afterwards.
You can also get these little guys to clamp & align the panels as you weld.
https://m.harborfreight.com/butt-welding-clamps-8-pc-60545.html _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5304 Location: Central Florida
Posted: Sun Feb 25, 2018 9:12 pm Post subject: Re: Restoring My New (to me) 1967 Bug |
I'm really impressed by your persistence. You know, I was one of the ones suggesting you give up on this car and I find myself glad you're sticking with it. You're barely a couple of years older than my youngest kids and they wouldn't even begin to be able to accomplish what you are. Stick with it. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine |
Posted: Mon Feb 26, 2018 12:29 pm Post subject: Re: Restoring My New (to me) 1967 Bug |
REDKAFER wrote: |
If not, get some socket head bolts (allen head). _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Mon Feb 26, 2018 1:12 pm Post subject: Re: Restoring My New (to me) 1967 Bug |
TDCTDI wrote: |
https://m.harborfreight.com/butt-welding-clamps-8-pc-60545.html |
Smart, I’ll do that for my next panel like this. _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'73 Dodge W200
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Posted: Mon Feb 26, 2018 5:59 pm Post subject: Re: Restoring My New (to me) 1967 Bug |
Sharp64 wrote: |
I'm really impressed by your persistence. You know, I was one of the ones suggesting you give up on this car and I find myself glad you're sticking with it. You're barely a couple of years older than my youngest kids and they wouldn't even begin to be able to accomplish what you are. Stick with it. |
Thanks man! I'm trying to get all of the major metal done so I can register it just in time for the first show of the year. If not then, then by the Bug-A-Fair. After this, I have the wheelhouses in the back, the heater channels, and the front firewall. I've been making videos for it too. I kind of like it. I can look back in the future on how I'm doing things now and see how I've improved and stuff.
'74 Westfalia
'63 Ragtop
'73 914
'73 Dodge W200
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Posted: Tue Feb 27, 2018 7:39 am Post subject: Re: Restoring My New (to me) 1967 Bug |
67ctbug wrote: |
Getting there!
Another tip, cut before or after a body line, seam, or crease. In this case, a fender will cover most of it but it will be hard to mask a repair when you cross over or seam at a body line. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
flyboy161 Samba Member
Joined: December 26, 2009 Posts: 2091 Location: Perry, GA
EMPIImp69 Samba Member
Joined: April 17, 2006 Posts: 3374 Location: Dirty Jersey
Posted: Tue Feb 27, 2018 12:28 pm Post subject: Re: Restoring My New (to me) 1967 Bug |
You need a 4.5" angle grinder cutter dude. You'll be going thru Dremel wheels pretty quickly doing it that way _________________ 1963 Ragtop Bug |
