cbeck Samba Member
Posted: Mon Aug 14, 2017 5:50 am Post subject: Re: so soon? |
Not supposed to use blue or red lite, those are for emergency vehicles. I have always been a rebel Things have changed tho, turns out I am now the good son My brother is in his second visit to the gray bar motel, my sister went to school on the other side of the state and never came back, and I bought a house less than 2 miles from my mom. |
Third Samba Member
Joined: June 13, 2017 Posts: 116 Location: Texas Coast
Posted: Mon Aug 14, 2017 9:20 am Post subject: Re: so soon? |
Back when LEDs were all the rage on Harleys and custom bikes, I vaguely recall that (at least in TX) blue could still be used as long as it wasn't view-able from the front. But I'd have to look it up to be certain...
I only remember because I too always thought blue and red were off-limits from any direction. |
Fenix Samba Member
Joined: October 05, 2016 Posts: 468 Location: St Louis
Posted: Mon Aug 14, 2017 7:27 pm Post subject: Re: so soon? |
Just ne careful with blue LEDs the wavelength of light is only slightly off UltraViolet spectrum, and over exposure can cause eye damage. |
cbeck Samba Member
Posted: Wed Aug 16, 2017 6:15 pm Post subject: Re: so soon? |
Seats/belts in. cv's packed and installed. Need real nuts and bolts for the grab bar. Need to adjust clutch slave some more.
Part of the deal with my buddy was I put his name on it somewhere.
pullstart Samba Member
Joined: August 23, 2016 Posts: 599 Location: Middleville, MI
Posted: Thu Aug 17, 2017 4:09 am Post subject: Re: so soon? |
so soon? turns into so nice!
I wish I had your patience. I wish that some day my rail looks as detail oriented as yours. But the reality is as soon as it functions safely again, I'll be out tearing up the trails and roads and sand. So I'll just look at yours and play with mine. Cars that is. _________________ 4 seater Appletree buggy, road legal with 002 IRS, 3x3 Appletree kit, 6" over Dan's beam with 10" towers and Fox 2.0 shocks, '00 Subaru EJ25 with KEP stage 3 clutch and KEP adapter plate.
my build page: https://www.thesamba.com/vw/forum/viewtopic.php?t=662104&start=0 |
cbeck Samba Member
Posted: Thu Aug 17, 2017 4:56 pm Post subject: Re: so soon? |
Mine is a 5 to 10 footer. Have you ever noticed that set of wheels on cl always looks better than the pos you see in front of you? |
Posted: Fri Aug 18, 2017 10:43 am Post subject: Re: so soon? |
You're selling yourself short... but that's fine by me. Got a fuel pump, filter and injection line today but I'm locked out of my shop... some day I'll get the key from the inlaws and not have to rely on the code _________________ 4 seater Appletree buggy, road legal with 002 IRS, 3x3 Appletree kit, 6" over Dan's beam with 10" towers and Fox 2.0 shocks, '00 Subaru EJ25 with KEP stage 3 clutch and KEP adapter plate.
Fenix Samba Member
Posted: Fri Aug 18, 2017 12:58 pm Post subject: Re: so soon? |
pullstart wrote: |
You're selling yourself short... but that's fine by me. Got a fuel pump, filter and injection line today but I'm locked out of my shop... some day I'll get the key from the inlaws and not have to rely on the code |
Yeah, he is humble about the awesomeness that he has built. |
cbeck Samba Member
Posted: Sat Aug 19, 2017 5:14 pm Post subject: Re: so soon? |
Aw, shucks Almost feel bad about reporting the need to pull the engine and find the clutch dysfunction. Found a place to stick his name. Got the cage cleaned and primed.
One last thing I want to do. My daughter, the muscian/arteest did a rough sketch. He needs to be a little more buff, and needs a anchor tat on the opposite fore arm. Want to put it on a roof panel and cleat coat it.
Posted: Sun Aug 20, 2017 6:05 am Post subject: Re: so soon? |
looks great! _________________ 4 seater Appletree buggy, road legal with 002 IRS, 3x3 Appletree kit, 6" over Dan's beam with 10" towers and Fox 2.0 shocks, '00 Subaru EJ25 with KEP stage 3 clutch and KEP adapter plate.
cbeck Samba Member
Posted: Mon Aug 21, 2017 5:52 pm Post subject: Re: so soon? |
Don't know what was wrong with the release bearing. Pulled the engine and everything looked ok. Put engine back in and it worked. With frame off of the jack stands, it is a tight fit.
Put the cage on after getting home from watching the eclipse.
Next issue is the exhaust fitment changed after removing and painting. Winter project will be removing exhaust, cutting above collector, rotating to the rear, and adding a 02 bung. Turns out my kid has a afr gauge and sensor.
Up next.
Posted: Tue Aug 22, 2017 4:27 am Post subject: Re: so soon? |
Your crest looks like it took a couple good blows in battle.
Before you install the floor you should have a blown up smurf sketch wrapped onto it. _________________ 4 seater Appletree buggy, road legal with 002 IRS, 3x3 Appletree kit, 6" over Dan's beam with 10" towers and Fox 2.0 shocks, '00 Subaru EJ25 with KEP stage 3 clutch and KEP adapter plate.
cbeck Samba Member
Posted: Tue Aug 22, 2017 10:30 am Post subject: Re: so soon? |
Progressive it is. Will give 10k full coverage. Will see about a safety inspection without a floorpan, not discussed in the safety inspectors handbook. |
cbeck Samba Member
Posted: Tue Aug 22, 2017 2:29 pm Post subject: Re: so soon? |
Mo safety inspection complete.
Posted: Tue Aug 22, 2017 5:25 pm Post subject: Re: so soon? |
Great news! Looks like better than a 10 footer to me, you should be proud. Cheers! _________________ 4 seater Appletree buggy, road legal with 002 IRS, 3x3 Appletree kit, 6" over Dan's beam with 10" towers and Fox 2.0 shocks, '00 Subaru EJ25 with KEP stage 3 clutch and KEP adapter plate.
cbeck Samba Member
Posted: Wed Aug 23, 2017 3:34 am Post subject: Re: so soon? |
My kid's boss lady came out to the shop and said it looked nice and do I want to trade? In a moment of weakness I spouted out-dodge, diesel, 4x4, dually, long bed, 4 door, with less than 150k miles. She said, we have some of those A couple times a week my kid drives home a truck they have picked up at auction. It's like a parade of trucks I can't afford after they are put on the lot. |
Posted: Wed Aug 23, 2017 4:06 am Post subject: Re: so soon? |
meaning.... they'd just sell it? well, I bet you know my vote, if it gives you any strength _________________ 4 seater Appletree buggy, road legal with 002 IRS, 3x3 Appletree kit, 6" over Dan's beam with 10" towers and Fox 2.0 shocks, '00 Subaru EJ25 with KEP stage 3 clutch and KEP adapter plate.
dustymojave Samba Member
Posted: Thu Aug 24, 2017 5:14 pm Post subject: Re: so soon? |
X2
Include your man hours to build when considering it's trade value. Include in that your parts chasing, research, design and planning time, etc.... And that portion of your soul invested into it. _________________ Richard
SoCalBajas Member
cbeck Samba Member
Posted: Sat Aug 26, 2017 3:56 am Post subject: Re: so soon? |
Yesterday was productive. Passenger grab bar and side mirrors on. Cranked up spring plates,need a level spot to get both sides evened out. Swapped 52 for some 60 idle jets, the engine really liked that. Floor pans painted, and bed floor installed. Going to call for insurance and hit the dmv today. Still need 4 wheel alignment. |
cbeck Samba Member
Posted: Sat Aug 26, 2017 9:53 am Post subject: Re: so soon? |
STREET LEGAL AGAIN Now where is that drunk :2gunfire: :snipersmile: :fist: |
