Pre-A vs 36HP breathers
gimmesomeshelter
gimmesomeshelter is offline
PostPosted: Thu Feb 11, 2016 8:35 pm    Post subject: Pre-A vs 36HP breathers Reply with quote
Is a Pre-A breather any better than the standard 36HP breather?
http://www.thesamba.com/vw/classifieds/detail.php?id=1404629
Cheers,
Paul
My dog's vet has all my car money (http://sagecenters.com/)
RichardinNZ
RichardinNZ is offline
PostPosted: Fri Feb 12, 2016 11:16 am    Post subject: Re: Pre-A vs 36HP breathers Reply with quote
Don't know the answer.but know which one looks most cool...
Richard
'58 Beetle; NZ Assembled
Dual Carb 36hp
View user's profile Send private message AIM Address Instagram Gallery Classifieds Feedback
Jacks
Jacks is offline
PostPosted: Sat Feb 13, 2016 9:35 pm    Post subject: Re: Pre-A vs 36HP breathers Reply with quote
The 356 super can have breather issuses due to several factors. One factor is that larger "Super" bore on some earlier engines moves more air in to the crankcase as the pistons return to the lowest position. Another factor is that higher compression can allow more gasses past the rings, particulary when worn, increasing crankcase pressure. Gasses escaping past valve guides/stems add even more pressure. As of this is not bad enough, the waste gate of the oil pressure relief valve on two piece 356 engines, as well as associated VW cases, dumps excess oil in to the timing gear area, which has limited drain back to the sump resulting in potential overfilling of the timing gear chamber. Slinging of oil off the timing gears exacerbate the problem. The higher rpm redline of the super adds to the overfilling of the gear chamber with oil due to higher oil pump speeds. This excess oil, combined with crank case pressure, can blow oil far up into the generator tower and out the road draft tube of the filler. Porsche added a larger chamber to the filler which allows excess oil to accumulate in the chamber briefly during high rpm's which will drain back to the engine (hopefully) after shifting or otherwise lowering rpm.
I have had good results using this part (a copy of a factory part, IIRC):
https://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111115450
In my experience, this part does not install in minutes as claimed, due to irregularities of the casting in the tower area. Significant trimming, and multiple attempts of installation may be required.
I do NOT recommend opening up the tiny square hole at the bottom of the cases between chambers to allow oil to flow back to the sump. This modification may allow even more oil into the timing chamber during long uphill climbs when full throttle applications are needed.
Does this help?
Jack Staggs
Actual name
RichardinNZ
PostPosted: Tue Feb 07, 2017 7:16 pm    Post subject: Re: Pre-A vs 36HP breathers Reply with quote
Can the WW oil baffle be installed on a built engine (ie in the car) is can it only be installed when the case is split?
Thanks
Richard
Richard
Dual Carb 36hp
txoval
txoval is offline
PostPosted: Tue Feb 07, 2017 7:28 pm    Post subject: Re: Pre-A vs 36HP breathers Reply with quote
Can be installed on built engine. It simply slides into the space beneath the generator. So remove the fan shroud/generator, remove the gasket, insert piece, install new gasket, install generator/shroud
Since I added other vents/breather I didn't install one, even though I have it.
Too bad you don't live in the states, I'd give it to you.
It also comes flat...you have to bend it into shape
RichardinNZ
PostPosted: Tue Feb 07, 2017 8:17 pm    Post subject: Re: Pre-A vs 36HP breathers Reply with quote
Thanks for the useful info; the 36hp dumped a patch of oil out of the standard breather tube after about 1.5hrs of relatively hard running the other day, despite having fitted the vented valve covers. I'm therefore thinking the baffle may be worthwhile. At least if they are sent flat the shipping may be less!
I was also considering whether to fit a filler/breather box; such as a Berg breather. Does anyone know whether these can be easily adapted to fit 36hp?
Thanks
Richard
Richard
Dual Carb 36hp
txoval
txoval is offline
PostPosted: Tue Feb 07, 2017 8:50 pm    Post subject: Re: Pre-A vs 36HP breathers Reply with quote
I took a later model 36hp breather/oil cap and welded a cover and breather port on it, to make it similar to late model 1600's.
Let me know if want a better picture of mine
RichardinNZ
PostPosted: Wed Feb 08, 2017 3:42 pm    Post subject: Re: Pre-A vs 36HP breathers Reply with quote
Do you then route it to a breather box on the firewall?
Thanks
Richard
Richard
Dual Carb 36hp
txoval
txoval is offline
PostPosted: Wed Feb 08, 2017 6:46 pm    Post subject: Re: Pre-A vs 36HP breathers Reply with quote
Yes
