Bruce Amacker Samba Member
Joined: December 26, 2007 Posts: 1786 Location: Cleveland, Ohio
campingbox Samba Member
Joined: November 14, 2000 Posts: 10196 Location: Petaluma, CA
Posted: Fri Feb 12, 2016 7:48 am Post subject: Re: Small Nut vs. Big Nut Axle Tubes |
It's easy to install those snubber brackets on an early box, maybe they were relocated?
The wheel cylinder bolts are in a different spot and the big nut boxes have the cap on the inside. |
Posted: Fri Feb 12, 2016 8:14 am Post subject: Re: Small Nut vs. Big Nut Axle Tubes |
campingbox wrote: |
By the looks, rust and age I'm pretty sure the snubber mounts are OE, plus the welds look original. (I've R&Rd snubber mounts before.) The inner housings do have the big plug and I'm pretty sure the WC is relative to the outer housing. I think this abortion had early brakes on it which matched the outer housing.
I've just never heard of small nut outer stuff on a BN inner housing/tube.
The bus is a '60, the tranny housing appears to be '67 (12v) with the ends of the axles converted to SN. Odd. _________________ '66 Deluxe Bus
'65 Standard Bus
Build threads:
'66- http://www.leakoil.net/forum/viewtopic.php?f=23&t=2888&sid=54d8dedfb3822f99c7f2ea430cb4e856
'65- http://leakoil.net/forum/viewtopic.php?f=23&t=4263 |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14269 Location: Casa de Oro, California
Posted: Fri Feb 12, 2016 10:39 am Post subject: Re: Small Nut vs. Big Nut Axle Tubes |
Does it appear that the dowel pins were ever removed? |
