Dirtyhippy Samba Member
Joined: April 24, 2015 Posts: 15 Location: Newberg, Oregon
Posted: Fri Feb 12, 2016 12:19 pm Post subject: Syncro locker vacuum hose routing |
I am trouble shooting my locker. Everything seems to be solid, junctions aren't loose, hoses aren't cracked, actuator moves if I blow into it. Just don't seem to be getting a vacuum. Where does the vacuum source start at the intake manifold? I have followed the lines into the engine bay only to see them tuck inside a hole above and behind the engine into the chassis. Where do they go from there?
On another note, is there a canned smoke to make this easier next time?
[img]https://www.thesamba.com/vw/gallery/pix/1464401.jpg[/imv
I presume that this is the breather for the differential?
_________________ The bus came by and I got on, that's where it all began... |
ScottShelley Samba Member
Joined: October 15, 2012 Posts: 513 Location: California
Posted: Fri Feb 12, 2016 12:25 pm Post subject: Re: Syncro locker vacuum hose routing |
Look under the van on the driver side. There is a 3 bulb canister that is the vacuum reservoir. There is a large vacuum line going to the brake booster that is Td to feed the reservoir. You should be able to check the vacuum there to start. |
insyncro Banned
Posted: Fri Feb 12, 2016 12:54 pm Post subject: Re: Syncro locker vacuum hose routing |
Verify vacuum at intake.
Make sure check valve is operating properly.
The locker system is very simple.
The stock lines of this system are colored, white, blue, black.
Make sure that you do not have obstructions or broken lines / connectors.
The stock rubber L connectors develop cracks at the bends.
The actuator can also be tested if disconnected at the shift coming out of the trans.
A roll pin holds it in place.
I have documented many of these parts, shown tricks and proper 3 knob routing in the Corter thread.
http://www.thesamba.com/vw/forum/viewtopic.php?t=525134&highlight=corter
Yes it is a long thread, but filled with Syncro specific info.
Hope this helps. |
Posted: Sat Feb 13, 2016 4:08 pm Post subject: Re: Syncro locker vacuum hose routing |
I hooked up a mighty vac to everything and tested. It all seemed to hold. Then checked the hg at the manifold line, it went to 15 hg, then hooked it all back up again, then it started to work. I'm wondering if I dislodged something when I applied manual vacuum to the system. However, the actuating pin moves only about halfway. I'm not moving the wheels( while underneath) so, is it possible we just arent lined up and engaging all the way yet? No
Light on the dash yet either. _________________ The bus came by and I got on, that's where it all began... |
Posted: Sat Feb 13, 2016 4:27 pm Post subject: Re: Syncro locker vacuum hose routing |
To get the locker to engage you will need to have the two rear wheels spinning at different speeds. I usually test by doing slow s turns on an unpaved road. |
Posted: Sat Feb 13, 2016 4:40 pm Post subject: Re: Syncro locker vacuum hose routing |
Testing tomorrow. I will post a new update, pictures, et cetera. _________________ The bus came by and I got on, that's where it all began... |
Posted: Sun Feb 14, 2016 1:51 pm Post subject: Re: Syncro locker vacuum hose routing |
I drove the Van around for 15 minutes on a gravel road, swerving, turning , a lot...... Pin drives only about halfway into the cylinder. Could it be that the po replaced things and the roll pin was pushed through a little too far, scored the cylinder? [/img] _________________ The bus came by and I got on, that's where it all began... |
Posted: Sun Feb 14, 2016 7:31 pm Post subject: Re: Syncro locker vacuum hose routing |
Got the punches out and gently tapped the roll pin into the diff lock pin.
Wasn't happy with the result so I tapped a little more and dragged my leather man outbound the outside edge hoping to dislodge any burrs. Cleaned it up with a magnet and a towel. Took it for a test drive.
We have light!!!! So I climbed underneath for another looksy....
Too dark to go mudding. I will have to try it again tomorrow.... _________________ The bus came by and I got on, that's where it all began... |
insyncro Banned
Posted: Mon Feb 15, 2016 1:53 am Post subject: Re: Syncro locker vacuum hose routing |
Awesome
Enjoy the locker, it is a God sent when in the thick of it. |
Syncro Jael Samba Member
Posted: Mon Feb 15, 2016 6:18 am Post subject: Re: Syncro locker vacuum hose routing |
I put a short piece of clear tubing over the actuator and pin. It has a small hole to let you access the roll pin with a punch. I also use the hole to squirt Fluid Film inside the tubing to keep everything lubricated. The clear hose is nice to keep everything clean and you can still watch the movement. Just FYI. _________________ 1987 Syncro Westfalia Hightop - NAHT
Subaru EJ25 Forged Frankenmotor, Triple Knob.
Jael = (Mountain Goat) |
