Mike760 Samba Member
Joined: November 19, 2015 Posts: 43 Location: Oceanside, CA
Posted: Sat Feb 13, 2016 10:03 am Post subject: Power Windows Not Getting Constant Power |
Just started having an issue where my power windows appear to not be getting constant power with the engine running. Back lighting blinks on both driver and passenger side. When I roll them up or down... they move, stop, move, stop w/ the blinking.
With the key in, they work just fine. It is just once the van is running.
I've searched thru and have not found any loose wires. Could this be a relay issue?
Thank you very much! _________________ 1984 Westfalia |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32632 Location: Reading Pennsylvania
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Sat Feb 13, 2016 12:12 pm Post subject: Re: Power Windows Not Getting Constant Power |
Could be corrosion at terminal contacts in the switch. That's easy to clean. Does the problem occur at both idle and higher RPM?
Aloha
tp |
Posted: Sat Feb 13, 2016 4:47 pm Post subject: Re: Power Windows Not Getting Constant Power |
Thank you all for the help.
I had just cleaned the grounds and possible not gotten one 100% down. I went thru and cleaned them all up and it seems to have stopped. Fingers crossed it doesn't return.
Still have something funky going on. The passenger window is slow operating from the driver side. Works fine when operating from the passenger side. But I can live with that... Thank you! _________________ 1984 Westfalia |
Posted: Sat Feb 13, 2016 7:10 pm Post subject: Re: Power Windows Not Getting Constant Power |
Mike760 wrote: |
... The passenger window is slow operating from the driver side. Works fine when operating from the passenger side. ... |
That might be due to the length of the wiring or corroded connections. Resistance = slow movement.
Aloha
tp |
Posted: Sat Feb 13, 2016 9:15 pm Post subject: Re: Power Windows Not Getting Constant Power |
Thanks Tom.
I'll have to remove the door panels and check all the wiring someday. The van has power windows, mirrors, dealer ac,... It's a mess of wires in the dash so I am avoiding messing with anything too much. _________________ 1984 Westfalia |
Posted: Sat Feb 13, 2016 9:32 pm Post subject: Re: Power Windows Not Getting Constant Power |
Mike760 wrote: |
... I'll have to remove the door panels and check all the wiring someday. ... I am avoiding messing with anything too much. |
The switches will pop off without removing the panels. You can clean and/or exercise the connections. That solved my intermittent passenger power window problem.
Aloha
tp |
