cdennisg Samba Member
Joined: November 02, 2004 Posts: 20278 Location: Sandpoint, ID
Posted: Sun Jun 24, 2018 5:34 pm Post subject: Re: My 57 Dove Blue Kombi |
Definitely looks better with the rear bumper in place. And yes, they can be a bit finicky to get installed just right. The effort is worth it. _________________ nothing |
Skim Rants Master
Joined: April 15, 2001 Posts: 17082 Location: GFK 31 Year Vet
Posted: Sun Jun 24, 2018 5:38 pm Post subject: Re: My 57 Dove Blue Kombi |
Hell yesss. Man bummer I didn’t see you at Prado! _________________ GFK
1953 Kabriolet
1954 Sunroof
1959 Lowlight Ghia vert
1963 Deluxe Turkis Walk Thru 15 Window OG Paint |
Dubskii Samba Member
Posted: Sun Jun 24, 2018 10:04 pm Post subject: Re: My 57 Dove Blue Kombi |
cdennisg wrote: |
Definitely looks better with the rear bumper in place. And yes, they can be a bit finicky to get installed just right. The effort is worth it. |
Most definitely! BTW when is your 57 rehab going to start?
Skim wrote: |
Hell yesss. Man bummer I didn’t see you at Prado! |
Likewise. This year was a "feeling it out" camping experience for me. Next year will be a few more days for sure. I was at the show on Sunday but there was so much going on I lost focus on the everything I wanted to see/do. _________________ 69 Sunroof Deluxe - Montana Red/Cloud White (Sold)
57 Kombi - Dove Blue http://www.thesamba.com/vw/forum/viewtopic.php?t=648240
WTB Early Dove Blue Bus Driver's Side Door
WTB Joe Heishman VW Arlington, VA License Plate Frame or Other Memorabilia |
Posted: Sun Jun 24, 2018 10:07 pm Post subject: Re: My 57 Dove Blue Kombi |
Dubskii wrote: |
BTW when is your 57 rehab going to start? |
Sometime in this millennium, I swear! _________________ nothing |
Coondog Samba Member
Joined: August 19, 2006 Posts: 78 Location: Daphne, AL
Posted: Wed Jun 27, 2018 12:49 pm Post subject: Re: My 57 Dove Blue Kombi |
Gorgeous, that is the bumper |
Posted: Fri Jul 27, 2018 10:22 pm Post subject: Re: My 57 Dove Blue Kombi |
Am I crazy? New wiring harness, (+) and (-) cables, re-furbished ignition and speedo, OG wiper switch and hard start relay.
Too late now!
This cobbled together mess is what I am trying to clean up. Also, a number of other areas that are gouged, spliced and held together with electrical tape.
Amazingly everything worked! I am hoping I can repeat that feat with it all being wired correctly.
Posted: Sun Jul 29, 2018 11:02 pm Post subject: Re: My 57 Dove Blue Kombi |
Followed some advice on The Samba and cut the main harness in the middle and fished from there with the help of my youngest son. Relatively easy except for the portion that runs from the rear frame and into the engine compartment. It took me about an hour to get the harness to make that 90 degree turn through two holes. I also had to enlarge the hole in the front with a punch to get the brake light wire and sleeve to fit.
Main harness in front
Difficult 90 degree bend
Engine is all wired up. Using shrink tubing on all spade connections where necessary. Other than that it is all screw terminals for me. Still need to ground the tail lights
Hard start relay kit and starter are complete. I wrapped the fuel sending wire several times around the other wires for possible future use.
Still looks like a train wreck under there but will be cleaned up soon.
So first of many questions I am sure...The supplied connector block holes for the below connection are not large enough to fit the single or the double wires as shown.
Has anyone tried to drill the connector block holes larger or is it better to just use a large butt connector? _________________ 69 Sunroof Deluxe - Montana Red/Cloud White (Sold)
western auto Samba Member
Posted: Mon Jul 30, 2018 9:02 am Post subject: Re: My 57 Dove Blue Kombi |
I think that hard start kit is completely unnecessary if your 12v |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Mon Jul 30, 2018 10:12 am Post subject: Re: My 57 Dove Blue Kombi |
western auto wrote: |
I
I would install it. I have had 12 volt buses that started much better in the winter with the hard start relais. And you simply don't run all the amperage to the ignition lock and back to the starter. Should have been like that from the factory. _________________ regards
Uli
Posted: Mon Jul 30, 2018 11:57 am Post subject: Re: My 57 Dove Blue Kombi |
mandraks wrote: |
I
I would install it. I have had 12 volt buses that started much better in the winter with the hard start relais. And you simply don't run all the amperage to the ignition lock and back to the starter. Should have been like that from the factory. |
I bought the kit several years ago when I was having starting issues and like Mandraks said it is a good idea and probably should have been like that from the factory. _________________ 69 Sunroof Deluxe - Montana Red/Cloud White (Sold)
Posted: Tue Jul 31, 2018 10:16 pm Post subject: Re: My 57 Dove Blue Kombi |
Picked up some new screw terminal bulb holders for my speedo.
Replaced my headlight bulb holders since those disintegrated and/or broke when they were removed.
Cleaned up my headlight switch and shined up the spade connectors. I am assuming this is not year correct since it doesn't have screw terminals???
Hoping to get back to wiring this weekend. _________________ 69 Sunroof Deluxe - Montana Red/Cloud White (Sold)
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
Posted: Sat Aug 04, 2018 2:32 pm Post subject: Re: My 57 Dove Blue Kombi |
Cleaned up the dome switch
Got the headlights wired. Not sure what is going on in the "Before" but they worked. Much cleaner in the "After" pic.
Before
After
Any ideas on how to get the red wires from the instrument harness and main harness into the fuse block? The fuse block hole is too small to accept these two wires as they come in the harnesses (ie soldered). I noticed in a few pics I searched up that these wires appeared staggered as they enter the fuse block. I would rather not butt connect them and then run a single wire into the fuse block.
sgellis Samba Member
Joined: July 06, 2016 Posts: 2014 Location: SW Nova Scotia, Canada
Posted: Sat Aug 04, 2018 6:52 pm Post subject: Re: My 57 Dove Blue Kombi |
Dubskii wrote: |
Cut the solder off and strip the wire back. Twist the wires tight and solder. If they seem too large you can remove a few strands before soldering. You don't actually need to solder but it is better in the long run. _________________ My 64 Kombi restoration
My camper interior build
My 54 standard restoration
The Nova Scotian Barndoor (YouTube)
The Nova Scotian Barndoor (CAD drawings) |
Who.Me? Samba Member
Joined: July 14, 2014 Posts: 2211 Location: UK (South)
Posted: Sun Aug 05, 2018 1:48 am Post subject: Re: My 57 Dove Blue Kombi |
Mine look like they have ferrules on the end and were crimped flat.
They are somewhat staggered too...
Not sure if this helps you for routing the wires to the upper connectors too. I don't have so many going through that hole behind the fuse box. It doesn't look to me like my fuse box has ever been out.
_________________ Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786 |
Posted: Sun Aug 05, 2018 11:08 pm Post subject: Re: My 57 Dove Blue Kombi |
Thanks for the suggestion sgellis and Who.Me?. I believe I have a solution and will post when it is confirmed.
Who.Me? wrote: |
Who.Me? The wiring on the second picture is the same to the top connectors as mine except the two outer wires are not routed through the upper hole. Or are you saying that from the factory you think VW didn't route the two outer wires through the upper hole? Either way, thanks for the pics! _________________ 69 Sunroof Deluxe - Montana Red/Cloud White (Sold)
Posted: Mon Aug 06, 2018 12:05 am Post subject: Re: My 57 Dove Blue Kombi |
Dubskii wrote: |
...Or are you saying that from the factory you think VW didn't route the two outer wires through the upper hole? |
Yes. I just posted that pic in case you were particularly OCD about things like that. _________________ Andy
Jacco Verveer Samba Member
Posted: Mon Aug 06, 2018 2:17 am Post subject: Re: My 57 Dove Blue Kombi |
sgellis wrote: |
Dubskii wrote: |
Cut the solder off and strip the wire back. Twist the wires tight and solder. If they seem too large you can remove a few strands before soldering. You don't actually need to solder but it is better in the long run. |
The hole was bigger in your original fuse box drill it out a little |
Posted: Thu Aug 09, 2018 11:01 pm Post subject: Re: My 57 Dove Blue Kombi |
carbage wrote: |
sgellis wrote: |
Dubskii wrote: |
Got it! Ended up cutting one soldered end and spreading the individual copper strands flatter and cutting an angled sliver from the other soldered end. I manipulated the angled soldered end a bit with some needle nose pliers and they both slide in in the fuse block. I wish I had tried the angled sliver idea prior to cutting off the entire soldered tip.
Anyway, I got lights! Headlights (high/low), turn signals, brake lights, wipers, generator, high beam, oil pressure, speedo and interior dome lights all work. And damn, that clear needle looks nice!
Next is firing her up! Fingers crossed... _________________ 69 Sunroof Deluxe - Montana Red/Cloud White (Sold)
Posted: Sun Aug 12, 2018 2:04 pm Post subject: Re: My 57 Dove Blue Kombi |
Cleaned up tail light wiring.
Before:
After:
