Dubskii Samba Member
Posted: Wed Aug 15, 2018 7:29 am Post subject: Re: My 57 Dove Blue Kombi |
Used a little KF remnant to double as a mounting bracket for my flasher relay. Painted the bracket and used velcro to adhere both together. Turned out great!
_________________ 69 Sunroof Deluxe - Montana Red/Cloud White (Sold)
57 Kombi - Dove Blue http://www.thesamba.com/vw/forum/viewtopic.php?t=648240
WTB Early Dove Blue Bus Driver's Side Door
WTB Joe Heishman VW Arlington, VA License Plate Frame or Other Memorabilia |
Posted: Fri Aug 17, 2018 12:36 pm Post subject: Re: My 57 Dove Blue Kombi |
Complete and all systems go! Relatively easy and straight-forward install. Nice to know all wires are in sheathing, no unnecessary connections/splices, correct wire gauge throughout and where and to what things are connected. All grounding locations were shined up and di-electric grease applied. Any non-screw terminal connection was shrink-wrapped and terminated.
Everything is much cleaner and presentable!
Before:
After:
I will post a lessons learned in the next few days. _________________ 69 Sunroof Deluxe - Montana Red/Cloud White (Sold)
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20278 Location: Sandpoint, ID
Posted: Fri Aug 17, 2018 5:23 pm Post subject: Re: My 57 Dove Blue Kombi |
My core muscles hurt knowing the time you spent in the awkward position working under the dash. _________________ nothing |
Posted: Sun Aug 19, 2018 10:17 pm Post subject: Re: My 57 Dove Blue Kombi |
cdennisg wrote: |
My core muscles hurt knowing the time you spent in the awkward position working under the dash. |
Agreed! Lot of time upside down and body twisted to get it all to go together. Worth the effort though. Cruised 50 miles today without an issue! _________________ 69 Sunroof Deluxe - Montana Red/Cloud White (Sold)
Posted: Mon Aug 20, 2018 1:27 pm Post subject: Re: My 57 Dove Blue Kombi |
Finishing touch with the rubber boots.
Posted: Fri Aug 24, 2018 10:13 pm Post subject: Re: My 57 Dove Blue Kombi |
Now that my harness is out, I was able to source quite a bit of good, original wiring for future use if needed.
Rat's Nest
Clean OG Wire
Cool Detail
Motherlode
This was my favorite hack.
Posted: Tue Aug 28, 2018 3:21 pm Post subject: Re: My 57 Dove Blue Kombi |
OK. Just some quick notes on the wiring harness install. I felt the WW wiring harness was a well put together product and worth the money. A few of the wires could have been a few inches longer (ie each front turn signal wire) to facilitate the required connections. The wire connectors that are provided in the kit are too small to work for the connections. I asked WW for larger ones which they gave me but those were too small as well. I ended up using my OG ones.
The directions were straight-forward and easy to follow but did have some discrepencies such as the length of the right front turn signal wire measured 760mm but the directions called it as being 800mm and the wiper motor to switch wire is black and purple striped but the misc wires diagram called it black and red striped. There were a few other itmes as well but relatively minor.
Other than then items listed above I am am very pleased with this product. I would definielty recommend doing this upgrade to any old bus. _________________ 69 Sunroof Deluxe - Montana Red/Cloud White (Sold)
Posted: Sun Sep 02, 2018 9:33 pm Post subject: Re: My 57 Dove Blue Kombi |
This simple engine lid spring has to be one of the best investments in a part I think I have made for my bus. My head has been smacked numerous times over the years and now this baby keeps the prop arm nice and snug!
DONGKG The Araneta Boys
Joined: August 28, 2006 Posts: 5475 Location: Cainta, Rizal, Philippines, "A Certified Type 3 and Karmann Ghia Maniac"
Posted: Sat Sep 08, 2018 3:11 pm Post subject: Re: My 57 Dove Blue Kombi |
I always wanted to add another brake light since the only one on my bus is like 2"x 3". Morons today aren't accustomed to seeing such a small brake light or that low. So I used some OG wiring to to wire up an 11 LED brake light mounted to the rear hatch. Works like a charm! Obviously a modern look to a classic so I am struggling with that. Opinions anyone?
Not too noticable when not lit.
Hello!!!
b-man Samba Member
Posted: Sat Sep 08, 2018 3:46 pm Post subject: Re: My 57 Dove Blue Kombi |
I like it, been considering doing something like that for my '56 panel as well.
My '56 was rear-ended pretty hard back in '84, a nice bright brake light like that just might have prevented it from happening. _________________ 1956 Dove Blue Panel
1966 Velvet Green Single Cab
1957 L41 Black Oval Window Beetle |
motofly196 Samba Member
Joined: June 01, 2008 Posts: 1467 Location: Eastern WA
Posted: Sat Sep 08, 2018 4:06 pm Post subject: Re: My 57 Dove Blue Kombi |
That looks really good! If it's too noticable when not lit for you, maybe you can get a tinted lens? Or like some did it in the 80's, light coat of plastic spray bomb paint on the inside of the lens?
I would rather see that light, than see you get a hard rear end hit. That scares the crap out of me when driving through Seattle! Main reason I spent $80 retrofitting my buckets to LED brake light bulbs in the rear. |
Posted: Sat Sep 08, 2018 10:42 pm Post subject: Re: My 57 Dove Blue Kombi |
b-man wrote: |
My '56 was rear-ended pretty hard back in '84, a nice bright brake light like that just might have prevented it from happening. |
Thanks b_man! Easy and inexpensive (sourced wire and $12 LED strip from Amazon). Made my own brackets and threw a weld on each to the hatch. BTW...nice 56 panel thread. Step up that motivation you say you lack in your thread and get that baby rollin' the streets again. Whereabouts in So Cal are you?
motofly196 wrote: |
Agreed motofly196. An added benefit is that I can actually see it light up when I hit the brakes. I now know that others should be aware that I am braking. _________________ 69 Sunroof Deluxe - Montana Red/Cloud White (Sold)
Posted: Sun Sep 09, 2018 7:26 am Post subject: Re: My 57 Dove Blue Kombi |
Dubskii wrote: |
Agreed motofly196. An added benefit is that I can actually see it light up when I hit the brakes. I now know that others should be aware that I am braking. |
For an added safety measure you could add a flasher like motorcycle guys use. It flashes the brake light a few times before turning solid each time you hit the brakes. I plan to add that setup to my Moto Guzzi and BMW in the near future. _________________ nothing |
b-man Samba Member
Posted: Sun Sep 09, 2018 8:14 am Post subject: Re: My 57 Dove Blue Kombi |
Dubskii wrote: |
b-man wrote: |
Thanks b_man! Easy and inexpensive (sourced wire and $12 LED strip from Amazon). Made my own brackets and threw a weld on each to the hatch. BTW...nice 56 panel thread. Step up that motivation you say you lack in your thread and get that baby rollin' the streets again. Whereabouts in So Cal are you? |
I'm in Santa Clarita. Working long hours all week along with most Saturdays just doesn't leave me with much time or energy for projects. Now with the weather starting to cool down a bit and with my work starting to slow down some I'm hoping I can make some real progress soon. _________________ 1956 Dove Blue Panel
Posted: Fri Sep 14, 2018 9:58 pm Post subject: Re: My 57 Dove Blue Kombi |
b-man wrote: |
Dubskii wrote: |
b-man wrote: |
I'm in Santa Clarita. Working long hours all week along with most Saturdays just doesn't leave me with much time or energy for projects. Now with the weather starting to cool down a bit and with my work starting to slow down some I'm hoping I can make some real progress soon. |
Understood. Keep plugging away when you do get the opportunity. You have a great bus! _________________ 69 Sunroof Deluxe - Montana Red/Cloud White (Sold)
Posted: Sat Nov 03, 2018 2:42 pm Post subject: Re: 57 Kombi |
Finished stripping old sound deadening. Doubt it was came from the factory so it had to go. Some small bits left but damn I love that OG grey!
Stripping anything off of these old busses is such a pain in the ass! _________________ 69 Sunroof Deluxe - Montana Red/Cloud White (Sold)
Coondog Samba Member
Joined: August 19, 2006 Posts: 78 Location: Daphne, AL
Posted: Wed Nov 14, 2018 10:46 am Post subject: Re: 57 Kombi |
Been following your thread for a while. My '57 is getting the welding treatment now. It's about the only thing I can't do worth a flip. I think the brake light mount is excellent. I don't think it takes away from the vintage appeal. Anything you can do to keep someone from rear ended you is the way to go. |
oakman Samba Member
Joined: February 05, 2014 Posts: 1715 Location: Edge of the Desert, Ca
Posted: Wed Nov 14, 2018 10:57 am Post subject: Re: 57 Kombi |
Nice work on everything! The brakelight in the window is the way to go. I'm going to do the same. _________________ Brandon |
Posted: Wed Nov 14, 2018 11:23 pm Post subject: Re: 57 Kombi |
oakman, Coondog thanks for following! I definitely feel better about cruising around with a little more notice to the other drivers of me slowing down. That engine lid brake light is badass but just so damn small!! _________________ 69 Sunroof Deluxe - Montana Red/Cloud White (Sold)
