babysnakes Samba Member
Posted: Sun Feb 14, 2016 6:45 am Post subject: Riveting remote control lock pull rod lever |
My slider was giving me problems opening. So I decided it was time to replace the nylon glider and clean and regrease all the bits. Then I found one of the latch rods just fell out of the box. It looks to have been riveted, I think. The rivet hole inside the box is out of round, so this has been a growing issue. Other than finding a good used unit, is there a way to fix this?
Joined: January 01, 2007 Posts: 16863 Location: sticksville, ct.
Posted: Sun Feb 14, 2016 6:48 am Post subject: Re: riveting latch ordeal |
how thick is the metal/hole depth? if you can thread it, make a stud/spacer etc and put it back together.
what year is it? if you're hard up, I may have one _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Posted: Sun Feb 14, 2016 6:53 am Post subject: Re: riveting latch ordeal |
Its from a '72, I thought about tapping it and using a shoulder bolt, but I don't know how much room there is behind it. It looks to be a tight squeeze. I think this is why it may have been riveted.I checked the Bentley (sorry to use profanity Skills) and also my service manual and neither confronts the issue. |
Posted: Sun Feb 14, 2016 7:03 am Post subject: Re: riveting latch ordeal |
I think it is riveted. refresh my memory...does it have 2 adjustable rods or 1 rod 1 cable? I will look and see what I have _________________
Jake Raby wrote: |
Brian wrote: |
Tcash Samba Member
Posted: Sun Feb 14, 2016 6:17 pm Post subject: 221843654B Remote control lock pull rod lever repair |
Thanks, Aeromech's pics provide a lot of info. Seems it's not a rivet but a press fit post. Mine was sheared off and you can see the hollow shaft remaining.
I don't think it would wise to try and tap it. I'll look into my parts stash, I may have the piece. If not, I''l source a good used one. |
SGKent Samba Member
Posted: Sun Feb 14, 2016 6:22 pm Post subject: Re: Riveting remote control lock pull rod lever |
If you can't find one.
221843654B 8/70 to 7/73
Bus Ok has an ad running for a NOS one. Airhead has used ones. Ken Madsen would be the best price _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
