Joined: January 01, 2007 Posts: 16883 Location: sticksville, ct.
Posted: Mon Feb 15, 2016 8:05 am Post subject: Cargo door/rocker question |
I am working on a 65 panel and had a question about the cargo door/rocker interface.
replacement rocker has lock rod "squares" welded to it to strengthen the area where the lock rod sits.
the cargo door have been repaired long before I got to it and was wondering if the bottom of the door is "notched" around the lock rod pockets.
if they are not notched on the door skin (in the gasket area) it will not allow the door to close without pushing the rocker out of shape, and the lock rods will never sit in the pockets
this isn't a concourse d'elegance resto, but I want it to be as right as possible.
I did search the gallery but really couldn't find any photos. I did see a few that looked as if it may be cut back on the door to allow it to sit into the rocker around the lock rod pockets (which is what I am ready to do) but it was unclear if that was the "correct" way.
sorry if it's been covered. bay guy working on a split here.... _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14271 Location: Casa de Oro, California
Posted: Mon Feb 15, 2016 9:58 am Post subject: Re: cargo door/rocker question |
skills@eurocarsplus wrote: |
...was wondering if the bottom of the door is "notched" around the lock rod pockets. |
If you mean on the inner part, then yes.
This was before I added the rod guide but you can see the notch.
Posted: Mon Feb 15, 2016 10:16 am Post subject: Re: cargo door/rocker question |
it was on the outer skin/gasket channel side of the door.
I thinned that area out about 3/16 and was able to get the door to close. when I get a little further I will post a photo.
I think it's right. so basically the gasket channel needs to be notched to go around the lock pockets. _________________
Jake Raby wrote: |
Brian wrote: |
BarryL Samba Member
Posted: Mon Feb 15, 2016 7:19 pm Post subject: Re: cargo door/rocker question |
You mean notches in the seal?
Posted: Mon Feb 15, 2016 8:04 pm Post subject: Re: cargo door/rocker question |
if that is the seal that goes in the rocker that gives a good picture of what I needed to do.
the door skin hit on the lock rod pockets, so I had to notch the door skin/gasket channel on the door in order to go around the pockets.
again, when I get further along I will post a photo.
good, bad or ugly it's just what I am going to have to do to make this work _________________
Jake Raby wrote: |
Brian wrote: |
BarryL Samba Member
Posted: Tue Feb 16, 2016 9:01 am Post subject: Re: cargo door/rocker question |
if that is the seal that goes in the rocker? |
Yes, NOS. |
