Sodo Samba Member
Joined: July 06, 2007 Posts: 9618 Location: Western WA
Posted: Wed Feb 01, 2023 11:18 am Post subject: Re: Peloquin diff and Torsen TBD (similarities?) |
That has been offered before, maybe a different company.
IIRC it was much much less $$ but was likely cheesier.
That looks like a nice product, but how much torque do you think can be transferred across that lubricated 'circle' where the springs mash it against the side gears?
Probably a little.
Look at a real clutch-type LSD that has a series of clutches, friction material, requiring enhanced lubrication for optimal performance (that squishes out of the way at peril to your gears/bearings!).
And the force comes from an arrangement of "ramps" that produce more force as torque increases,
not just the constant-force of springs.
It's probably helps a little.
$379/$1500= 25%
I highly doubt it's even 25% of a $1500 Peloquin.
Perhaps better than nothing but I doubt its better than your parking brake lever. _________________
....KTMs, GasGas, SPOT mtb |
tjet Samba Member
Posted: Wed Feb 01, 2023 11:40 am Post subject: Re: Peloquin diff and Torsen TBD (similarities?) |
I wonder if the preload will cause issues when trying to lock the diff up.
Also, you must machine some clearance on one side of each of the internal gears inside the diff itself (spider gears).
Are those gears still available new? (just incase I'd want to revert it back to stock)
Thanks! |
Sodo Samba Member
Posted: Wed Feb 01, 2023 11:57 am Post subject: Re: Peloquin diff and Torsen TBD (similarities?) |
tjet wrote: |
I wonder if the preload will cause issues when trying to lock the diff up. |
This cannot be fitted to an 094 Locker, only fits on on the open diff.
It will fit on your front diff.
I would not even go to the trouble to install it.
Maybe someone else will, but you have to trust their ability to perform a valid test, as its contribution will be subtle and difficult to quantify. _________________
tjet Samba Member
Posted: Wed Feb 01, 2023 12:28 pm Post subject: Re: Peloquin diff and Torsen TBD (similarities?) |
I see now . The Traction Concepts spring-loaded LSD block itself replaces item 11 on a standard open diff. The syncro locker (shown below) has the 2 additional holes on that part, as well as the two extra shafts (#17), & 2 more gears (#13). That LSD block only works with 2 spider gears inside the diff, as it looks like a factory locker has 4 gears in there, if i'm reading that right...
& a 091 open diff (for reference) The block replaces item 5 in the illustration below, and puts a spring load on the two spider gears (item 4).
I would definitely try that TC LSD block thing on my lowered '85 if I still had it...
https://www.thesamba.com/vw/gallery/pix/2132517.jpg
Thanks again Sodo |
