First aircooled 65 single cab
Page: Previous  1, 2, 3 ... 15, 16, 17 ... 22, 23, 24  Next
Burlyhammer
Burlyhammer is offline
PostPosted: Thu Mar 01, 2018 7:21 am    Post subject: Re: First aircooled 65 single cab Reply with quote
I guess this means that you’re not going to replace that whole window frame section. Good deal. I didn’t think it looked that bad. Looking good!
ryans65
ryans65 is offline
PostPosted: Thu Mar 01, 2018 7:28 am    Post subject: Re: First aircooled 65 single cab Reply with quote
lol yes. maybe. depends on what mood I'm in when I get to the shop this weekend Laughing
ryans65
ryans65 is offline
PostPosted: Thu Mar 01, 2018 7:36 am    Post subject: Re: First aircooled 65 single cab Reply with quote
just a tip here also for anyone doing the nose/ lower frame:
The Klassic fab nose panel wiper holes DO NOT line up with the factory windshield frame. If you line up the wiper holes the panel is off left to right and it sits way too low leaving a (relatively) large gap at the lap joint. There is a 90 degree bend at the top of the nose panel that is supposed to interface with the frame but I found that when I pushed the nose panel up to where both 90 degree angles meet the holes are way off. I suppose pretty much everyone uses the lower frame when doing a nose but if you plan on saving your frames and tucking the nose panel there are some differences between the two. Kurts video also points these differences out as well as the very ends of the lower frame where you hammer the flange. The KF frame seems to come up short there even with the KF nose. I think there are just too many angles at play there for it to fit right out of the box.
Skim
Rants Master
Skim is offline
PostPosted: Thu Mar 01, 2018 7:53 am    Post subject: Re: First aircooled 65 single cab Reply with quote
Ryan getting down!
GFK
1953 Kabriolet
1954 Sunroof
1959 Lowlight Ghia vert
ryans65
ryans65 is offline
PostPosted: Thu Mar 01, 2018 9:05 am    Post subject: Re: First aircooled 65 single cab Reply with quote
Killing myself doing it too!
Here's my schedule yesterday:
Wake at 4:30am
Drive 1 hour to work
Work 7-5:30
Drive 1 hour to house to feed/ let out dog
Load dog in car
Drive 1 hour to shop
Work on bus 8-10:30
Drive 1 hour home
Unload dog
Go to sleep at midnight
Lol
Skim wrote:
Ryan getting down!
Burlyhammer
PostPosted: Thu Mar 01, 2018 9:07 am    Post subject: Re: First aircooled 65 single cab Reply with quote
Wake at 4:30am
Work 7-5:30
Load dog in car
Work on bus 8-10:30
Drive 1 hour home
Unload dog
Lol
Skim wrote:
Ryan getting down!
You can rest later. Haha
It is definitely hard to make time for everything. Do what you can do.
ryans65
ryans65 is offline
PostPosted: Thu Mar 01, 2018 9:17 am    Post subject: Re: First aircooled 65 single cab Reply with quote
Haha, exactly! I spent too much time resting the first six months of the project that's for sure. Had to get off my ass and make some progress.
Burlyhammer
PostPosted: Thu Mar 01, 2018 9:21 am    Post subject: Re: First aircooled 65 single cab Reply with quote
I just wish I could go “Skim speed!”
ryans65
ryans65 is offline
PostPosted: Thu Mar 01, 2018 10:54 am    Post subject: Re: First aircooled 65 single cab Reply with quote
No doubt! I'm convinced there is a time machine somewhere down in TX.
ryans65
ryans65 is offline
PostPosted: Sat Mar 03, 2018 6:51 pm    Post subject: Re: First aircooled 65 single cab Reply with quote
Picked up two push button doors, the drivers door should give me a nice section to repair the lower hinge on my original door.
ryans65
ryans65 is offline
PostPosted: Fri Mar 16, 2018 5:51 am    Post subject: Re: First aircooled 65 single cab Reply with quote
Three or four projects all going on simultaneously
Had some time to work on the long rocker last night, I had a small "upheaval" after welding. Frustrated, I grabbed my metal hammer and set about making small taps right on the ridge area and to my surprise it actually smoothed the area out considerably. I think it's at a point now where I am satisfied and I can stop thinking about cutting the entire side out and replacing it Laughing
Burlyhammer
PostPosted: Fri Mar 16, 2018 8:13 am    Post subject: Re: First aircooled 65 single cab Reply with quote
I’m glad to hear the hammering worked. I may have to try that as well. That panel looks good!
ryans65
ryans65 is offline
PostPosted: Fri Mar 16, 2018 8:45 am    Post subject: Re: First aircooled 65 single cab Reply with quote
It actually surprised me! There is some filler work that will need to be done but that long side was such a mess to begin with I can't ask for much more. I have not plug welded the braces behind the panel so maybe since it had some "bounce" to it when I was hitting it it was able to absorb the blows and not dent inwards.
ryans65
ryans65 is offline
PostPosted: Sat Mar 17, 2018 6:06 pm    Post subject: Re: First aircooled 65 single cab Reply with quote
Hammered my lower nose lip today and finished welding it
ryans65
ryans65 is offline
PostPosted: Sun Mar 18, 2018 11:25 am    Post subject: Re: First aircooled 65 single cab Reply with quote
Birthday loot
ryans65
ryans65 is offline
PostPosted: Sat Mar 31, 2018 7:17 pm    Post subject: Re: First aircooled 65 single cab Reply with quote
Had to cut out the lower hinge and replace with a donor hinge section. No pics of that as it was tedious and horrible. Door fit is decent now. Passenger needs hardly any work so doors will be done soon. Looks strange with a door on!
Burlyhammer
PostPosted: Sun Apr 01, 2018 6:32 am    Post subject: Re: First aircooled 65 single cab Reply with quote
Wow. Everything is lining up nicely. The door hinge repair is not fun. I put mine off for a long time. Looks like you nailed it!
ryans65
ryans65 is offline
PostPosted: Sun Apr 01, 2018 5:21 pm    Post subject: Re: First aircooled 65 single cab Reply with quote
It was such a pain hanging the door about 30 times by myself but in at a point where I am satisfied now. Shuts with a "click"!
Touch Nicks Thing
Touch Nicks Thing is offline
PostPosted: Mon Apr 02, 2018 3:44 pm    Post subject: Re: First aircooled 65 single cab Reply with quote
You running a new wiring harness or is the original pretty nice?
ryans65
ryans65 is offline
PostPosted: Mon Apr 02, 2018 6:32 pm    Post subject: Re: First aircooled 65 single cab Reply with quote
I ran a brand new one last summer before I really just went all in on this thing. I got a little ahead of myself installing that lol
Page 16 of 24
