VicVan Samba Member
Joined: July 01, 2015 Posts: 1845 Location: Vancouver Island, BC
Posted: Sat Feb 20, 2016 11:19 pm Post subject: Power windows - Why are they always switched on? |
Hi everyone,
91 Vanagon. I noticed the power window switches are always lit, even without the key in the ignition. I'm concerned about the battery drainage...
Is this normal ? Shouldn't the power windows work only with key in ignition or engine running ?
Or is there a way to get rid of those lights (after all, being able to use the windows without key in ignition can be convenient) ?
Thanks for your advice
JB _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
goffoz Samba Member
Posted: Sat Feb 20, 2016 11:29 pm Post subject: Re: Power windows - Why are they always switched on ? |
sorry
that shouldn't be
someone switched the power wire at the fuse block...easy fix
use the search, this is a well discussed situation |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12008 Location: Santa Cruz, CA
Posted: Sun Feb 21, 2016 12:00 am Post subject: Re: Power windows - Why are they always switched on ? |
Yes, you are correct that the illumination shouldn't be on full time. Someone probably installed the trigger wire for the relay(attached to the top of the fuse box) in the wrong place on the back of the fuse box. You will need to look for previous owner "improvements" or changes to the correct wiring of the circuit.
Good luck. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32634 Location: Reading Pennsylvania
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Sun Feb 21, 2016 8:16 am Post subject: Re: Power windows - Why are they always switched on ? |
djkeev wrote: |
... Having the power windows only able to operate with the key on is kind of a PITA in certain situations.
Camping for instance ........
While a key being required is the norm ... |
It is possible to move the windows without the key in an OG Vanagon.
Light switch on, pull up on the highbeam lever, move the windows, don't forget to turn the lights off
Maybe not a good idea to be turning on your highbeams at night in the campground.
Aloha
tp |
Posted: Sun Feb 21, 2016 9:03 am Post subject: Re: Power windows - Why are they always switched on ? |
The light stalk short cut to use the power windows has produced problems for several and is no longer advised according to previous threads. |
Posted: Sun Feb 21, 2016 9:14 am Post subject: Re: Power windows - Why are they always switched on ? |
syncrodoka wrote: |
I wasn't aware that it had caused problems. Thanks for the heads up. Any links those threads?
Aloha
tp |
Posted: Sun Feb 21, 2016 9:38 am Post subject: Re: Power windows - Why are they always switched on ? |
otiswesty wrote: |
For the record, I fried a fuse and melted another wire under my dash using this trick last Fall. I have 100 Amp x 4 highbeams, so that may be the reason if it bypassed my highpower headlight relay. I officially do not recommend doing this and would instead advise to use the key in or rewire the window switch using the Jetta switch version. |
http://www.thesamba.com/vw/forum/viewtopic.php?t=319668
The guy that told him how to do it has told me not to do it as well. |
VicVan Samba Member
Posted: Sun Feb 21, 2016 10:14 am Post subject: Re: Power windows - Why are they always switched on ? |
Hi folks
I found the diagram in the Bentley (97.190), I guess someone plugged the the relay on the permanent + (track 30). I'll take a look later today, I'll let you know.
Two questions :
1/ Can I get rid of the lights inside the switches ? I opened a switch once, was never able to put it back together properly.
2/ so I get it right, the track X refers to equipments that are on when ignition is on or engine running, but turned off when starter is cranking (load reduction) ? _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
Posted: Sun Feb 21, 2016 10:21 am Post subject: Re: Power windows - Why are they always switched on ? |
VicVan wrote: |
Two questions :
1/ Can I get rid of the lights inside the switches ? |
No, when the power window system has power the lights are on. |
kamzcab86 Samba Moderator
Posted: Sun Feb 21, 2016 11:23 am Post subject: Re: Power windows - Why are they always switched on? |
VicVan wrote: |
2/ so I get it right, the track X refers to equipments that are on when ignition is on or engine running, but turned off when starter is cranking (load reduction) ? |
Correct. X circuit = load reduction = power is cut to those components on the X circuit when key is turned to "start". _________________ ~Kamz
2016 Golf GTI S
VicVan Samba Member
Posted: Sun Feb 21, 2016 11:26 am Post subject: Re: Power windows - Why are they always switched on ? |
Which means I need to solve this.
I checked the wiring on relay 24, seems consistent with what the Bentley diagram indicates (relay triggered by black/yellow wire).
I noticed that when I reconnect the battery, relay 8 (that is load reduction relay) clicks. Is that normal ? From what I understand from the Bentley, it isn't. (97.211, track 89).
I measured the following current draws :
Load Reduction Relay (n.8 ) unplugged : 0 mA
Load Reduction Relay plugged, Power window relay unplugged : 17 mA
Both relays plugged in : 37 mA
Why would my Load Reduction Relay be always switched on ? any ideas ? The ignition switch is in good shape from what I can see... _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
0to60in6min Samba Member
Joined: November 27, 2006 Posts: 3417 Location: OR & CA (Oregon/California)
Posted: Sun Feb 21, 2016 12:37 pm Post subject: Re: Power windows - Why are they always switched on? |
I'd think that the PO rewired the power window circuit so it can be operated with the ignition OFF...
I'd think the P terminal was used instead of the G (G1/G3)
the G terminal is hot only when the ignition is ON
the P terminal is hot all the time
look at the back of the fuse board to see if there's any modif there... |
bluebus86 Banned
Posted: Sun Feb 21, 2016 12:46 pm Post subject: Re: Power windows - Why are they always switched on? |
seems handy to have the windows operable with no key in the switch, but power drain is an issue, I'd remove the light bulbs and thus solve the drain issue while retaining the ability to operate the windows with no key. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
VicVan Samba Member
Posted: Sun Feb 21, 2016 1:33 pm Post subject: Re: Power windows - Why are they always switched on? |
0to60in6min wrote: |
I checked, it is properly wired to G1 (black/yellow wire).
Like I wrote in my last post, the problem seems to come from the Load Reduction Relay, which is always hot (and shouldn't, right ? ).
bluebus86 wrote: |
seems handy to have the windows operable with no key in the switch, but power drain is an issue, I'd remove the light bulbs and thus solve the drain issue while retaining the ability to operate the windows with no key. |
Yes but to remove the bulbs you have to open the switch, and I'm not sure I can close them again... _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
Posted: Sun Feb 21, 2016 2:02 pm Post subject: Re: Power windows - Why are they always switched on ? |
VicVan wrote: |
The ignition switch is in good shape from what I can see... |
Unless you removed the switch and broke it open, you do not know if the switch is, in fact, still good.
Pull the X relay out, get a test light (or VOM), and turn the key to "on". There should be voltage at socket 86. Turn the key off; there should be no voltage at socket 86.
Another test: Pull the relay stamped 53 and temporarily put it in position 8 and do your current draw test again. If no draw, X relay is probably faulty (86 could be shorted to 30). _________________ ~Kamz
2016 Golf GTI S
VicVan Samba Member
Posted: Sun Feb 21, 2016 5:07 pm Post subject: Re: Power windows - Why are they always switched on? |
Found the culprit ! It's.... the... ignition switch.
By testing voltage on X relay socket 86 as suggested by kamzcab, i noticed the voltage flickering when I touched the key.
I then tested the ignition switch, and indeed, when key is in OFF position, I still have current on the X terminal.
I tested that switch two months ago, worked fine, that's why I dismissed it originally. Lesson learned.
I'll do like many people on this forum and buy two, and keep the spare in the Van. Any brand you recommend ? Or recommend not buying ? _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
Posted: Sun Feb 21, 2016 5:15 pm Post subject: Re: Power windows - Why are they always switched on? |
VicVan wrote: |
I tested that switch two months ago, worked fine, that's why I dismissed it originally. Lesson learned. |
VicVan wrote: |
I'll do like many people on this forum and buy two, and keep the spare in the Van. Any brand you recommend ? Or recommend not buying ? |
Like most electrical components these days, it's a crapshoot. Just be sure to keep a spare in the van for when (not if) the replacement fails. _________________ ~Kamz
2016 Golf GTI S
VicVan Samba Member
Posted: Sun Feb 21, 2016 8:39 pm Post subject: Re: Power windows - Why are they always switched on? |
Thanks everybody for your help ! _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
bluebus86 Banned
Posted: Mon Feb 22, 2016 11:26 am Post subject: Re: Power windows - Why are they always switched on? |
VicVan wrote: |
Thanks everybody for your help ! |
your battery will no last longer once you have this fixed. parasitic current draw can shorten a battery life a good deal, specially if the vehicle sits for many days between uses. batteries don't like to be discharged and sit, it shortens their service life (I had a parasitic drain in a 914 that killed batteries, the battery would die after a couple weeks of not driving, and its life was drastically cut short. took a while to find the current draw, the fuse panel was missed wired (love the prior owner) and some relays where always on. it appears it was prior owner's work around for dead relay, and it caused another relay to be always on.
happy fix for you. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
