how to remove the motor from your 1969 vw bus
vwuguy Premium Member
Location: southwestern ontario, on and netherlands and bc
vwuguy is offline
PostPosted: Sun Feb 21, 2016 9:02 pm    Post subject: how to remove the motor from your 1969 vw bus Reply with quote
any comments it only took an hour..
Smile please check my youtube and click like and subscribe here trying to get to 1000 subscribers
i challenge you to invite a few friends to subscribe and help a vw uguy out
https://www.youtube.com/@Vwuguy
richparker
richparker is offline
PostPosted: Sun Feb 21, 2016 9:10 pm    Post subject: Re: how to remove the motor from your 1969 vw bus Reply with quote
New hair cut looks good!
__________
’71 Westy build
Adventure thread
’65 Deluxe Build
’71 Double Cab
streamr
streamr is offline
PostPosted: Sun Feb 21, 2016 9:41 pm    Post subject: Re: how to remove the motor from your 1969 vw bus Reply with quote
At about 12 minutes, I was yelling at my computer...Dude, you forgot the throttle cable and gas line! Other than investing in a tripod, I thought it was great.
'03 MV
vwuguy is offline
Thanks
Brian
Brian is offline
PostPosted: Sun Feb 21, 2016 9:53 pm    Post subject: Re: how to remove the motor from your 1969 vw bus Reply with quote
Does this work with a 1500?
Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter
airschooled
Air-Schooled
airschooled is offline
PostPosted: Sun Feb 21, 2016 9:56 pm    Post subject: Re: how to remove the motor from your 1969 vw bus Reply with quote
When you're on a deadline:
Gotta beat book time.....
Robbie
www.airschooled.com
Road trip reports and tech blog:
vwuguy is offline
PostPosted: Mon Feb 22, 2016 7:50 am    Post subject: Re: how to remove the motor from your 1969 vw bus Reply with quote
Heh Rob,
wow using my other bus to pull the motor out. i never thought of that before...
Heh Brian,
yes this video is the same for a 1500,1200, and 1300 too . The only difference is when you lower it down the heater boxes clear a little different and the generator as seen in my previous video when i was taking the motor out of the 69 last time..
also don't forget to disconnect the heater boxes before you start pulling on it or you won't get anywhere..
How fast can you do this. I know the best time i have from start to finish is about 30miuntes to pull a motor..
