nick135 Samba Member
Posted: Mon Feb 22, 2016 10:40 pm Post subject: VW Beetle single stage paint |
I have a 1965 vw beetle that I want to paint my self and I want to find the best single stage paint, primer and what ever else you need for painting. Best bang for your buck I have heard a lot about ppg concept but I see they no longer make it are there any paints out there comparable to ppg concept single stage paint. Paint needs to be strong it's for a daily driver also I m starting from bear metal if that makes a difference |
buguy Samba Member
Joined: November 17, 2003 Posts: 4915 Location: Port Orange, FL
Posted: Tue Feb 23, 2016 7:47 pm Post subject: Re: Vw beetle single stage paint |
PPG has a paint line called Shop Line that i have used with good results. You could also use the Dupont Nason line. Both will work fine. Single stage wont be as strong as a base/clear though. |
offshores Samba Member
Joined: February 08, 2012 Posts: 1085 Location: So Cal
Posted: Wed Feb 24, 2016 5:52 am Post subject: Re: Vw beetle single stage paint |
I've been using 5 Star Xtreme primer which can be sprayed on bare metal. It can be used as regular primer, high build or a sealer depending on how you mix it. I bought my last 2 gallon kits on Ebay for just under $100 shipped. Comes with Gallon of white, grey or black primer and activator. You need to get reducer. I have one 65 Bug fully primed in it and another 65 that's 50% primed. I'm also painting both myself in single stage and recently tried PPG Delfleet and also the Omni line. Both will work for my needs and budget, but I'll more than likely use Omni. The Delfleet dries slower, but is a bit more durable. |
Posted: Wed Feb 24, 2016 12:47 pm Post subject: Re: Vw beetle single stage paint |
Can you find oem colors from these companies also which paint is easier to work with single stage or bc/cc this would by my first paint job and I want to find a paint that's hard to mess up |
jspbtown Samba Member
Posted: Wed Feb 24, 2016 12:55 pm Post subject: Re: Vw beetle single stage paint |
Any paint is easy to mess up. |
Posted: Wed Feb 24, 2016 2:29 pm Post subject: Re: Vw beetle single stage paint |
That's what I have heard but the guy at the paint shop said that single stage is easier to work with . Also what do you guys think about the Nason paint line of single stage urethane |
Posted: Thu Feb 25, 2016 6:56 pm Post subject: Re: Vw beetle single stage paint |
What are the layers of paint products in order . What order do you put epoxy primer ,sealer ,2k primer ,base and clear is that the correct order . Also did I miss something? |
Envious Samba Member
Joined: January 08, 2003 Posts: 1821 Location: Toronto, Ontario, Canada
Posted: Sat Feb 27, 2016 5:25 am Post subject: Re: Vw beetle single stage paint |
Nason single stage shot in my garage.
_________________ 71 Type 1302 Custom
64 Type 151
63 Type 117 L469 Anthracite
64 Type 361 L575 Nutria
64 Porsche 356c
56 Type 113 L227 Strato Silver
52 BSA C11G
59 Heilite Single Wheel Camping Trailer
56 Allstate Single Wheel
84 Vanagon Westfalia
http://www.thesamba.com/vw/forum/viewtopic.php?t=388225 |
Posted: Sat Feb 27, 2016 9:15 am Post subject: Re: VW Beetle single stage paint |
Quote: |
What are the layers of paint products in order . What order do you put epoxy primer ,sealer ,2k primer ,base and clear is that the correct order |
1. Degrease thoroughly & tack
2. Epoxy, then allow appropriate flash
3. High build. Allow to cure
4. Block with guidecoat
5. Sealer (you can reduce your epoxy normally). Allow appropriate flash
6. Base (usually 3 coats) with appropriate flash between coats and appropriate flash before clear
7. Clear.
8. Color sand and buff (if desired). |
Posted: Sat Feb 27, 2016 3:56 pm Post subject: Re: VW Beetle single stage paint |
If it's a daily driver, just prime and paint it with single stage. If you live in California, all the advice you hear about epoxy can be shit canned unless you have a way to get it from another state. |
wcfvw69 Samba Purist
Posted: Sat Feb 27, 2016 5:17 pm Post subject: Re: VW Beetle single stage paint |
For a garage paint job, single stage is a good way to go. Unless you build a terrific garage paint booth, having to apply sealer, base coats and +clear coats can really enhance your ability to get lots of dust and dirt in the wet paint. I agree that a base/clear is more durable. I also think single stage looks better on classic VW's vs. base/clear coat.
I used PPG concept at $500 a gallon w/reducer and hardeners. I was under whelmed by it. I had a few runs in the paint and when I flattened them down, it discolored the paint and required a re-spray of the affected panels.
Many folks get terrific results from the less expensive paint lines already mentioned, especially on a daily driver. _________________ Contact me at [email protected]
The Samba member since 2004.
pwomble Samba Member
Joined: December 22, 2015 Posts: 44 Location: Lakeland, FL
Posted: Sat Feb 27, 2016 6:40 pm Post subject: Re: Vw beetle single stage paint |
Envious wrote: |
Which Nason product did you use? These look great! |
Posted: Sat Feb 27, 2016 7:21 pm Post subject: Re: Vw beetle single stage paint |
pwomble wrote: |
Envious wrote: |
Just Nason urethane. I mixed the top two coats with their panel clear coat as per their spec sheet. Turned out great. Sanded and polished well. _________________ 71 Type 1302 Custom
64 Type 151
64 Porsche 356c
52 BSA C11G
Posted: Sat Feb 27, 2016 10:27 pm Post subject: Re: VW Beetle single stage paint |
Thanks for the replies I think I will go with the Nason single stage paint with some of their clear mixed in any recommendations for epoxy primer |
Posted: Sun Feb 28, 2016 8:21 am Post subject: Re: VW Beetle single stage paint |
nick135 wrote: |
Just be aware that some of these epoxy primers need to be sanded right before you spray the paint on them if you go more than 24 hours after laying the primer on, before laying the color coat paint on. The epoxy primer hardens and the color coat won't adhere or stick to it unless you open the pores back up on the primer by sanding it again before painting.
I forgot that on one panel I did. I had to put some masking tape on it several days after the paint dried. The color coat lifted right up off the epoxy primer due to it not bonding correctly. _________________ Contact me at [email protected]
Posted: Sun Feb 28, 2016 9:26 am Post subject: Re: VW Beetle single stage paint |
Yes!
Follow the flash instructions VERY carefully when using epoxy.
That's one of the nice things about using a high build.... other than getting very straight panels. It kind of gives you a break between primer and base since you have to sand. |
Posted: Sun Feb 28, 2016 5:46 pm Post subject: Re: VW Beetle single stage paint |
while we are talking about paint any suggestions for the wheel wells and inner fenders . i have heard that bed liner works well and i was thinking about the U-pol products black bed liner. |
Posted: Sun Feb 28, 2016 6:45 pm Post subject: Re: VW Beetle single stage paint |
I personally like Herculiner. Easy to apply. Looks good. And seems pretty durable. And not that expensive either. |
Posted: Sat Mar 12, 2016 8:54 am Post subject: Re: VW Beetle single stage paint |
Okay I need some more help I have completely stripped the beetle with paint stripper and I need some recommendations for epoxy primer also I'm going with the single stage Nason paint but I have read their primer is poor quality so what brand do you guys recommend |
Posted: Sat Mar 12, 2016 4:35 pm Post subject: Re: VW Beetle single stage paint |
Kirker Epoxy. Inexpensive. Easy to mix ands spray.
www.autobodytoolmart.com |
